Interesting read
by double vanos. 07/16/19 10:34 AM
Apollo 11
by Snagglefoot. 07/16/19 09:55 AM
Brake Pad Unboxing and Review
by krismoriah72. 07/16/19 09:40 AM
Limited Slip Additive
by Snagglefoot. 07/16/19 09:39 AM
Future of Chevy Bolt
by Snagglefoot. 07/16/19 09:04 AM
ST6607 on Honda CR-V 2.4L
by MontePrix28. 07/16/19 08:50 AM
2006 4runner Oil Leak After Synthetic
by Lucas_Jones. 07/16/19 08:46 AM
Quiet Small Engine
by Bailes1992. 07/16/19 08:26 AM
2005 C55 AMG oil recommendation
by TinyVoices. 07/16/19 08:26 AM
Uniroyal Tiger Paw Ice and Snow 3 - Reviews?
by Miller88. 07/16/19 08:09 AM
Wix XP oil filter deal
by Randy_R. 07/16/19 06:54 AM
How accurate is the octane rating at the pump ?
by Mr Nice. 07/16/19 06:33 AM
NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68670 Registered Users
103 registered members (ad244, 1WildPig, Alfred_B, alchargo, 53' Stude, 4WD, 10 invisible), 2,275 guests, and 27 spiders.
Topics291,937
Posts5,013,724
Members68,670
Most Online2,967
Mar 10th, 2019
2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 #5135090
06/15/19 04:54 PM
06/15/19 04:54 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
This is my friends ride, and I do all the maintenance on it, at least until he moves to Texas in a little over a month.
This oil was in service a little over a year. He does a lot of flying, working out of state, so the car sits a lot.
Code
Iron		26
Chromium	0
Nickel		1
Aluminum	12
Copper		3
Lead		0
Tin		0
Silicon		10
Sodium		5
Potassium	0
Molybdenum	184
Boron		24
Magnesium	12
Calcium		2261
Phosphorous	742
Zinc		876
Fuel		<1 - Estimated
Soot		<.1
Water		<.1 - FTIR
Visc		[email protected]
TBN		2.25
Oxid		21
Nitr		12
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: Colt45ws] #5135093
06/15/19 04:59 PM
06/15/19 04:59 PM
CO
JLTD Offline
JLTD  Offline
CO
Looks ok to me.
Older vehicle, over 100k and going to TX? I'd use 10w-30 and run it a little longer.
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, SS 5w20/Amsoil
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: Colt45ws] #5135136
06/15/19 06:13 PM
06/15/19 06:13 PM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Your friend's 4.6L may have an issue with the timing chain guides wearing. There is elevated Fe and Al; the two signs of wear metals associated with the guides and chain. The Fe is at almost 4ppm/1k miles and the Al is just under 2ppm/1k miles. Those are both about 2x higher than what we'd expect to see for a healthy engine.
These 4.6L engines are generally very low wearing. Here is a link to my UOAs for my two Grand Marquis (2005 and 2007).
As you can see, the Fe and Al on a "wear rate" are much lower, and it does not matter which grade or base stock of oil is used.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5011812/5
My Fe is typically at or less than 1ppm/1k miles and the Al is so low it's typically just noise. And I run 10k mile OFCIs.
It's not time to panic for your friend's car. This is only one UOA. Most certainly, I'd start doing the UOAs every 5k miles and if you see the wear rates uptick even more, it's time for action! He needs to be aware that it's likely cam chain guide wear. It's not that hard to look at it; pull off the valve covers and then use a bore scope to down down at the chain guides.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: dnewton3] #5135137
06/15/19 06:18 PM
06/15/19 06:18 PM
CA
BLND1 Offline
BLND1  Offline
CA
It’s a 120k mile 4.6. Bump it to 5w30 and keep running it until it dies. The repair is likely more than the vehicles worth.
