98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
Grousebeater, RoyD, clonis, golddots, Baronmoye
68698 Registered Users
27 registered members (Bailes1992, bbhero, Char Baby, ArrestMeRedZ, Danno, 6 invisible), 617 guests, and 20 spiders.
Topics292,010
Posts5,015,212
Members68,698
Most Online2,967
Mar 10th, 2019
4ft LED shop light #5134804
06/15/19 10:28 AM
06/15/19 10:28 AM
Nebraska
Duffyjr Offline OP
Duffyjr  Offline OP
Nebraska
My old 4ft florescent shop light in the garage decided to retire on me after 20 plus years so a searching I go and found this one at HF.
https://www.harborfreight.com/4-ft-led-hanging-shop-light-64410.html
Are these LED lights worth the cost, I guess what drew my attention to it was the 5000 Lumens and 30,000 service life.
Also is it common for these to be throw away, in other words some of the reviewers say the LED is not replaceable.
89 GMC Sierra VR1 10w30/1036 Gold
08 Lucerne CX Advanced 5w30/1040 Gold
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: 4ft LED shop light [Re: Duffyjr] #5134813
06/15/19 10:46 AM
06/15/19 10:46 AM
TX
KJSmith Offline
KJSmith  Offline
TX
You can just replace the tubes with LED.
50k hr life is very common
The ones get at work have a 70k life.
https://www.homedepot.com/p/toggled...LED-Tube-Light-Bulb-D416-40311/206723426
Re: 4ft LED shop light [Re: KJSmith] #5134815
06/15/19 10:49 AM
06/15/19 10:49 AM
Indiana
dlundblad Online happy
dlundblad  Online Happy
Indiana
It was my understanding that the ballast also needed replaced, but after reading the description, I see that's not the case here. Very interesting.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980 (Ecore)
Re: 4ft LED shop light [Re: KJSmith] #5134824
06/15/19 10:57 AM
06/15/19 10:57 AM
Nebraska
Duffyjr Offline OP
Duffyjr  Offline OP
Nebraska
That is interesting but when mine failed to come on I thought it was the florescent tubes needed replacing so I replaced them and it didn't work, I tested the bulbs in my kitchen so I know they're good.. This is a cheap one I got and I don't see where I could replace the ballast. Besides the only way to turn it on and off was with the plug, it's time I stepped up to one with a pull chain.
Re: 4ft LED shop light [Re: Duffyjr] #5134835
06/15/19 11:13 AM
06/15/19 11:13 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: 4ft LED shop light [Re: Duffyjr] #5134861
06/15/19 11:41 AM
06/15/19 11:41 AM
Germantown, MD
greenjp Offline
greenjp  Offline
Germantown, MD
Flourescent lamp ballasts use a not inconsiderable amount of energy so you shouldn't leave them in, even if the LEDs say you can.
50k hours, 70k, it's all theoretical. LEDs themselves don't "burn out" per se, but just get dimmer over time. The quoted hours is typically an estimate of how long it'll take to get to 70% of the initial brightness, based on accelerated usage testing. They're more likely to fail much, much sooner than that due to the various electronics within going bad.
I have several of these (they're available in many different configurations/color temps, under many brand names but presumably all from the same manufacturer in China) in my garage and will be installing a bunch in my mother in law's basement and garage next week. Nice and cheap if you just need a light source.
jeff
Re: 4ft LED shop light [Re: Duffyjr] #5134868
06/15/19 11:50 AM
06/15/19 11:50 AM
ME
eljefino Offline
eljefino  Offline
ME
I got "just tubes" for $2.50 each at Lowes. Utilitech, on "clearance".
I believe my state may have had some sort of subsidy. But this was a couple years back, too.
It would be worth researching if said bulbs can run directly off 120V as some do, and many more will be able to. Then if it's your ballast that died, you can wire around it.
I think you can do better, cheaper.
Re: 4ft LED shop light [Re: Duffyjr] #5134899
06/15/19 12:35 PM
06/15/19 12:35 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
Costco here has the shop light for $19.99 each. You can daisy chain up to four at a time.
2002 Silverado 5.3 0w-20 AMSOIL
Re: 4ft LED shop light [Re: Duffyjr] #5134908
06/15/19 12:50 PM
06/15/19 12:50 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
GOOD quality LED's have good, long life...
cheap Chinese garbage - - - does NOT
If you know someone with a Costco membership,
check out the 4' LED shop lights there - -
those are the nicest you will find at that low of a price
Re: 4ft LED shop light [Re: greenjp] #5134909
06/15/19 12:52 PM
06/15/19 12:52 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
NOPE...... all of the cheap ones I have bought, it is the power supply ("driver") that burns up before they get dim
Re: 4ft LED shop light [Re: Leo99] #5134918
06/15/19 12:58 PM
06/15/19 12:58 PM
D/FW Metroplex
The_Nuke Offline
The_Nuke  Offline
D/FW Metroplex
Originally Posted by Leo99
Those are good lights. I just had to throw mine away, but I had it for several years and used it as a drop light when working on the car, so it met a considerable amount of abuse during its time.
One drawback is that they will bring the mosquitoes in like nothing else, but I was able to mitigate that by wrapping it in red taillight repair tape. That made for an interesting look from the street at night, but I don't care what the neighbors think if I'm managing to reduce the mosquito count exponentially by doing whatever it is drawing their ire.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: 4ft LED shop light [Re: Duffyjr] #5134941
06/15/19 01:17 PM
06/15/19 01:17 PM
Nebraska
Duffyjr Offline OP
Duffyjr  Offline OP
Nebraska
Thanks guys, no homedepot or costco with in 80 miles. Menards, Wally and HF are all I have for reasonable price. I'd rather buy HF than Menards plus 20% off at HF will help.
Funny thing I put the old tubes back in the light and forgot to unplug it and when I went back out an hour later it had come on but I unplugged it and plugged it back in and nothing, time for a new one.
Thanks again!
Re: 4ft LED shop light [Re: Linctex] #5134948
06/15/19 01:25 PM
06/15/19 01:25 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
try reading farther you skipped the part where you are agreeing with him to disagree?
Underline for emphasis
Re: 4ft LED shop light [Re: Duffyjr] #5134952
06/15/19 01:28 PM
06/15/19 01:28 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
I've been very happy with the LED shop lights I bought at Rural King.
Re: 4ft LED shop light [Re: Duffyjr] #5134967
06/15/19 01:47 PM
06/15/19 01:47 PM
TX
KJSmith Offline
KJSmith  Offline
TX
70k hrs may be theory to you.... the LED's I buy ( from Grainger) also come with a 7yr warranty.
They are GE branded, made in China.
I pay right at $10.00 a tube.
I have installed well more than 1000 of these in my area.
No failures... not a single one.
You can get LED's that are direct power, ballast powered, or driver driven.
Direct and ballast power just supply power to an internal DC driver.
It is my understanding that the LED's will not burn out or dim.
The driver will fail first.
I rarely see LED's of any kind rated at less than 50k hrs.
If they are, I would avoid them.
