And so it begins. Winter 2019-2020.
by DejaVue - 12/11/19 12:13 AM
reference for tires wearing faster when new?
by NissanMaxima - 12/10/19 10:46 PM
2.4L GDI Turbo available?
by 2014_K5_Optima - 12/10/19 10:08 PM
rotary compressor breathing air
by MasterBlaster - 12/10/19 09:33 PM
Substitute for Polaris hub oil?
by The_Eric - 12/10/19 08:53 PM
'20 Hyundai Sonata -- Wow-ee! Looks!
by paoester - 12/10/19 07:11 PM
2021 Chevrolet Suburban and Tahoe Revealed
by E365 - 12/10/19 06:56 PM
Do you try to book on widebodies?
by fdcg27 - 12/10/19 06:25 PM
Carbon Farming
by SubLGT - 12/10/19 05:40 PM
How Many Vehicles Do You Maintain?
by Passport1 - 12/10/19 04:23 PM
Bypass Setting vs Subaru
by Al - 12/10/19 03:10 PM
13 chevy equinox I4 engine oil in filter box
by Fitter30 - 12/10/19 02:04 PM
Driven - Direct Injection Oils
by buster - 12/10/19 01:59 PM
.308 Win or .25-06
by mobilaltima - 12/10/19 01:05 PM
FI cleaners ruin injectors?
by Redright9 - 12/10/19 12:54 PM
Planned Changes at Honda
by The Critic - 12/10/19 12:30 PM
The forgotten Bolens 1253
by Lubener - 12/10/19 11:49 AM
Valvoline High Mileage vs Valvoline Full Synthetic?
by Bettez88 - 12/10/19 10:33 AM
Bruce147, snowplow, Rovingcowboy, 2014_K5_Optima, Peter_Tremonti
70098 Registered Users
26 registered members (AnthemBassMan, Char Baby, cos, ctechbob, AurionX2, BlakeB, 4 invisible), 689 guests, and 25 spiders.
Topics298,557
Posts5,138,066
Members70,098
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: SN-Plus VS Dexos1-GEN2 [Re: Solarent] #5133836 06/14/19 06:07 AM
V
Virtus_Probi Offline
V
Originally Posted by weasley
Originally Posted by OilUzer
Didn't some experts say in Europe they don't have/use d1g2 or d2 and they have no lspi issues?
I think they use thicker and/or higher hths oil!
On the contrary - GM brands here issued a service bulletin a while back requiring certain gasoline-engined cars to use dexos1g2 to mitigate LSPI. This was slightly inconvenient as most oils here were dexos2, with few d1g2 options available.
VERY interesting info...thank you!
I have been guessing that we haven't heard much about problems with DIT engines using A3/B4 oils because of the higher ZDDP levels, as that additive is a strong LSPI quencher...but that it is only a guess.
Originally Posted by Solarent
Both options have LSPI testing - GM uses the GMOD, and SN+ uses the Sequence IX which is a Ford engine.
Eliminating LSPI is an interesting part of this question. Lubrizol has been out in the market talking about LSPI protection on used oil (both the tests only
look at LSPI protection on new oil).
Lubrizol Podcast on LSPI
The updated -B1 Ford oil specs also include an LSPI test in a 2.0l EcoBoost, but I don't know how that test compares to the SN+ one.
2014 Forester XT, 105000 miles
Last Change;
PP 5w30 d1G2
Tokyo Roki 15208AA170 filter
Re: SN-Plus VS Dexos1-GEN2 [Re: Virtus_Probi] #5133844 06/14/19 06:13 AM
Solarent Offline
The 2.0L Ecoboost is the same engine in the Sequence IX.
Re: SN-Plus VS Dexos1-GEN2 [Re: Solarent] #5133848 06/14/19 06:19 AM
V
V
Thanks...do you know if the actual LSPI tests are similar between SN+ and the -B1s?
Last Change;
PP 5w30 d1G2
Re: SN-Plus VS Dexos1-GEN2 [Re: Virtus_Probi] #5133926 06/14/19 08:22 AM
T
Triple_Se7en Offline
T
Are all the A3/B4 oils low Calcium (-1100) and high Magnesium (+500)?
19' Hyundai Santa Fe 2.4 GDI - Valv Syn 5w30 / Napa Proselect filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Factory-fill oil / filter
04' Colorado 3.5 / Castrol Edge 0W40 / K&N filter
Re: SN-Plus VS Dexos1-GEN2 [Re: Triple_Se7en] #5134005 06/14/19 10:42 AM
V
V
I have seen a number of VOAs for M1 0W40 FS A3/B4 and they have all been very high in calcium (maybe 2800 ppm) and had little magnesium. I believe the M1 0W40 formulation before that was similar.
I think Castrol 0W40 A3/B4 is quite a bit lower than M1 in calcium but I'm not completely sure of that.
There was a summary of oil additive effects on LSPI from one of the additive makers (Infineum??) that showed a plot with the occurrence of LSPI really plummeting as the ZDDP concentration was swept not far beyond the typical SN/GF5 levels...I actually bought a bottle of Rislone ZDDP additive and was adding a bit at every change before d1G2 came along! Yes, I know I'm ridiculous...