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: Colt45ws] #5135152
06/15/19 06:38 PM
06/15/19 06:38 PM
Maricopa Arizona
dave1251 Online happy
dave1251  Online Happy
Maricopa Arizona
I agree with the chain wear just advise and hope for the best. I learned how to really drive on a Police Interceptor Crown Vic. They can't keep up with the new Chargers but they still are fun to drive.
don't use.
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: dnewton3] #5135328
06/15/19 10:16 PM
06/15/19 10:16 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Fe was higher last time, 39ppm in 5500 miles, so its wearing better, whatever caused it to have a high Fe. Al was 5ppm that report, so that went up slightly on a ppm/mile basis so idk.
-Colton
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: BLND1] #5135465
06/16/19 06:45 AM
06/16/19 06:45 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Yep, when it hits 200,000 miles he can switch to 15W-40
grin2
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: Colt45ws] #5135689
06/16/19 12:23 PM
06/16/19 12:23 PM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Because the Fe is coming down and the Al is going up, it's probably the cam chain tension-er guides. The steel chain is having it's way with the Al backed guides which have nylon surfaces and are known to crack and shed off large chunks. Once the nylon is gone, the steel sees some abuse, but eventually has it's way with the aluminum backer; hence Fe rises and then falls, and the Al keeps going up. I cannot assure you this is the issue; there are other potential places for problems, but this is by far the most likely cause. And like I said, it can be checked by scoping down the front cover.
I would disagree with the thicker oil recommendation; that isn't going to make this problem go away. And, being a 2011 CVLX with 120k on it, it's probably worth a fair amount presuming it's in decent shape, so the repair at a reputable shop is not out of the question. The parts are not expensive; you can get kits for around $150 or less, depending upon what level of part replacement you want to get into. Your friend may do as he sees fit.
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: Colt45ws] #5136125
06/16/19 08:59 PM
06/16/19 08:59 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
I think I still have his filter. Ill grab it from the shop and cut it. My 02 had this problem and it was very obvious looking at the sparkles in the filter.
-Colton
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: dnewton3] #5139589
06/20/19 08:25 PM
06/20/19 08:25 PM
FL USA
DJapplecrisp Offline
FL USA
I have an 04 MGM that I'm running Castrol edge 5w-20 in. Is there anything I can do to prevent or reduce the amount of timing chain/tensioner wear?
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: Colt45ws] #5139699
06/20/19 10:16 PM
06/20/19 10:16 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Not really. Most Modular V8s will make hundreds of thousands of miles, 400-500k is not uncommon before the tensioners wear out and this problem occurs.
A very low percentage of the population they give out around the 100k mile mark. I know in one case I believe there was a bad run of tensioners around year 2000 and there was a bunch of cases of those going bad but beyond that I havent heard a convincing reasoning for why certain ones fail early while most make it through the life of the vehicle.
My 2002 has over 200k miles and was a ex sheriff cruiser so I suspect it was run hard a LOT so I give that one the benefit of the doubt that it was just it's time.
-Colton
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: Colt45ws] #5158941
07/12/19 06:39 PM
07/12/19 06:39 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Update: I cut this oil filter. There was no aluminum particulate in it. It was 100% normal.
-Colton
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: Colt45ws] #5159767
07/13/19 06:41 PM
07/13/19 06:41 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
By the way, are you going to try to convince him to leave it behind? wink
Plain, simple Garak.
Re: 2011 Crown Vic LX, 4.6L 112k, 7.5k on Havoline HM 5W20 [Re: Colt45ws] #5159911
07/13/19 09:28 PM
07/13/19 09:28 PM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Just because you cannot see it, does not mean it's not there. UOAs can see material up to about 5um, all else is smaller than that; your eyes cannot see that small so it does not surprise me that you didn't see stuff in the filter. The UOA is telling you something; there's Fe and AL in elevated levels; something is amiss.
I realize it's your friend's ride. He may or may not have the time/money/care to do anything about it, until it's too late.
