Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
21 registered members (4WD, bonjo, dieselguy67, CATERHAM, 2015Corolla, eljefino), 647 guests, and 24 spiders.
Topics293,636
Posts5,043,861
Members69,027
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
20W or 30W for long interstate drive ? #5134283 06/14/19 06:02 PM
ChrisD46 Offline OP
The '10 Elantra in my signature is going up I-95 to PA. and back end of June ... Oil cap says 5W20 but was considering a 5W30 synthetic for the summer long distance drive .
*I forget if a constant interstate drive is easier or harder on a vehicle in the summer - what would you use ?
'17 Hyundai Sonata 2.4L GDI 5W30 Valvoline Advanced Syn / Fram Ultra
'10 Hyundai Elantra 2.0L 5W30 QSUD / Fram Ultra
'07 Kia Sedona 3.8L 5W30 M1 EP HM / Fram Ultra
Re: 20W or 30W for long interstate drive ? [Re: ChrisD46] #5134295 06/14/19 06:10 PM
H
hallstevenson Offline
H
Use 5W-20 like it wants. Highway driving is a piece of cake for a car. Nothing special needed.
Re: 20W or 30W for long interstate drive ? [Re: ChrisD46] #5134303 06/14/19 06:19 PM
T
tig1 Offline
T
Lets see. With about 490K using almost all M1 0-20 I have extensive mileage on long trips in my Fords. My 2007 Ford Fusion 2.3 has made 21 trips to Florida from Illinois. and 1 trip to Maine. My 2017 Ford Fusion 2.5 has 5 trips to Florida, I trip to Maine, and 1 trip to Colorado. If your engine calls for a 20 wt oil, use it with no worries.
2007 Ford Fusion 246,000 miles
M1 5-20HM
2017 Ford Fusion 75K
M1 0-20EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 20W or 30W for long interstate drive ? [Re: tig1] #5134358 06/14/19 07:37 PM
ChrisD46 Offline OP
*That's a lot of interstate trips ... Looks like the 20W synthetic did a good job for you !
Re: 20W or 30W for long interstate drive ? [Re: ChrisD46] #5134385 06/14/19 08:10 PM
B
benjy Offline
B
look in your owners manual!! girlfriends just purchased 18 optima with 2.4L has 5-20 on the cap as well but owners manual states 5-20, 5-30 or 10-30 SN or above. i dumped the 5-20 cheap semi-syn the car lot put in + went with 10-30 full-fake synthetic quaker state. direct injection is hard on oil + i see 7500 or 6 mo for normal driving in her owners manual. the 1/4 mpg you get from xxW20 is a waste especially if you keep your past 100 thou IMO
Re: 20W or 30W for long interstate drive ? [Re: ChrisD46] #5134419 06/14/19 08:54 PM
M
Mad_Hatter Offline
M
Don't quote me on this but I thought I once read it's a 10:1 ratio when it comes to engine wear and hwy miles v. stop n go city miles.
That said, I just switched over to 10w30 the other day. My manual allows for 5w20/30 and 10/30 with the low starting temp being the lone caveat. But since it's summer here, that's not a concern. I know I'll take a slight hit on the mpg using the heavier oil but like the previous poster said, it's a trade-off for better wear protection for the long summer road trips (at least that's my thought process, right or wrong)
I'm sure someone will say a quality 5w30 would do just fine as well, and they're likely right, but it's just what I want to do and I'm ok with it.
Re: 20W or 30W for long interstate drive ? [Re: Mad_Hatter] #5134421 06/14/19 08:59 PM
JohnnyJohnson Offline
That said, I just switched over to 10w30 the other day. My manual allows for 5w20/30 and 10/30 with the low starting temp being the lone caveat. But since it's summer here, that's not a concern. I know I'll take a slight hit on the mpg but like the previous poster said, it's a trade-off for better wear protection (at least that's my thought process, right or wrong)
My 2004 Corolla summer OCI is Havoline Pro DS 10w-30 MPG hit ZERO! So far I haven't noticed any change.
