Originally Posted by hallstevenson
Originally Posted by atikovi
If the previous installer used anti-seize this wouldn't be a problem.
Both NGK and Denso both say not to use any anti-seize and I even emailed one of them (don't remember which) to see if they'd kinda hint in a roundabout way something like "it's not necessary, but it won't hurt anything" (wink, wink) but he repeated their stance: no anti-seize. We still put some on but a very, very small amount.
I have said it many times here over the last 10+ years.
Things in the salt belt tend to corrode in place without anti seize, period. I have had NGK and Denso plated plugs stuck in there tighter than a bulls backside in a hurricane.
The reason they say this is for legal reasons ONLY, using anti seize effect torque and if misused can trigger a cat damaging misfire. Someone goes and buys plugs, lathers them up and torques to spec and strips the threads or ruins a cat due to getting anti seize on the firing end and sues the company.
