15w40 or synthetic 10w30 for 115°f temps
AZ
I have 2 boats with 350 engines in them. I've always used 1540 or 2050 in them but I've been curious if I'd gain anything from a full synthetic 10w30.
Engine RPM never goes past 4k
We cruise them at 3k.
My only concern is certain spots of water can we warm especially late in the summer.
What are your thoughts?
Why change what's working?
Only difference I could see, is additional cost to you.
Don't they require marine oil?
Keep doing what works. I dont think theres anything to gain here except if you were running longer intervals perhaps.
What you could gain is running a straight-weight oil if the brand/weight you want comes in that offering.
Running a winter rating is pointless for a vehicle not started below freezing (I'm making an assumption here about your use of it), and you sacrifice by having a lighter base oil and non-lubricating and potentially shearing VIIs in it.
15w40 would get my vote. Good all round oil that can handle high heat and even cool temps you may see.
20w50 all the way, way more so for your hot climate.
15/40 acceptable but would prefer 25/40 is you were to go down to a 40.
10w30 to me would be insanity and I think all you would need to do is try it out, then run the boat for an hour or two at 3000+ RPM, slow down and listen to your valves clap.
Most marine engines have 170 degree thermostats in them so it doesnt matter too much as far as water temperature that the boat is running, unless you have closed cooling, then you may have a 190 thermostat..
Oil temperatures do not correlate to water and engine temperature. An engine with a water/coolant temperature of 170 degrees will see oil temperatures well over 200 degrees, there is nothing cooling the oil and your engine compartment is pretty much closed.
This isnt an automobile with 4 smooth rolling wheels, this is a log (boat) being pushed through water with a lot of engine and bearing pressure which greatly adds to the temperature of the oil.
(just my thoughts)
Ps. I always followed the manufacturer which was 25/40 in my mercruisers and now with a Volvopenta engine the book also states 20/50 as an option that I choose to use.
Actually currently using 15w50 Mystik JT8 semi syn this year in our new to us Chaparral.
Originally Posted by DoubleWasp
Don't do it. The 30 weight thing has been tried by the manufacturers before. Didn't work. Wear problems popped up like whackamoles.
This^. Stick with a 40 weight, and HDEOs work great in marine engines.
Not to mention fuel dilution which will shear that 30w down quickly. 15w-40 hdeo is all I'll run in my 4.3l volvo penta. I think you were the one who turned me on to that a few years ago DoubleWasp. Lol
FD is a big problem for a lot of marine engines. Some ridiculously more than others.
But as previously stated, if an engine does not have a nice big oil cooler, it's oil temps will not correlate at all with cooling water temps.
Plenty of marine engines turn 40 weight into 20 weight in short order. Now take a 30 weight, dilute it, and bring it up to 250+°F. Bad situation.
