API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
105 registered members (AlienBug, AandPDan, 69GTX, aquariuscsm, Alfred_B, 2010Civic, 10 invisible), 1,874 guests, and 22 spiders.
Topics291,979
Posts5,014,501
Members68,682
Most Online2,967
Mar 10th, 2019
15w40 or synthetic 10w30 for 115°f temps #5135042
06/15/19 03:29 PM
06/15/19 03:29 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
I have 2 boats with 350 engines in them. I've always used 1540 or 2050 in them but I've been curious if I'd gain anything from a full synthetic 10w30.
Engine RPM never goes past 4k
We cruise them at 3k.
My only concern is certain spots of water can we warm especially late in the summer.
What are your thoughts?
Supertech Junky
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5135043
06/15/19 03:32 PM
06/15/19 03:32 PM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
Why change what's working?
Only difference I could see, is additional cost to you.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5135061
06/15/19 03:53 PM
06/15/19 03:53 PM
Apple Valley, California
Chris142 Offline
Chris142  Offline
The water can't be nearly as warm as the ambient air temp or the water coming out of the radiator.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5135063
06/15/19 03:58 PM
06/15/19 03:58 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Unlimited cooling water supply, most marine engines have relatively low temp thermostats in them, I would stick with the 15W40.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5135124
06/15/19 05:56 PM
06/15/19 05:56 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
Don't they require marine oil?
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5135199
06/15/19 07:41 PM
06/15/19 07:41 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Keep doing what works. I dont think theres anything to gain here except if you were running longer intervals perhaps.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5135202
06/15/19 07:48 PM
06/15/19 07:48 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
What you could gain is running a straight-weight oil if the brand/weight you want comes in that offering.
Running a winter rating is pointless for a vehicle not started below freezing (I'm making an assumption here about your use of it), and you sacrifice by having a lighter base oil and non-lubricating and potentially shearing VIIs in it.
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5135283
06/15/19 09:09 PM
06/15/19 09:09 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
15w40 would get my vote. Good all round oil that can handle high heat and even cool temps you may see.
yup
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5135336
06/15/19 10:35 PM
06/15/19 10:35 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Don't do it. The 30 weight thing has been tried by the manufacturers before. Didn't work. Wear problems popped up like whackamoles.
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5135345
06/15/19 10:50 PM
06/15/19 10:50 PM
Alaska and Wisconsin
SteveG4 Offline
SteveG4  Offline
Stick with the 15W-40 usage.
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: 15w40 or synthetic 10w30 for 115°f temps [Re: leroyd92] #5136298
06/17/19 05:37 AM
06/17/19 05:37 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
20w50 all the way, way more so for your hot climate.
15/40 acceptable but would prefer 25/40 is you were to go down to a 40.
10w30 to me would be insanity and I think all you would need to do is try it out, then run the boat for an hour or two at 3000+ RPM, slow down and listen to your valves clap.
Most marine engines have 170 degree thermostats in them so it doesnt matter too much as far as water temperature that the boat is running, unless you have closed cooling, then you may have a 190 thermostat..
Oil temperatures do not correlate to water and engine temperature. An engine with a water/coolant temperature of 170 degrees will see oil temperatures well over 200 degrees, there is nothing cooling the oil and your engine compartment is pretty much closed.
This isnt an automobile with 4 smooth rolling wheels, this is a log (boat) being pushed through water with a lot of engine and bearing pressure which greatly adds to the temperature of the oil.
(just my thoughts)
Ps. I always followed the manufacturer which was 25/40 in my mercruisers and now with a Volvopenta engine the book also states 20/50 as an option that I choose to use.
Actually currently using 15w50 Mystik JT8 semi syn this year in our new to us Chaparral.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
