Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
44 registered members (53' Stude, bernau, BlueOvalFitter, AndyB, Bighorn2500, 9 invisible), 653 guests, and 19 spiders.
Topics290,259
Posts4,987,229
Members68,412
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Robertson Screwdrivers [Re: ecotourist] #5130648
06/10/19 06:58 PM
06/10/19 06:58 PM
SE Alabama
Fawteen Offline
Fawteen  Offline
SE Alabama
They're very common in the US. You can go into any hardware store or big box (Lowes, HomeDepot, etc.) and buy them. I have a dozen or so packages out in the garage (along with phillips, standard and torx).
Re: Robertson Screwdrivers [Re: maxdustington] #5130660
06/10/19 07:06 PM
06/10/19 07:06 PM
British Columbia, Canada
ecotourist Offline OP
Originally Posted by maxdustington
Originally Posted by ecotourist
They just work better during assembly and even more so on disassembly. The screwdriver needs very little forward pressure to stay fully engaged and for the most part just doesn't slip.
They work well in all sizes, and it's fairly easy to insert a Robertson screw with one hand when used vertically and even to a certain extent when used horizontally (as the screw balances readily on the screwdriver).
With a small screw and brand new bit, sure. Bulk box 3 1/2" construction screws and a bit that's seen 100+ screws? Not without a magnetizer or magnetic bit holder.
As I understand it they are tapered and this is supposed to hold the screw on a bit, but a little bit of wear fixes that right up. I think they do hold a bit better than a Phillips even when worn but it's not night and day.
No one makes a decent Robertson screwdriver outside of Canada other than Klein. I think electricians in the US use Robertson, too.
My Robertson screwdrivers have seen many Robertson screws and they're still fine - even the cheap ones. My Robertson driver bits do get chewed up eventually and I just replace them. They may not be made with as good a material as the screwdrivers or maybe the torque is just so high. I can't compare Robertson driver bit life to other designs as I use the others so infrequently.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Robertson Screwdrivers [Re: ecotourist] #5130707
06/10/19 07:39 PM
06/10/19 07:39 PM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
RVs seem to use quadrex screws, which fit a Phillips or Roberson head [Linked Image]
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: Robertson Screwdrivers [Re: ecotourist] #5130830
06/10/19 09:18 PM
06/10/19 09:18 PM
UT
BHopkins Offline
BHopkins  Offline
UT
I've used a lot of Robertson screws. They are good. But I would not say that Robertson is superior to Phillips in every way. They both have their pros and cons.
Robertson bits are much less prone to slipping out than Phillips. But Phillips bits are much more durable. I have never broke off a Phillips bit. But I have broke off a lot a Robertson bits. And when they break off, the portion still in the drill makes a BIG mess of woodwork. Phillips bits do wear out faster than Roberston bits. But Robertson bits do wear out also.
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
Re: Robertson Screwdrivers [Re: hallstevenson] #5131075
06/11/19 06:59 AM
06/11/19 06:59 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Its great for the fat folks, they can say 158 instead of 350.
Re: Robertson Screwdrivers [Re: Onetor] #5131271
06/11/19 10:57 AM
06/11/19 10:57 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Originally Posted by Onetor
I wish the USA would go metric...
And yet, we navigate by nautical miles. 360 degrees in a circle, 60 minutes per degree and 60 seconds per minute. One second being 1 Nautical Mile.
Therefore, one degree of Lattitude is 60 Nautical Miles.
Conversely, one Nautical Mile is 1852 meters......
Which one makes more sense again????
Re: Robertson Screwdrivers [Re: ecotourist] #5131611
06/11/19 06:00 PM
06/11/19 06:00 PM
MD
ET16 Offline
ET16  Offline
MD
I was in Toronto over the weekend and used some Robertsons. I think they're great.
Re: Robertson Screwdrivers [Re: BHopkins] #5132829
06/13/19 01:14 AM
06/13/19 01:14 AM
Vancouver, Canada
dk1604 Offline
dk1604  Offline
Vancouver, Canada
The main problem with Phillips is the existence of Pozidriv. When you're trying to figure out why your Philips screwdrivers keep chewing up the screw heads on the Ikea furniture you're trying to assemble, it's because it's Pozidriv :-)
And then there's JIS B 1012...
Re: Robertson Screwdrivers [Re: ecotourist] #5134920
06/15/19 01:00 PM
06/15/19 01:00 PM
Montague, NJ
repairman54 Offline
repairman54  Offline
Montague, NJ
My cargo trailer uses double Robertson on the exterior skin. Initial glance it looks like a Torx but it's actually a double Robertson but a single Robertson bit will fit in them.
John
Anything you say can & will be misquoted & used against you
'16 Equinox 3.6 AWD
'11 Tahoe LTZ
'09 2.4 Malibu
FLHR
Doo 1200 GSX
Sea Doo GSX
Re: Robertson Screwdrivers [Re: ecotourist] #5135261
06/15/19 08:52 PM
06/15/19 08:52 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
The best is the Robertson flat head combo screws found on electrical equipment. Milwaukee makes a bit that fits them perfectly.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Page 2 of 2 1 2
