Door hinge pins and bushings
by P10crew - 11/19/19 08:22 PM
future new car prices-gas vs electric
by 1978elcamino - 11/19/19 07:51 PM
Briggs/ Walbro idle tuning
by eljefino - 11/19/19 07:46 PM
Shell Rotella Gas Truck 0W-20, 9349 miles FCA 2.4
by austinlunsford - 11/19/19 06:53 PM
06' V6 Accord 12,462 miles Penzoil Platinum 0W20
by Daschicken - 11/19/19 04:57 PM
Pride Asian Plus Coolant-thoughts?
by N Heat - 11/19/19 04:21 PM
Should it really take this long?
by IronMaidenRules - 11/19/19 02:21 PM
Does Ford use Hall Effect sensor for the APPS?
by LoneRanger - 11/19/19 02:09 PM
Brake Calipers for my 74 Corvette
by Alwyn678 - 11/19/19 01:32 PM
My Neighbor's 320,000 Mile Saturn
by CrackyWainwright - 11/19/19 01:14 PM
2012 GMC Terrain 3.0L V6 P0300
by benjamming - 11/19/19 12:51 PM
Mustang 4r70w atf recommendation
by Hansvoytek - 11/19/19 12:18 PM
PRO TEC PTL 57502 CUT OPEN
by 53' Stude - 11/19/19 12:08 PM
Federal rebates?
by buck91 - 11/19/19 12:07 PM
Bosch fuel pump quality
by drtyler - 11/19/19 11:28 AM
Standard Motor Products
by Whimsey - 11/19/19 11:25 AM
Cubez007, dshadow, Hansvoytek, DeltaP71, 300Kncounting
69918 Registered Users
114 registered members (2002 Maxima SE, 4WD, 92saturnsl2, 10ecfarmer, Aero540T, 97K15004WD, 8 invisible), 1,975 guests, and 18 spiders.
Topics297,650
Posts5,120,007
Members69,918
Most Online3,589
Nov 2nd, 2019
High Performance Lubricants BAS 5w-30 Racing Oil VOA #5132589 06/12/19 06:33 PM
RDY4WAR Offline OP
This is an oil that we are looking into for our race cars.
Does anyone know where 14 ppm of nickel would come from in a virgin oil sample? What about the vanadium and barium?
The base oil is a blend of 1-decene, homopolymer PAO and 1-decene, trimer PAO. The ZDDP is short-chained secondary type. The moly is all tri-nuclear.
Let me know what you think.
EDIT: The VOA seems difficult to read on here when loaded. Here's the data.
Iron: 0
Chromium: 1
Nickel: 14
Aluminum: 0
Copper: 3
Lead: 0
Tin: 0
Cadmium: 0
Silver: 0
Vanadium: 4
Silicon: 23
Sodium: 17
Potassium: 0
Titanium: 0
Molybdenum: 1747
Antimony: 0
Manganese: 0
Lithium: 0
Boron: 118
Magnesium: 4
Calcium: 2488
Barium: 8
Phosphorus: 790
Zinc: 947
KV100 = 10.2 cSt
TBN = 8.72
Oxidation = 11
Nitration = 5
This is a VIRGIN oil sample, not used. OAI screwed that up so ignore the comments.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5132597 06/12/19 06:42 PM
RDY4WAR Offline OP
The quart jug just in case someone's curious about the name.
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5132625 06/12/19 07:07 PM
J
JAG Offline
J
That dose of tri-nuclear moly is impressive. Is this oil for sale to the general public?
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: JAG] #5132763 06/12/19 09:51 PM
RDY4WAR Offline OP
I don't see why not, but I wouldn't know where to get it. If you were to contact HPL, I'm sure they'd be able to connect you with a retailer that might have it.
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5132777 06/12/19 10:11 PM
Marco620 Offline
Wow. Lots of molybdenum
15' Civic 1.8 i-vtec 288,000 mi Motul 0w30 & LG Biotech, BP CVT Fluid,Redline Si-1
Doberman Whisperer!
Honda,Doberman,CZ's & SONY Aficionado
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5132811 06/12/19 11:39 PM
R
rubberchicken Offline
R
Get it retested, maybe by a different lab, or take the same quart bottle and sent to 2 different labs. I am thinking either the oil you got is fubar, or the test was buggered up.
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5132812 06/12/19 11:42 PM
R
R
And what about silicon ? I think I would look elsewhere for an oil supplier.
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5132819 06/12/19 11:56 PM
Marco620 Offline
Why? Redline Oil has highish silicon at mid 10s. I think he should look into Redline or Klotz oils though.
Doberman Whisperer!
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5132876 06/13/19 04:55 AM
M
Mainia Offline
M
Oil Analyzers IS "Polaris Labs" and when they saw Nickel that high, I can almost say for sure it was retested as part of protocol. It doesn't matter ifit is VOA why the nickel and in a virgin oil for that matter.
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5132893 06/13/19 05:36 AM
B
Bailes1992 Offline
B
I always thought that anything more than 100ppm of Moly was a waste?
I too would give that a miss.
So many other off the shelf oils I would pick over that.
19 Volvo V40 D3 Auto - 96 Defender 300TDi - 03 Ford Mondeo ST 3.0 V6
Engine - Castrol Edge 5w30 LL
Manual - Fuchs Sintofluid 75w80
ATF - Comma MVATF
Diff & Transfer - Fuchs Sintopoid 75w90
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5132959 06/13/19 07:00 AM
RDY4WAR Offline OP
The silicon is for anti-foaming. I'm not worried about that. I actually want that there.
More than 100 ppm of moly may not show any gains for a daily commuter cruising along at 2000 rpm. The engine this oil is going in is a big block V8 making 1300+ horsepower at 9000 rpm in a highly competitive racing class. We'll take any edge we can get. The margin of victories often come down to thousandths of a second.
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: Bailes1992] #5132999 06/13/19 07:53 AM
SubieRubyRoo Offline
I'm pretty sure I remember reading in a research paper posted on here a while back that moly really doesn't start to show real friction reduction benefits until it is OVER 200 ppm. There were a couple other "benefits" to higher moly... as long as the base oil will keep it in suspension.
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5133299 06/13/19 02:25 PM
RDY4WAR Offline OP
The formulator got back to me about the 14 ppm of nickel. He said it's just a catalyst leftover from the production of the additive package and not something to worry about. Same for the vanadium. He also noted that the TAN for the sample they've run is 1.46.
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: RDY4WAR] #5133335 06/13/19 03:06 PM
53' Stude Offline
May I ask where you purchased this oil? My dad is interested in this for his 56' Chevy gasser
Thank You
Re: High Performance Lubricants BAS 5w-30 Racing Oil [Re: 53' Stude] #5133370 06/13/19 03:41 PM
RDY4WAR Offline OP
Thank You
This oil was gifted to me to try it out. I'll find out where it can purchased.
