The Hunt Begins...
by MCompact. 07/21/19 02:10 PM
Cambodia Forest, River and Beach.
by Voleak. 07/21/19 02:01 PM
Foxwoods Resorts Casino 301 at NHMS
by bdcardinal. 07/21/19 01:29 PM
2017 Ram 1500 rear brake lines
by LAGA. 07/21/19 01:27 PM
yacco oils, better than motul (xcess)?
by pep808. 07/21/19 01:22 PM
Scotty K. has finally let me down
by Lolvoguy. 07/21/19 01:03 PM
Exxon/Mobil Synergy Supreme +
by incognito_2u. 07/21/19 12:51 PM
Son going to bring another vehicle home
by vavavroom. 07/21/19 12:43 PM
The stent didn't work, now what?
by andyd. 07/21/19 12:34 PM
TV shows you enjoy
by 53' Stude. 07/21/19 12:14 PM
Replaced strut mount. Still binding
by lairdwd. 07/21/19 11:07 AM
2019 Jeep Wrangler Unlimited Rental
by 2015_PSD. 07/21/19 10:33 AM
Galvanic corrosion
by LeakySeals. 07/21/19 10:20 AM
Ford EcoBoost Oil Catch Can?
by JeffKeryk. 07/21/19 10:17 AM
Hybrid-Keep or Trade
by Spector. 07/21/19 10:05 AM
STP S 4967 NEW FILTER CUT OPEN
by 53' Stude. 07/21/19 09:03 AM
Is my mower battery going to die one day?
by motor_oil_madman. 07/21/19 08:26 AM
Repurposing Sears and other retail sites
by Kira. 07/21/19 07:34 AM
andrewv, AMHKCMO, vanenk, grikor, Mikelima
68723 Registered Users
108 registered members (1WildPig, AdditiveOCD, 01rangerxl, 53' Stude, 2015_PSD, 4WD, 11 invisible), 2,517 guests, and 24 spiders.
Topics292,199
Posts5,018,575
Members68,723
Most Online2,967
Mar 10th, 2019
Pennzoil Platinum 5W30 : Does It Hold Up ? #5135291
06/15/19 09:16 PM
06/15/19 09:16 PM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
In reviewing some recent 5W30 synthetics , I become increasingly surprised that PP 5W30 comes in with a low cSt @ 100 degrees C. of 9.8 . Compare this to Valvoline Advanced 5W30 = cSt @ 100 degrees C. of 10.6 , M1 5W30 = cSt @ 100 degrees C. of 11.0 and QSUD 5W30 = cSt @ 100 degrees C. of 11.6 . *While still technically a 5W30 (9.8) , I would think after 4K to 5K miles you may be flirting with the upper end of a 5W20 somewhere down in the high 8's cSt @100 degrees C. ? ... Then again , I believe of the readily available synthetic 5W30 oils the PP and M1 are the only ones with A5/B5 ratings ... Beyond the Pure Plus, natural gas derivative , etc. I just now think the newer PP 5W30 D1 / Gen2 5W30 is kind of an odd oil amongst it's competitors I listed ?
'17 Hyundai Sonata 2.4L GDI 5W30 Valvoline Advanced Syn / Fram Ultra
'10 Hyundai Elantra 2.0L 5W30 QSUD / Fram Ultra
'07 Kia Sedona 3.8L 5W30 M1 EP HM / Fram Ultra
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: ChrisD46] #5135332
06/15/19 10:19 PM
06/15/19 10:19 PM
PEARL River la
tiger862 Offline
tiger862  Offline
PEARL River la
And if you look at UOA on here you will notice not only viscosity drop but lower flashpoint. Everyone on here claim it is nothing to worry about but me personally there are better oils out there for your money.
Tiger862
2018 Grand Caravan
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: ChrisD46] #5135334
06/15/19 10:22 PM
06/15/19 10:22 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
I think the HTHS of Pennzoil Platinum is still around 3.0-3.1 which is what the bearings see while running. And that is what ultimately truly matters. Being that PP has Dexos approval and ACEA A5 means it is a solid performer. I believe only M-1 is the only other 5w30 that carries both of those specs.
Nissan Altima 3.5 Coupe
Carquest High mileage full synthetic 5w30
CQ blue 84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: ChrisD46] #5135410
06/16/19 02:06 AM
06/16/19 02:06 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Any oil with a Euro ACEA spec like A5/B5 or A3/B4 or C3 etc needs to pass a stay-in-grade shear stability test. This is not part of the standard API SN or ILSAC GF-5 test, so a A5/B5 oil like PP or M1 5W30 are usually blended with a more shear stable VII additive.
Castrol Edge 10W30 A5/B5 + Wesfil-Cooper Z154
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: tiger862] #5135443
06/16/19 05:56 AM
06/16/19 05:56 AM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
*That appears to be a prevailing thought ... Currently my Sonata has a newish fill using Valvoline Advanced Synthetic 5W30 which is gaining in popularity due to add pack and UOA's . The Advanced synthetic may become my #1 followed by M1 5W30 and a #3 slot (TBD) .
