WD-40 is too weak for this.
One method nobody seems to have ever heard of is mixing them all, equal parts. Liquid Wrench and the Kroil, could leave the WD-40 out. Or straight up Acetone mixed with some auto trans fluid. Either the equal-part blends of everything or the acetone and auto trans fluid are much much much better options on penetrating liquid. You are on a head on a car with porcelain etc so while heat would help this, warmed up engine vs cold .. you probably are not advised to put heat to it. No, do not do that.
Then again, I have seen people REMOVE spark plugs with an Impact, usually a 3/8" . It is a clean break, so, while totally within your rights to not do, this could solve that problem also. Does this last spark plug look straight up and down, like the others? Or to one side, a sign of cross thread
