Which Synthetic Oil Do You Use, And Why?
by BlueOvalFitter. 07/18/19 10:50 PM
do laptop batteries really go bad or
by WhyMe. 07/18/19 10:32 PM
2016-2017 Chevy Equinox reliability
by gregk24. 07/18/19 10:12 PM
Mann HU816 x
by IllinoisSparky. 07/18/19 09:41 PM
Seafood Combo
by vavavroom. 07/18/19 09:37 PM
‘13 Silverado 1500 Extended Cab
by parshisa. 07/18/19 09:35 PM
Where to have a watch serviced?
by E150GT. 07/18/19 08:32 PM
Stubborn diff fill plug
by HoosierJeeper. 07/18/19 08:21 PM
Big score on auto parts clearance AAP
by Marco620. 07/18/19 08:05 PM
Would this cause my jeep to stall?
by MileHigh18. 07/18/19 08:00 PM
Looking for Highlander '06,'07, '09
by Gebo. 07/18/19 06:39 PM
'03 F150 Parking Brake Adjustment
by benjamming. 07/18/19 06:17 PM
Do You Still Change Your Oil at 3K?
by Gebo. 07/18/19 05:33 PM
Any sellers on amazon for Honda A02?
by BTLew81. 07/18/19 03:44 PM
First SMR (MMR) slated to be built at Chalk River
by OVERKILL. 07/18/19 03:31 PM
Torque Specs for 2004 Dodge Ram transfer case
by diyjake. 07/18/19 02:15 PM
OAT ad NOAT
by CCI. 07/18/19 02:06 PM
30 years clean & sober today.
by Papa Bear. 07/18/19 02:03 PM
suuru, Hollicrev, Richb55, Shaz, Grousebeater
68702 Registered Users
40 registered members (alcyon, brudawg, AnalogReigns, ArrestMeRedZ, acmesupply, Bailes1992, 5 invisible), 885 guests, and 34 spiders.
Topics292,057
Posts5,016,066
Members68,702
Most Online2,967
Mar 10th, 2019
Seafoam In Oil (Up To 300 Miles) #5134748
06/15/19 08:48 AM
06/15/19 08:48 AM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
I have now used Seafoam (1 oz. per quart of oil ) at the end of oil changes (i.e. last 200 ~ 300 miles) in all my rides with no ill affects . I use synthetic oils in all my rides at normal / shorter intervals and in every case - the oil came out darker on the dip stick (before & after) using Seafoam ... I then drained the vehicles while warm then refilled with what ever synthetic oil WM has on rollback : Pennzoil Platinum , Mobil 1 or Valvoline Advanced + Fram Ultra oil filter. Will I be using Seafoam before every oil change ? No , but for every 20K miles or so I see nothing wrong with my protocol of using Seafoam for the occasional removal of deposits that a synthetic oil may not remove . Lastly , Seafoam is available at all WM's and is relatively cheap ... Lastly , I do not use Seafoam in my gas tank (nothing wrong with doing so) - I just prefer to use a gas additive with PEA instead .
'17 Hyundai Sonata 2.4L GDI 5W30 Valvoline Advanced Syn / Fram Ultra
'10 Hyundai Elantra 2.0L 5W30 QSUD / Fram Ultra
'07 Kia Sedona 3.8L 5W30 M1 EP HM / Fram Ultra
Re: Seafoam In Oil (Up To 300 Miles) [Re: ChrisD46] #5134755
06/15/19 09:00 AM
06/15/19 09:00 AM
US
talest Offline
talest  Offline
US
Yeah Seafoam is pretty much a waste in the gas, though on cars responsive to higher octane it may make it feel "peppier" for that one tank .
Re: Seafoam In Oil (Up To 300 Miles) [Re: ChrisD46] #5134772
06/15/19 09:22 AM
06/15/19 09:22 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
In this day and age, any oil sold by WM and changed within a decent interval shouldn't require any help.If the car is short tripped or towing , or drives on dirt roads or races, maybe. But for your stable... grin2
Thick oil is better grin2
Re: Seafoam In Oil (Up To 300 Miles) [Re: ChrisD46] #5134776
06/15/19 09:30 AM
06/15/19 09:30 AM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Sea Foam is about 90% oil carrier and 10% Isopropyl alcohol.
I find the only use for it is cleaning out the jets and pickup tubes of small OE engine carbs. It does a real good job of removing gum deposits.
"Science is a body of knowledge, a 'recipe', as it were, for reality. The totality of science is a collection of hard-earned nuggets, using math as a language of expression." Chip Cohen
Re: Seafoam In Oil (Up To 300 Miles) [Re: MolaKule] #5135008
06/15/19 02:43 PM
06/15/19 02:43 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
I found it useful for that purpose as well. I left a non-running chainsaw with SeaFoam in the carb for a week, then I had a running chainsaw.
Various musings: http://hangfire.net
Re: Seafoam In Oil (Up To 300 Miles) [Re: HangFire] #5135366
06/15/19 11:37 PM
06/15/19 11:37 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Heh heh, I've done the same using Berryman's Chem-tool instead for 1/3 the cost. Stihl wouldnt start at end of a Sunday afternoon. Next Saturday it started first pull. Done it a few times since with other stuff. I'v taken to dosing the fuel with it for OPE carb troubles before I break out the tools. I run oily mix ,so a little solvent doesnt mess with internals.
Re: Seafoam In Oil (Up To 300 Miles) [Re: andyd] #5135446
06/16/19 06:09 AM
06/16/19 06:09 AM
NY
demarpaint Offline
demarpaint  Offline
NY
B12 is imo one of the best additives you can put in gas for carb problems in OPE.
God Bless Our Troops
