The Hunt Begins...
by MCompact. 07/21/19 02:10 PM
Cambodia Forest, River and Beach.
by Voleak. 07/21/19 02:01 PM
Foxwoods Resorts Casino 301 at NHMS
by bdcardinal. 07/21/19 01:29 PM
2017 Ram 1500 rear brake lines
by LAGA. 07/21/19 01:27 PM
yacco oils, better than motul (xcess)?
by pep808. 07/21/19 01:22 PM
Scotty K. has finally let me down
by Lolvoguy. 07/21/19 01:03 PM
Exxon/Mobil Synergy Supreme +
by incognito_2u. 07/21/19 12:51 PM
Son going to bring another vehicle home
by vavavroom. 07/21/19 12:43 PM
The stent didn't work, now what?
by andyd. 07/21/19 12:34 PM
TV shows you enjoy
by 53' Stude. 07/21/19 12:14 PM
Replaced strut mount. Still binding
by lairdwd. 07/21/19 11:07 AM
2019 Jeep Wrangler Unlimited Rental
by 2015_PSD. 07/21/19 10:33 AM
Galvanic corrosion
by LeakySeals. 07/21/19 10:20 AM
Ford EcoBoost Oil Catch Can?
by JeffKeryk. 07/21/19 10:17 AM
Hybrid-Keep or Trade
by Spector. 07/21/19 10:05 AM
STP S 4967 NEW FILTER CUT OPEN
by 53' Stude. 07/21/19 09:03 AM
Is my mower battery going to die one day?
by motor_oil_madman. 07/21/19 08:26 AM
Repurposing Sears and other retail sites
by Kira. 07/21/19 07:34 AM
andrewv, AMHKCMO, vanenk, grikor, Mikelima
68723 Registered Users
96 registered members (4WD, 1WildPig, 2003f7, 01rangerxl, 53' Stude, 2015_PSD, 10 invisible), 2,509 guests, and 25 spiders.
Topics292,200
Posts5,018,587
Members68,723
Most Online2,967
Mar 10th, 2019
Filter type for New Holland TC24DA #5135287
06/15/19 09:13 PM
06/15/19 09:13 PM
PA
jayjr1105 Offline OP
PA
2002 or 2003 New Holland Tractor
Just did the first oil change on it since 2013. (My father in law is not mechanically inclined)
Used 3 quarts of Shell Rotella T6 5w40 and an STP S3614
After I noticed how black the oil was and the install data written on the oil filter of 2013, I didn't have time to do much research on filter type.
Luckily, Autozone was actually able to look up the filter type for this particular tractor and they pulled up an STP S3614 which they had in stock.
Do I need to worry about anything using a regular oil filter meant for a car?
It fit perfectly and matched the size of the old one exactly.
2013 Mazda 3 - Supertech FS 0w20
2005 Honda Odyssey - Supertech FS HM 5w20
Re: Filter type for New Holland TC24DA [Re: jayjr1105] #5135297
06/15/19 09:24 PM
06/15/19 09:24 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
The filter you used will be just fine. Great choice with the T6.
The oil will be that black again within an hour's runtime. smile
I have a TC45. Good little tractors with Shibaura engines!
Re: Filter type for New Holland TC24DA [Re: jayjr1105] #5135311
06/15/19 09:41 PM
06/15/19 09:41 PM
Virginia
mattwithcats Offline
Virginia
You can use a Fram 3600 oil filter...
It’s the same base and bypass as the 3614, but 5 inches long verses 3 and a half...
Look on RockAuto dot com for cheap filters, Wix 51516 or 51516XP are good solid choices..
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Filter type for New Holland TC24DA [Re: jayjr1105] #5135407
06/16/19 01:49 AM
06/16/19 01:49 AM
Wisconsin
Black_Thunder Offline
Wisconsin
Same size oil filter as my NH TC-30
I've only ever used auto filters for mine either a Motorcraft 910s or a Bosch 3330 which is a 3614 equivalent
I'd buy Callahan autoparts if I could.
Re: Filter type for New Holland TC24DA [Re: jayjr1105] #5135432
06/16/19 04:47 AM
06/16/19 04:47 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I work on a lot of New Holland stuff, and I always step up to the longer 3600 length filters, "just because" I always have so many on hand.
That doesn't use a high volume oil pump (about 2- 3 GPM max) so the 3614 will work just fine.
It's a shame they are sourcing their tractors from LS now, instead of Shibaura
Re: Filter type for New Holland TC24DA [Re: jayjr1105] #5135505
06/16/19 08:07 AM
06/16/19 08:07 AM
PA
PA
Thanks for the clarification guys. This might be the first diesel engine I've ever changed the oil in. I always heard from word of mouth that you can't go wrong with Rotella for diesel parts but all the ck4 and cj this and that certifications can be confusing. I'll probably use a Fram gold 3614 on the next change.
