Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
19 registered members (bonjo, dieselguy67, CATERHAM, 2015Corolla, 4WD, Duke, 1 invisible), 604 guests, and 25 spiders.
Topics293,636
Posts5,043,858
Members69,027
Most Online3,532
Jul 30th, 2019
Used Jeep Rubicon - Fluids? #5133045 06/13/19 09:44 AM
G
Greg L Offline OP
G
My son just purchased a used 2012 Jeep Rubicon with V6, from a dealer. It has 85k miles on it and he is now the second owner.
Neither he or I are familiar with this model, or the V-6 engine. I assume it is the 'PentaStar' people have talked about on this forum?
Questions from my son: What is suggested oil for this motor? Should he use High Mileage? And suggestions for filter?
Also, any recommendations on tranny fluid and rear differential oil? And, does it require seperate fluid for the transfer case?
Any comments/ help would be appreciated I will pass it along to him. (He lives out of state). Thank you in advance.
GL
1951 GMC 1/2 Ton 270ci
2008 Jeep Compass 2.4
2010 Toyota Prius 1.8
2011 Dodge Ram 1500, 5.7 Hemi
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133055 06/13/19 10:12 AM
J
JLTD Offline
J
2012 should be the 2nd year for the Pentastar, and it is specified 5w-30.
No high mileage oil required. Fram Ultra is available for the 2012. I would pick a solid synthetic and run with it.
Automatic or manual transmission?
Lots of his questions (especially tc fluid) can be answered by reading the Owner's Manual....
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, SS 5w20/Amsoil
Re: Used Jeep Rubicon - Fluids? [Re: JLTD] #5133061 06/13/19 10:21 AM
G
Greg L Offline OP
G
Thanks, I'll let him know.
He doesn't spend time on forums, or have a computer at home. Just a smartphone he uses for music and an occasional Facebook post.
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133074 06/13/19 10:43 AM
A
atikovi Offline
A
Mobil 1 5W20 or 5W30 at Walmart on sale is the best deal. Mopar oil filters from the dealer or online for $5.
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133152 06/13/19 12:21 PM
J
Jimmy_Russells Offline
J
If it's an automatic it will use ATF+4, which are basically all the same. The transfer case also uses this. Any name brand, or Mopar, is fine. Engine oil is spec'd as 5w30 that meets Chrysler MS-6395 specification, which is very easy to find. Diffs use standard 80w90 gear oil.
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133224 06/13/19 01:43 PM
Sunnyinhollister Offline
The rear diff uses 75W-140 when towing. Otherwise 80W-90 or 75W-90 will do.
2017 Ram 1500 Regular Cab 4x2 5.7L 8spd
2017 Chevy Bolt
2018 Jeep Cherokee Trailhawk
2004 Toyota Highlander AWD
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133257 06/13/19 02:28 PM
Danno Offline
If it was my Wrangler, I would use Pennzoil Yellow Bottle 5W-30 conventional and an OEM Chrysler/Jeep oil filter.
Its a very good oil, meets the Chrysler spec, and can be had for a great price.
OEM filter just because they give me piece of mind vs. aftermarket. My opinion of course.
Not knowing his drive cycle or geography, start at 5,000 mile oil change intervals.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133279 06/13/19 03:03 PM
sloinker Offline
My 2014 Pentastar spec's 5W20 MS-6395. I like the Valvoline product line in conventional for this engine. Mopar filters. Cheapest ATF4 and again Mopar filter. This engine is known to develop leaks on the filter adapter, don't over tighten the plastic. Keep your eyes peeled for leaks, coolant and oil both reside in the adapter body. The oil pressure sender for the idiot light is also on this assembly and is a known problem. If your idiot light and scan show low oil pressure this is the fix. Be careful on which coolant you use. It is either 100k pink or 150k purple and they can't be mixed.
'16 Tiguan TSI Ravenol VST 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133302 06/13/19 03:30 PM
CrAlt Offline
I use pennzoil yellow bottle in my wrangler's pentastar and mopar filter every 5K.
pennzoil syncromesh in the NSG 370 manual 6speed. IIRC the manual says every 30K. (If it was an auto I would use Supertech ATF+4 and change per the manual schedule)
Supertech ATF+4 in the TC
SuperTech 80w90 in the diffs.
The diffs are real easy to change because they have drainplugs.
If he is missing the manual he can go to the mopar.com website and download a full copy.
'16 Wrangler FormulaShell 5w20 / MO 349
'77 Corvette VR1 10w30 / WIX51061
'83 Trans-Am VR1 10w30 / WIX51061
'91 Dodge D150 FormulaShell 10w40 / WIX51515
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133359 06/13/19 04:27 PM
G
Greg L Offline OP
G
Thanks for the responses, I will let him know.
I don't think he has a manual for it.
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133362 06/13/19 04:30 PM
E
Env1ous Offline
E
https://justgivemethedamnmanual.com/jeep/2012-jeep-wrangler-owners-manual/
Just for you!
Re: Used Jeep Rubicon - Fluids? [Re: Greg L] #5133385 06/13/19 04:53 PM
G
Greg L Offline OP
G
Thank you!
