Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
120 registered members (928, 2012AccentSE, apollo18, Anduril, ABomb369, 750IX, 10 invisible), 2,265 guests, and 22 spiders.
Topics301,698
Posts5,200,833
Members70,759
Page 2 of 3 1 2 3
Re: Mixing 0W-16 and 0W-40 [Re: camryrolla] #5132332 06/12/19 12:24 PM
M
Miller88 Offline
M
Have you done a UOA to determine that the current oil is letting you down at 10,000 miles?
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Mixing 0W-16 and 0W-40 [Re: Miller88] #5132339 06/12/19 12:33 PM
camryrolla Offline OP
Miller,
I have not done a 10K UOA, but running AFE/EP at 10K is a walk in the park for this Camry. My goal is to extend OCI further to 12,500 miles, and even to 15K OCI if I could.
'11 Camry 2.5L 170K mi
'07 Corolla 1.8L 220K mi
Always Fram XG filter.
Re: Mixing 0W-16 and 0W-40 [Re: SubieRubyRoo] #5132365 06/12/19 01:12 PM
DoubleNickels Offline
Originally Posted by SubieRubyRoo
Leave blending to the professionals.
This is the only intelligent answer.
Re: Mixing 0W-16 and 0W-40 [Re: DoubleNickels] #5132404 06/12/19 01:51 PM
H
hallstevenson Online Content
Online Content
H
Yeap, blending your own in a jug in the garage doesn't magically take the best properties of one and combine it with the best properties of the other to make a super-duper, magic oil ! Who is to say that a component in one doesn't neutralize or lessen the properties of a component in the other ? Or worse, what if they combine to make something negative to the oil's properties ?
I doubt you end up with a 0W-28 viscosity like someone who does the math thinks either.
Re: Mixing 0W-16 and 0W-40 [Re: camryrolla] #5132413 06/12/19 02:03 PM
G
geeman789 Offline
G
I used M1 0w40 in a Honda Odyssey that spec'd 5w20.
The GOOD: Engine was noticeably quieter when warm, and oil consumption dropped by roughly 1/3 ...
The BAD: Zip. Mileage was about the same. Cold starts were the same.
I liked the quieter engine with reduced oil consumption. Sold van with 150 k miles on it, engine still running A +.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Mixing 0W-16 and 0W-40 [Re: camryrolla] #5132441 06/12/19 02:47 PM
SubieRubyRoo Offline
Originally Posted by camryrolla
Miller,
If you "think" the oil was fine at 10k, why not run the same oil 12.5k and then send it in? Having "more" TBN at a given mileage does absolutely nothing beneficial for your engine... i.e., if two different oils are used and drained at a hard limit of 12.5k, and one oil has a TBN of 2.3 and one has a TBN of 5.2, all this tells you is that BOTH oils could be used in service for some additional time (as long as viscosity is still in grade). However, TBN does not decline linearly, so even the oil that only had a TBN of 2.3 "may" be sufficient to take out to 15k or more... it all depends on your engine and usage. It's not something you can guess about. Amsoil SS is rated to 25k OCIs, and should certainly get you well past your comfort zone at the very least.
From what you're saying (and not saying) in your posts, it sounds to me like you would be almost perfectly served by a nice 5W30 A3/B4 oil. Castrol and Ravenol both make good oils that are in this category that I've used and would recommend. Just remember that picking an oil solely on TBN is like having a chimpanzee pick out your clothes for the day- it may work, but you may end up looking like a monkey.
Pick your oil based on the manufacturer's requirements for your engine and go from there.
De omnibus dubitandum.
Re: Mixing 0W-16 and 0W-40 [Re: OVERKILL] #5132457 06/12/19 03:16 PM
53' Stude Offline
Originally Posted by OVERKILL
If you want to run longer, just run M1 EP 0w-20. Mixing the two isn't going to give you an improved product.
Amen!
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Mixing 0W-16 and 0W-40 [Re: camryrolla] #5132479 06/12/19 03:40 PM
Yah-Tah-Hey Offline
WHY?
Re: Mixing 0W-16 and 0W-40 [Re: SubieRubyRoo] #5132641 06/12/19 07:20 PM
M
Mitch Alsup Offline
M
Why would you bother? <snip> but even the oil blender recommends against it.
Oil blenders recommend using the oil as they blend it.
Is it any wonder.......
Re: Mixing 0W-16 and 0W-40 [Re: camryrolla] #5132759 06/12/19 09:50 PM
A
askani79705 Offline
A
It's a Camry. Run whatever bulk 5w30 the dealer has on special. SIL has done this for over 300k In her 04. With a reasonable OCI you can't kill the [censored] things.
2019 Ford F150 NAPA syn 5w20 Motorcraft Filter
2000 Chevy 2500 Silverado NAPA conv 5w30 AC Delco Filter
2012 Impala MileSYN 5w30 AC Delco Filter
Re: Mixing 0W-16 and 0W-40 [Re: Mitch Alsup] #5132793 06/12/19 10:47 PM
Shannow Offline
Argument doesn't make sense...mixing still uses the same number of retail quarts...
If it's the truth....it can handle the pressure !!!
Re: Mixing 0W-16 and 0W-40 [Re: camryrolla] #5132815 06/12/19 11:47 PM
B
Bullwinkle007 Offline
B
I am hesitant to use 0W-40 alone as the base viscosity is already at 13.4 and running it for 12,500 miles will only thicken it further.
Find the Euro manual for that engine. I guarantee they use it overseas, in accordance with the weather. Both of my Honda's, 1 a v6 and 1 a 2.4, I run motul excess 5/40
Re: Mixing 0W-16 and 0W-40 [Re: Bullwinkle007] #5134393 06/14/19 07:21 PM
chubbie Offline
If you feel frisky mix away. I believe mixing is ok I only mix like half a quart from my last oil change.I would pick a viscosity that you like 20w or 30w and Google the viscosity calculator so you know how much of each to put in.
07 Dodge Ram 151K shell rotella gas truck 5w-30
18 Mazda cx5 61K pennz syn 0w-20
Re: Mixing 0W-16 and 0W-40 [Re: chubbie] #5134399 06/14/19 07:28 PM
chubbie Offline
Re: Mixing 0W-16 and 0W-40 [Re: Bullwinkle007] #5134779 06/15/19 08:32 AM
SR5 Offline
For a 2011 Camry 2.5L in Australia they say you can run 0W20, 5W30, 10W30 or 15W40.
So if you want to use 0W40 then use it, it will be fine. Otherwise the M1 0W20EP or 5W30EP are good options.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Page 2 of 3 1 2 3
