Just had the dealer do the "drop pan, adjust bands, replace filter, replace pan gasket [with neoprene piece]" on the 727-based 46RE in my 2001 DODGE Ram (V8-318, 3.55's, 2WD; 5,080#) at 92k.
Added the requisite ATF+4 [4-quarts], and I added the correct amount of ARX for a 2000-mile cleanout. At the end of the period I will replace the current fluid with SCHAEFFERS 204-Supreme, a MAGNEFINE magnetic auxiliary filter, and look into the labor cost of a few mods already well-researched.
Bought a few months back, I've put about 8k on the truck. The fluid didn't look or smell too bad (can't tell as easily as years ago, but a calibrated nose is helpful). This trans is strained with a small-block, 0.69 ratio OD, emissions-calibration shifting and a few problems not well-sorted by factory. I've a ways to go in achieving complete prophylactic maintenance & upgrades, but starting with the dealer was easy. (What hurt was the having the fuel pump/filter/regulator replaced for $800; but, then, the use of FUEL POWER -- I am a little more than half-convinced -- allowed me to choose the time when to do it as that booger whined for the whole 8k I've had it).
Cost for trans service? About $100 plus a few bucks. Glad to have the bands adjusted according to spec, the dealer to look it over (I've a good relationship with an outstanding service writer), and I've some piece of mind.
I'll do the rest, and from here on will do annual pan drop/adjustment at dealer or an independent, and will change fluid myself after annual/25k ARX clean-up. (It also duplicates the set-up on our 2001 JEEP Cherokee [L6-242, AW-4] and makes for ease of service on both).
A few bucks out of my pocket doesn't hurt so much with trusted techs/service department . . especially as I learned many years ago how to do all of this myself, but failing health prevents me from "doing it all".
Just find a good shop, buy/study the factory service manual, and use the Internet wisely to spend appropiate to your long-term cost of ownership. Sorta hard to do too much.
[ March 11, 2005, 11:45 PM: Message edited by: TheTanSedan ]
