Hyundai ELantra ATF follow up
by flinter. 07/17/19 10:14 AM
Poor Bill
by 4WD. 07/17/19 10:05 AM
Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
100 registered members (14Accent, 4WD, AandPDan, AlaskaMike, Alfred_B, 87sammy, 7 invisible), 2,021 guests, and 30 spiders.
Topics291,983
Posts5,014,545
Members68,682
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Oil for 1985 Nissan Pickup. Is high ZDDP required? #5135099
06/15/19 05:08 PM
06/15/19 05:08 PM
CA
Hal9000 Offline OP
Hal9000  Offline OP
CA
Getting read to change oil on a 1985 Nissan Pickup (2.4, automatic) with 99K miles. I have some conventional Pennzoil High Mileage 10w-30 that has been sitting in the garage for around 3 years or so. I was going to use that and a Fram Tough Guard (what Walmart had).
Googling around the internet I see some people saying that an older flat tappet engine like this should have an oil higher in ZDDP. And, there's no better place on the internet than here to ask an oil-related questions. smile
Is the Pennzoil High Mileage 10w-30 fine? I definitely want to keep the truck for many years, so if it's not I'd certainly be willing to go buy something else.
And, out of curiosity, oil sitting for 3 years in a bottle should still be good, right?
Thanks.
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135102
06/15/19 05:11 PM
06/15/19 05:11 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
LOL its an 85 any oil you run will be better than it had in 1985.
2004 Corolla 134004
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 75175
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135105
06/15/19 05:15 PM
06/15/19 05:15 PM
US
talest Offline
talest  Offline
US
KA24E.
Use that three year old oil on that 34 year old Datsun/Nissan and enjoy it.
Back To The Future truck was a Toyota 4x4. Similar but different look than yours.
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135106
06/15/19 05:17 PM
06/15/19 05:17 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I'm sure that oil is fine. I think that engine is a SOHC and therefore not really a flat tappet design. I owned one back then and going by memory about the SOHC thing.
By the way, mine lasted a very long time and the subsequent owner had a couple hundred thousand miles on it.
But like all engines with a timing chain, it's good to use a quality oil and change it frequently.
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135111
06/15/19 05:29 PM
06/15/19 05:29 PM
Maricopa Arizona
dave1251 Online happy
dave1251  Online Happy
Maricopa Arizona
Pennzoil HM is a good fit for your truck enjoy!
don't use.
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135175
06/15/19 07:12 PM
06/15/19 07:12 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
Nissan pickup engines were all OHC, so no flat tappet concerns with these engines.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40
04 Odyssey EX 190k Valv. Durablend 5w-30
96 Maxima GLE 265k Chevron Delo LE 5w-40
07 Chrysler Pacifica Limited 4.0L 140k Belgian Castrol Edge 0w-30 Euro
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: 92saturnsl2] #5135233
06/15/19 08:30 PM
06/15/19 08:30 PM
Canada
expat Offline
expat  Offline
Canada
So maybe not flat tappet, but if a flat rocker acts on a cam, is that not the same thing?
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135246
06/15/19 08:41 PM
06/15/19 08:41 PM
Los Angeles, California
Gokhan Offline
Gokhan  Offline
Thanks.
No, you do not need higher ZDDP for flat tappets with today's modern oils.
However, you do need a thicker base oil for flat tappets. The viscosity your valvetrain experiences is the base-oil viscosity at the given oil temperature because of the ultrahigh shear rates in the valvetrain, not the kinematic or HTHS viscosities. A 15W-40 HDEO is by far the best choice, especially in your climate. The base oil will not get much thicker than that.
10W-30, especially a high-mileage one or an HDEO 10W-30 is OK if your climate does not allow a 15W-40. There is no HTHS viscosity data on Pennzoil HM 10W-30 but it's probably around 3.4 cP and the base oil should be moderately thick as well, although not nearly as thick as that of a 15W-40.
Avoid 5W-30, as the base oil will be too thin for flat tappets. Valvoline Advanced Synthetic 5W-30 could be an exception.
Oils have at least five or more years of shelf life. Shake the bottle before use.
If anyone asks the flat-tappet question again, the answer is any modern 15W-40 HDEO and the ZDDP level does not matter.
There is also Amsoil ACD 10W-30/SAE 30, which is perfect for flat tappets, as it has a very thick base oil because it is a monograde, but it's expensive.
1985 Toyota Corolla LE, 4A-LC engine, ~ 276,000 M
Mobil 1 Extended Performance 0W-20 SN PLUS (PAO-and-AN-based)
Fram Ultra XG3600 filter (full synthetic), 90430-12031 drain gasket (rubber on aluminum)
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: dave1251] #5135293
06/15/19 09:19 PM
06/15/19 09:19 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
I agree with dave1251... Pennzoil HM.
Nissan Altima 3.5 Coupe
Carquest High mileage full synthetic 5w30
CQ blue 84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135399
06/16/19 01:33 AM
06/16/19 01:33 AM
Balearic Islands , Spain
FordCapriDriver Offline
SOHC doesn't mean it's not flat tappet.... i haveppen to have a SOHC flat tappet engine in my Escort.
The camshaft is in the head, and the hydraulic flat tappet lifters ride on the cam, which push up directly on the rocker.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40
G40 Si-OAT coolant in both
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Cujet] #5135402
06/16/19 01:35 AM
06/16/19 01:35 AM
There are various designs of SOHC valvetrains, some do actually have lifters like the ones you would find in a pushrod engine.
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135453
06/16/19 06:18 AM
06/16/19 06:18 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes, I still have oil in the bottle left over from the 1990's - it's perfectly fine and never goes bad if stored properly.
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135506
06/16/19 08:07 AM
06/16/19 08:07 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
KA24E - that's the head and cam used for seq. IVA valvetrain wear tests.
It's like a Honda Civic SOHC design without the VTEC.
Remember too High ZDDP = Cam and follower wear.
2019 VW Jetta S 6MT OCI#0 5033mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135639
06/16/19 11:08 AM
06/16/19 11:08 AM
CA
Hal9000 Offline OP
Hal9000  Offline OP
CA
Thank you for all the responses thus far. Here are a few pics of the vehicle.
She's an ideal runabout/Home Depot vehicle. These older trucks that are low to the ground are so easy to load/unload. It's also extremely easy to park, and has power steering even. Now, obviously it's not going to pull a huge trailer or boat, and with the three speed automatic it isn't going to win the Cannonball Run. It's the 'Sport Truck' trim level, which I presume got you bucket seats in blue plaid and a snazzy ST decal. However, it apparently didn't include AC.
[Linked Image]
[Linked Image]
Re: Oil for 1985 Nissan Pickup. Is high ZDDP required? [Re: Hal9000] #5135643
06/16/19 11:12 AM
06/16/19 11:12 AM
PimTac Offline
PimTac  Offline
Does this truck have the engine with two spark plugs per cylinder?
I almost bought a Datsun 4x4 with that motor. Really nice truck. I wish I had.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Page 1 of 3 1 2 3
