Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
Canada
The second OEM I have cut open off this car. Pretty standard, all the blue paint fragments are from the cutter.
113k kms on the vehicle (2014 Crosstrek). Also changed the air filter (Fram CA9997) and replaced all four brake rotors and pads today.
I have been using Subaru OEM (blue) filters in both my Subaru vehicles since they were new. I am told the black OEM are better but hard to get in the USA.
Just changed the oil in Crosstrek tonight.
Next change I will start using NAPA Platnium filters that I got on a super sale price.
Originally Posted by Donald
Did you find the rear pads tiny?
Yeah cute little things, I should have taken some pics. The rear inner pads were down to the wick.
Originally Posted by aquariuscsm
Looks alot like the Honda oem.
I think the bypass valve spring has an extra coil ... that is where the infamous Subaru by-pass spec happens.
Excepting the nitrile adbv, looks a lot like the Honda A02. Afaik, no known efficiency spec, however going to speculate in same range as the data point for the A02.
Thanks for c&p.
