Originally Posted by Astro14
You've got carbon on the threads. Don't just crank this out, soak it, tighten it back up, and loosen again. You're breaking up the carbon and allowing it to work loose. If it gets hard to turn while removing again, just run it back in a turn or two, then continue to loosen.
By the way, WD-40 is a terrible penetrant for this purpose. Try Liquid Wrench (easily found) or Kroil (absolute best of all of them). They'll work much better.
This. Tap the spark plug wrench in both directions. When it feels like it has broken free, continue to work the wrench in both directions,more travel each time. Add more penetrant after it breaks free, and as you go along.
Use antiseize on the new ones.