2004 Corolla 134866
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 76356
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 20W or 30W for long interstate drive ? [Re: ChrisD46] #5134424 06/14/19 09:02 PM
dave1251 Offline
That is such easy duty for a engine I would not worry about the grade of the oil.
don't use.
Re: 20W or 30W for long interstate drive ? [Re: ChrisD46] #5134426 06/14/19 09:03 PM
B
Brojo Offline
B
Whatever makes you sleep better at night. I have liked PP 5w30 in our Kia GDI, it’s hardly thicker than some 20 weights. But like tig1, there are tons of folks who use 20w with great results. In GA, you could even go 10w30 no problem if you want
Just go with your gut and pick your favorite brand that is dexos licensed
Re: 20W or 30W for long interstate drive ? [Re: JohnnyJohnson] #5134429 06/14/19 09:05 PM
M
Mad_Hatter Offline
M
That's the sweet spot, no? 👍
And this will be the first summer that I'm going to actually track that/put the theory to test. I suppose it boils down to each person's driving style, actual speeds driven blah blah blah. as to whether or not they see a noticable hit to mpgs. But gas prices around here are typically at their lowest in the summer months so I don't expect a huge hit to the pocket book, if any.
Re: 20W or 30W for long interstate drive ? [Re: dave1251] #5134435 06/14/19 09:10 PM
CR94 Offline
Besides, I-95 is generally less hilly than other long Interstates in the East.
2011 Toyota Prius now at 102K
Re: 20W or 30W for long interstate drive ? [Re: ChrisD46] #5134446 06/14/19 09:26 PM
Dave9 Offline
The best choice would be an oil change right before the trip to 5W30, but only if you switch back to 5W20 before winter, and the difference isn't worth the bother of changing the oil again that soon unless the mileage dictates it.
Interstate/hwy miles are much easier (if driving sanely not in the high rev range) and yet, it's an extended period at full temperature on a ~9 yr old vehicle.
Re: 20W or 30W for long interstate drive ? [Re: hallstevenson] #5134457 06/14/19 09:42 PM
B
bbhero Offline
B
I agree ^^^^^
Just watch out for the numerous state troopers in NC and Va...
And if you go up 295 around Richmond Va do not speed over 79 mph near or in Hopewell... The city of Hopewell police are out there like gangbusters... During daylight hours... It is near exit 9 through the Appomattox river bridge when heading northbound if coming up from the southward direction. And from the north coming back towards the south the Hopewell city police massive presence starts has soon as you cross the Appomattox river bridge.... They sit right in the median as soon as you cross that bridge heading south bound 295 into Hopewell.
Nissan Altima 3.5 Coupe
Cam2 Dexos1 Gen 2 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: 20W or 30W for long interstate drive ? [Re: tig1] #5134479 06/14/19 10:09 PM
A
AlienBug Offline
A
Funny enough I’m road tripping to Florida in my 2011 Fusion 2.5 SEL next week. An 1,100 mile speed run, six days on the beach, then return trip.
I installed Mobil 1 AFE yesterday.
Some folks say 1 mpg isn’t a good enough reason to run a 20wt. I look at it the other way. Since my engine will run happily for as long as I care to own it on 0w20, why wouldn’t I take the extra 1mpg?
Don
2005 Ford Freestyle SEL, 158k, Motorcraft 5w20 synblend, Motorcraft filter
2007 Ford Fusion SE 2.3l, 125k, Mobil 1 EP 0w20, Motorcraft filter
Re: 20W or 30W for long interstate drive ? [Re: AlienBug] #5134483 06/14/19 10:13 PM
demarpaint Offline
An extra 1 mpg? Interesting, I switched two vehicles from "20wt" to 30wt and have been unable to calculate any difference in mpg.
God Bless Our Troops
Page 1 of 3 1 2 3