Last Change;
PP 5w30 d1G2
Re: SN-Plus VS Dexos1-GEN2 [Re: Virtus_Probi] #5134012 06/14/19 10:50 AM
Corollaman Offline
That's what I was wondering. Will all these sn+ oils meet the ford -B1 spec? All of the "conventional" oils from supertech, chevron, etc meet sn+.
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5134230 06/14/19 03:55 PM
Direct_Rejection Offline
Thank you Solarent for the prompt link to this vital podcast.
From Part I...
SN+/D1G2 >> SN/D1/G1.
It is eye opening to learn how important the changes are for insurance against LSPI.
From Part II...
The culprit is the combination of small amounts of motor oil, with unburned fuel mixed in, in the crevice volume (between the first ringland and the top piston ring,) along with piston deposits.
LSPI is complex, as stated, but there is also greater specificity here.
It sure sounds like there is a direct correlation between fuel dilution and LSPI.
My maintenance plan with a boosted GDI engine would surely involve the cheapest SN+ oil, Chevron Supreme comes to mind, and OCIs which are quite short, 3k miles !!
Also, I glean that recommended viscosity should be used over going thicker and extending OCis. JMO.
Lexus UX 250h F-Sport
Pennzoil Hybrid 0W16
Re: SN-Plus VS Dexos1-GEN2 [Re: Direct_Rejection] #5134259 06/14/19 04:35 PM
Corollaman Offline
From Part I...
From Part II...
I'm using Chevron Supreme 5w30 SN+ and doing short oil changes (4,000 miles) in my 2016 Fusion 2.0, with a Motorcraft oil filter it's like $17 total.
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5134470 06/14/19 08:58 PM
B
burla Offline
B
A short interval with either will smash the other one assuming a long interval. Ise a stable weight oil like 5w20, even better.
Re: SN-Plus VS Dexos1-GEN2 [Re: Virtus_Probi] #5134527 06/14/19 10:27 PM
O
OilUzer Offline
O
a3/b4 oils have higher hths as well.
Re: SN-Plus VS Dexos1-GEN2 [Re: Virtus_Probi] #5134546 06/14/19 11:11 PM
SR5 Offline
Yes, I recall those plots, and I think it was Infineum. They showed that LSPI events increased linearly with increasing Ca add, hence the SN+ and D1G2 move to replace some Ca with Mg detergent. To decrease Ca levels for the same final TBN.
However they also showed that LSPI events decreased exponentially with increasing ZDDP, it was a powerful quencher of LSPI.
Most Euro A3/B4 oils that I know still have a full Ca detergent package with no or little Mg. However A3/B4 oils don’t have a restriction on their upper Phos (and therefore ZDDP) levels, while ILSAC-SN oils do have an upper limit imposed. Most SN / SN+ and GF-5 oils have about 700 ppm ZDDP while a typical A3/B4 Euro oil will have about 1000 ppm ZDDP. Recall a non-GF5 viscosity grade, like 5W40 has no restriction and so can be SN & A3/B4, it’s the thinner grades that are restricted.
I think when Europe was running full-SAPS A3/B4 oils with high ZDDP levels, they had no LSPI issues even with full Ca detergent packages. But recently they have moved to mid-SAPS C3 oils (like Dexos2) for both petrol (gas) and Diesel engines. This is probably where the problem with LSPI in Europe started as a C3 oil is restricted in the upper level of Sulphated Ash (SA%) permitted, and given that ZDDP adds to the SA% they tend to make Euro C3 oils with the same ZDDP levels as American GF-5 oils, but without swapping out some Ca for Mg and hence the start of seeing LSPI in Europe.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: SN-Plus VS Dexos1-GEN2 [Re: OilUzer] #5134552 06/14/19 11:26 PM
SR5 Offline
Both ACEA A3/B4 and ACEA C3 are high HTHS oils (>= 3.5 cP) they differ in their SAPS level (SA%).
A Dexos2 oil is also a C3 oil (mid-SAPS), but can’t be an A3/B4 oil (high-SAPS).
A GF-5 or D1G2 oil is a low HTHS oil.
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5134816 06/15/19 09:49 AM
T
T
So why are all the oil companies pushing low Calcium and high Magnesium oils these days for GDI / TGDI / lspi Engines. Wait - it's because we use thin oil in this country. Check all the owners manuals in the past decade for verification of that.
So find out what 0W16 / 0W20 / 5W20 / 5W30 oils have a good amount of ZDDP and problem solved. Then be sure to check the labels of these oils, for another verification that says SN Plus and Dexos1Gen2.
I side with the automakers USA specs. Those are Dexos/SN Plus currently. Most-all prior owners manuals have older specs than what's current. But store shelves will catch-up with new specs in little time thereafter.
You can side with high ZDDP in your GDI / TGDI / lspi machines. I like my chances of lower maintenance better than yours, using the latest specs intended for USA vehicles / USA fuel..
Re: SN-Plus VS Dexos1-GEN2 [Re: Corollaman] #5135067 06/15/19 03:01 PM
From Part I...
From Part II...
Nice !
A vastly overlooked motor oil.
Chevron Supreme
SN+.
Hydrocracked.
Synthetic Blend.
Turbo rated.
$2.27/qt.
Page 2 of 2 1 2
