WiFi “bridge” to outbuilding
by dlundblad - 08/20/19 05:00 AM
SynLube
by sloinker - 08/20/19 04:55 AM
Rental review : 2019 Dodge Charger
by FirstNissan - 08/20/19 12:14 AM
Truck diesel oil in Lawn mower (SAE30)
by Polyalphaolefin - 08/19/19 11:18 PM
Pinstripes Not Popular on Pickup Trucks?
by LoneRanger - 08/19/19 10:04 PM
More choices
by KeithS_NW_Ohio - 08/19/19 09:43 PM
INEOS to Surpass EXOM in PAO production.
by MolaKule - 08/19/19 09:17 PM
Need a miter saw
by JLawrence08648 - 08/19/19 09:01 PM
Using a 7.1 receiver with only 2 speakers
by Papa Bear - 08/19/19 08:44 PM
HD Sportster 5000 mi Red line PS 20w-50
by shanneba - 08/19/19 07:17 PM
College Football Time
by kstanf150 - 08/19/19 07:17 PM
Eco Plug oil drain plug
by passgas55 - 08/19/19 07:15 PM
Pep Boys Deals
by kstanf150 - 08/19/19 06:43 PM
MB229.5 and MB229.51
by Tikka - 08/19/19 06:35 PM
2019 Mazda 3 Recall....Wheels fall Off!
by Boomer - 08/19/19 05:43 PM
Rut Roh!😂
by Mad_Hatter - 08/19/19 04:40 PM
Oil for vintage Mopars
by 440Magnum - 08/19/19 04:37 PM
M1-102 vs M1-103
by Deontologist - 08/19/19 04:06 PM
Why no love for M1 gear oils?
by zuluplus30 - 08/19/19 03:02 PM
Brandon86, smartd_e, serhat, BlueSky, 444samc
69000 Registered Users
59 registered members (billt460, 08z06, Bighorn2500, 87sammy, Bailes1992, 6 invisible), 791 guests, and 20 spiders.
Topics293,548
Posts5,042,127
Members69,000
Most Online3,532
Jul 30th, 2019
My 09 Suburban Needs A Body Control Module #5132748 06/12/19 10:36 PM
N
NYEngineer Offline OP
N
Great... Huge single point of failure. My brother knows a guy that comes to you and programs them but he doesn't sell them. Any suggestions? Dealer?
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5132764 06/12/19 10:52 PM
clinebarger Offline
Dealer.....i would have it flashed/configured by the same dealer as well. GM will not warrant one configured by a 3rd party.
In general.....Most BCM failures are from Cold/Cracked solder joints.
2001 Chevy Camaro L92/4L80E
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5132891 06/13/19 06:31 AM
L
LazyDog Offline
L
You can just pull it out and sent to have the solder joints fixed. No need to reprogram since it is the original. banana
Re: My 09 Suburban Needs A Body Control Module [Re: LazyDog] #5132898 06/13/19 06:40 AM
Astro14 Offline
Yep.
I’ve done this with many Volvo modules. Worked great. I used these guys: https://xemodex.com/us/
They fix the module (solder joints, bulbs, power supply, transistors, whatever) and ship it back. They have express shipping. They are an example of a module repair company. Don’t know if they’ve got the service for your exact module, but...
I’m willing to bet that there is a whole trade industry fixing GM modules. Google. Surf the Chevy forums.
Barring that, get the dealer to do it. A new (or used) module that isn’t original to your car will need to be reprogrammed. For that, you’ll want full - up dealer software and a warranty.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5132932 06/13/19 07:27 AM
DoubleWasp Offline
I've pulled them and resoldered the joints. It's not hard if you have enough skill to get it out.
Re: My 09 Suburban Needs A Body Control Module [Re: DoubleWasp] #5132935 06/13/19 07:36 AM
Astro14 Offline
I’ve got the skill to get it out, but I’m no good at soldering...
And if the problem is more complex than soldering (e.g. transistor or power supply failure) then I’m way over my head.
This is something that I would farm out, personally...
32 Packard 15W40
05 MB S600 0W40 M1
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133029 06/13/19 09:29 AM
Chris Meutsch Offline
2005 Honda CR-V EX, 275k
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133030 06/13/19 09:30 AM
DoubleWasp Offline
You need none at all. You're not even soldering. You're just reflowing. Touch the tip to the old solder until it turns fluid. Lift tip off. Repeat for other solder points. Done.
I did my last one sitting on a box in my garage while falling asleep.
When my friend had the same problem with his other truck, his 10 year old son duplicated my work. If you can use a razor and write your name with a pen, you're good to go.
Don't worry about what might be wrong. It's a 45 minute job. If it doesn't work, then toss that thing off. But that's just my perspective. I haven't encountered one that was anything more than the solder yet.
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133046 06/13/19 09:48 AM
A
andyd Offline
A
The power transistor on the 535i ECU would break solder joints. I watched Peter Florrance revive 2 out of 3 with a soldering iron. The 3rd smelled fried. At the time a new ECU was 1500$. I described the operation to a noob on the board and he fixed his.. You can see a broken solder joint. There is a black ring just below the top of the blob.It is carbon from arcing. grin2
Thick oil is better grin2
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133115 06/13/19 11:33 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
I have the benefit of a stereomicroscope available to me. Instead of reflowing dozens of good solder joints, I'll inspect the unit and find the broken and iffy solder joints.
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133347 06/13/19 04:15 PM
DoubleWasp Offline
The GM BCM doesn't have many. Might have been ten.
I always reflow all of them. If I have the unit open and my iron in front of me, do I really want to put it back together with the rest of the time bombs still ticking?
If one poorly done joint did the unit in, what reasonable assumption can one make about the rest of the joints?
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133635 06/13/19 09:30 PM
N
N
Awesome. I'll pop it out tomorrow and have a look at it. This place is the best.
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133954 06/14/19 10:01 AM
M
meep Offline
M
@ NYE - if you don't have an iron, pick up a 30 watt iron and some solder. Get the iron hot and moisten the tip with solder. if it doesn't adhere, scuff it lightly and try again. Keep a moist sponge or rag nearby to clean the tip.
As D'Wasp said, just reflow - but having your own spool will help if the tip gets dry, tacky, or you find a joint that is too dry.
@ Astro14 - I've read your posts. You can do this. Pick up an iron and some solder and practice on scrap 14 to 24 gauge wire and you'll get the feel for it.
2018 F150
2015 crv (wifey!)
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5134023 06/14/19 12:29 PM
N
N
Meep... Thanks. I've got plenty of experience making emergency field repairs to printed circuit boards. I'm all set. I've got the perfect iron for this job. I'm excited to do it. I may try and do it as soon as I get home from work today.
I'll post back and let everyone know how it goes.
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5134287 06/14/19 06:04 PM
N
N
Ok... I am a peepee. I got the BCM out of my truck pretty easily and got it open slightly less easily. I inspected it and realized I needed a magnifying glass so I went and got one at Ace. Still found NOTHING. I reassembled it and put it back in. Everything works the same.
I'm going to order a new one on Monday.
I just fixed the board in a VFD last week at work. After watching a few youtube videos I figured I had this in the bag.