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: tiger862] #5135494
06/16/19 07:53 AM
06/16/19 07:53 AM
The land of USA-made Subies!
SubieRubyRoo Offline
Considering Pennzoil will warranty your engine for 300k on this oil if you start using by 75k total vehicle miles, and the fact that you can frequently get $10 rebates on 5qt jugs, I'm going to go out on a very thick limb and say you're welcome to your opinion but in the absence of hard data, that your statement is worth only what I paid to read it, or less.
As bbhero points out, and has been discussed quite extensively lately on the board, HTHS is much more relevant than KV100 when it comes to protection and wear. It's also one reason I'm looking at running Redline 5W20 in my Subaru since the HTHS of 3.2 is well in to the same realm as all the other 30wts I've run, and AAMOF it's actually higher than the Amsoil SS 10W30 (3.1) that's currently in my vehicle. However, the Redline 5W20 KV100 is just over 2 full points lower than the Amsoil, I'm expecting a reduction in pumping losses, and quicker lubrication on startup while not losing any protection in the bottom end.
OP, the PP 5W30 is fine for any vehicle that calls for the 5W30 and the specs it meets; if you're looking for a really thick 5W30 and prefer the yellow bottle and easy availability at WM, look at the PP Euro L 5W30. My VOA showed a KV100 of 12.38, which is at the very upper end of the 30wt scale.
[Linked Image]
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: SubieRubyRoo] #5135542
06/16/19 08:43 AM
06/16/19 08:43 AM
PEARL River la
tiger862 Offline
tiger862  Offline
PEARL River la
[Linked Image]
Has anyone been able to use the warranty? Other oil companies have a warranty also.
Tiger862
2018 Grand Caravan
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: ChrisD46] #5135550
06/16/19 08:51 AM
06/16/19 08:51 AM
Iowa
Iowegian Offline
Iowegian  Offline
Iowa
From personal experience, I agree.
I have done a couple UOA for a 2011 Equinox with 2.4l.
The 2nd one was after the engine rebuild. PP (gen 2)full synthetic still wasn't holding up. Thinning badly. Thought maybe it was just the engine (direct injection). 3k miles and it was very thin. After looking at the stories of how Castrol was holding up well with Ford's Ecoboost, I thought I would try it.
Was going to do a UOA on the Castrol Edge (gen 2) I used but sold the car at 3k miles. But the oil was still GOOD. Still clear and not thinned out. The PP was looking pretty bad by 2k miles.
I also swapped from PP to Magnatec for the 2009 Sienna. No UOA, but I was changing oils on the Sienna by 4k miles because the engine was running rough. This time it was 6.5k miles. No color is not indicative of oil quality but if the oil has thinned to the point that I can tell the engine is not "happy" with it anymore....I really don't need a UOA.
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: SubieRubyRoo] #5135659
06/16/19 11:28 AM
06/16/19 11:28 AM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
*Good information - I trust PP 5W30 has a HTHS of at least 3.0 ?
[Linked Image]
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: ChrisD46] #5135695
06/16/19 12:39 PM
06/16/19 12:39 PM
Cali
Malo83 Offline
Malo83  Offline
Cali
I use 9ennz Platinum 5w30 in both my 2008 Malibu LTZ 3.6 and my 2017 Buick Regal GS 2.0T with complete confidence, no need for the rocket science, been using Pennzoil for the last 50+ years of driving thumbsup
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: ChrisD46] #5135730
06/16/19 01:36 PM
06/16/19 01:36 PM
Maricopa Arizona
dave1251 Online happy
dave1251  Online Happy
Maricopa Arizona
PP is just as good as the other products in the same grade and price point.
don't use.
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: ChrisD46] #5136091
06/16/19 08:25 PM
06/16/19 08:25 PM
FL
tblt44 Online content
tblt44  Online Content
FL
Ultra platinum is a little thicker
2 bucks more for 5 quarts at Wally world online here
2003 Avalanche Z71 5.3
2006 Tahoe 5.3
1989 Yamaha moto 4 250
2004 Key Largo w/70 Yamaha 2 stroke
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: tblt44] #5136272
06/17/19 03:35 AM
06/17/19 03:35 AM
Canada
jbutch Offline
jbutch  Offline
Canada
According to a VOA, the new SN + PUP is not thicker anymore.
2015 Forester XT @ 92000km
Current fill: Mobil ESP Formula 5w-30 with Fram Ultra XG7317
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: jbutch] #5136805
06/17/19 04:36 PM
06/17/19 04:36 PM
FL
FL
From penzoil website as of today 06/17/2019
PUP 10.3
PP 9.8
2006 Tahoe 5.3
Re: Pennzoil Platinum 5W30 : Does It Hold Up ? [Re: tblt44] #5136809
06/17/19 04:44 PM
06/17/19 04:44 PM
PimTac Offline
PimTac  Offline
PUP 10.3
PP 9.8
The difference is minuscule.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
