Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
111 registered members (apollo18, Anduril, 2012AccentSE, ABomb369, avi1777, 750IX, 8 invisible), 2,212 guests, and 22 spiders.
Topics301,698
Posts5,200,833
Members70,759
Page 2 of 4 1 2 3 4
Re: METALSLUG First ever oil filter cut open FL820s [Re: addyguy] #5133012 06/13/19 08:10 AM
K
kschachn Online Content
Online Content
K
Originally Posted by addyguy
Whatever engine this is on is having serious problems - can has a lot of sludge in it, and the filter is full of metal flakes.
I'd worry about the engine this came off, not so much the filter.
One might wonder if those flakes are a result of cutting open the can.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: METALSLUG First ever oil filter cut open FL820s [Re: MetalSlug] #5133014 06/13/19 08:11 AM
T
tig1 Offline
T
I use other MC filters like the FL 910S and the 2017B cartridge and they are outstanding, but there is no way I would use the 820. Dude, be realistic.
2007 Ford Fusion 253,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: METALSLUG First ever oil filter cut open FL820s [Re: addyguy] #5133024 06/13/19 08:24 AM
M
MetalSlug Offline OP
M
metal flake are from the saw my friend use it to cut the fiter. about the sludge im not sure.
Re: METALSLUG First ever oil filter cut open FL820s [Re: kschachn] #5133026 06/13/19 08:26 AM
M
M
Originally Posted by kschachn
Originally Posted by MetalSlug
Enjoy guys I’m going drink beer.
Maybe it's time to reconsider your sig line of "NO FRAM OCOD " Orange Can Of DEATH"
wink
not a chance, im stick to that until fram add metal end cap to the OCOD filter.
Look at my stash, i have 2 ultra . I do use ultra, but i lost interest on ultra after all. im thinking wix line from now.
Re: METALSLUG First ever oil filter cut open FL820s [Re: Farnsworth] #5133031 06/13/19 08:30 AM
M
M
Originally Posted by Farnsworth
Manufacturing defect again like on so many brands. Reading your description it seems the hole first seen was at the seam, and the wide pleat was NOT torn until you pressed it with finger, correct? Some seams do have gap but there should be glue inside, check up to a light for a hole. I have pressed with finger a number of brands pleats and they tore, Baldwin for one which has sort of a soft thick media. Not excusing this one.
You have a 600 hp Mustang driving in Texas? How about the Ford Racing filter? From what I see here it is the best thing going for an engine like you have.
I do want give Ford racing FL820s a try. but for $20+ dollar oil filter... I think a wix xp or napa platium are better
I read other say about purolator BOSS, having some kind of issue about ADBV.... is that serious ? something need to be avoid ? after discount code at advance turn out to be under $11 everday price.
Re: METALSLUG First ever oil filter cut open FL820s [Re: MetalSlug] #5133038 06/13/19 08:36 AM
K
Online Content
K
And yet it is the metal end cap filters that are tearing. Honestly I'm over them, none of my cars use a filter with a metal end cap (most have none) and I've come to believe that's a good thing from what I've seen on here.
1994 BMW 530i, 251K
Re: METALSLUG First ever oil filter cut open FL820s [Re: MetalSlug] #5133058 06/13/19 09:16 AM
SlavaB Offline
You lost an interest for ultra why?
It doesn’t make much sense, you’re saying I’m not interested in an efficient filter yet I’m looking into using wix do/Napa platinum which is a decent one yet not even close to ultra efficiency-wise
17 Kia Sportage EX 2.4 GDI / Castrol Magnatec 5w30, OEM filter
15 MB GLA250 4Matic 2.0T / Mercedes OEM 5w40, OEM filter
Re: METALSLUG First ever oil filter cut open FL820s [Re: MetalSlug] #5133124 06/13/19 10:46 AM
JohnnyJohnson Online Content
Online Content
The Boss 99% efficiency at 40 microns. You get 99% plus efficiency from a TG at six dollars and change.
2004 Corolla 138781
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: METALSLUG First ever oil filter cut open FL820s [Re: MetalSlug] #5133193 06/13/19 12:07 PM
Z
ZeeOSix Offline
Z
might be nothing new to you all, but its a big new for me.
Nothing like seeing it with your own eyes to make it real.
Re: METALSLUG First ever oil filter cut open FL820s [Re: MetalSlug] #5133209 06/13/19 12:25 PM
A
aquariuscsm Offline
A
Could tearing of the media be a result of handling the oil soaked media while and after cutting them open?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: METALSLUG First ever oil filter cut open FL820s [Re: aquariuscsm] #5133234 06/13/19 12:53 PM
Z
ZeeOSix Offline
Z
Read what he said about finding a hole, shown in the 4th photo, way down in the pleat seam. Sounds like he started pushing pleats around after that, and found that the media was weak and could tear easily.
So where did that blown out piece of media go? Inside the oiling system of course.
Re: METALSLUG First ever oil filter cut open FL820s [Re: MetalSlug] #5133408 06/13/19 04:23 PM
BlueOvalFitter Offline
Any one want to guess how it turn out ? Tear or no tear ?
I bet it will be torn. I mean, we have to keep the streak going here, on EVERY FL-820S is GUARANTEED to be torn......"WINK, WINK" smirk
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: METALSLUG First ever oil filter cut open FL820s [Re: MetalSlug] #5133503 06/13/19 06:11 PM
F
Farnsworth Offline
F
It's a tough one but MC filters do have the bypass on the correct end for Ford. The Boss, on some versions, have cuts in the adbv from the baseplate holes. The rubber is pressed into the base so there shouldn't be any leaking. Still not visually OK.
Since the filter didn't tear you may want to keep on using these if price is important. I'm no expert like some, but that's what I would do, and send MC pictures with an email asking them for advice.They are a bargain oil filter. Where is the hole? I saw the white spot and thought that was some debris. Good luck with finding oil filters. Wix and Fram also make racing filters.
Re: METALSLUG First ever oil filter cut open FL820s [Re: BlueOvalFitter] #5133507 06/13/19 06:16 PM
chubbie Offline
Well I ain't no rocket doctor or a brain scientists however looking in the can there is evidence of grime dirt ect. I wouldn't be to worried because if it was clean that crap would have worked it's way into the engine which obviously is bad.Although I would live and learn don't use this filter again like a dog going back to eat his vomit.
07 Dodge Ram 151K shell rotella gas truck 5w-30
18 Mazda cx5 61K pennz syn 0w-20
Re: METALSLUG First ever oil filter cut open FL820s [Re: Farnsworth] #5133561 06/13/19 07:23 PM
Z
ZeeOSix Offline
Z
Motorcraft/Ford won't respond. Others here tried contacting them before when they found torn MC filters, and all that was heard back was chirping crickets.
Page 2 of 4 1 2 3 4
