Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
41 registered members (Best F100, 53' Stude, bernau, 11 invisible), 735 guests, and 22 spiders.
Topics290,259
Posts4,987,237
Members68,413
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Mr4btTahoe] #5132766
06/12/19 10:55 PM
06/12/19 10:55 PM
SC
BillyE Offline
BillyE  Offline
SC
Originally Posted by Mr4btTahoe
I don't think that's coincidental.
The anecdotal evidence you’ve seen lined up with what Ford saw when they decided to ditch CK-4 in favor of their own F1 spec. Interestingly, DELO is an oil that failed to make the cut. It has lower zinc/phosphorus than almost every other HDEO.
I think you’ve got a lot of choices to consider. First, you can switch to any oil on the F1 list. Another option might be to use a break-in additive for extra ZDDP. Another is the Amsoil option but that sounds very expensive. I think I’d personally just try an oil off the F1 list and see how it goes.
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Mr4btTahoe] #5132798
06/13/19 12:02 AM
06/13/19 12:02 AM
Southeast
BlakeB Offline
BlakeB  Offline
Southeast
I believe Chevron still makes their CJ-4 Delo 400 LE 15w40. If you have a Chevron distributor near you I would check with them.
Another possible temporary solution might be WM SuperTech 15w40 individual quarts. While the bigger containers are all CK-4 at my local store, the individual quarts are (at least the last time I checked) still CJ-4.
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Mr4btTahoe] #5132971
06/13/19 08:14 AM
06/13/19 08:14 AM
In the shop
53' Stude Online content
53' Stude  Online Content
In the shop
Check out Rural King as they still have 10w30 HDEO cj4/sm and 15w40 thats cj4 rated
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Mr4btTahoe] #5133122
06/13/19 11:43 AM
06/13/19 11:43 AM
Indiana
njohnson Offline
njohnson  Offline
Indiana
Chevron has really reduced the zinc on the Delo CK-4 oils.
Maybe other oils with higher zinc levels will help in your situation.
Rural King sells Delvac 1 ESP 5W-40 and the TDT 5W-40 for around 22 dollars a gallon. They still have the zinc levels above 1200 ppm for now. Mobil may change that in future, but, as of right now, the CK-4 versions are still above 1200 zinc. This is what we are using in older diesel equipment.
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Mr4btTahoe] #5133125
06/13/19 11:48 AM
06/13/19 11:48 AM
Indiana
njohnson Offline
njohnson  Offline
Indiana
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Mr4btTahoe] #5133177
06/13/19 12:46 PM
06/13/19 12:46 PM
Southern Indiana
Mr4btTahoe Offline OP
Southern Indiana
Currently, it has Delo 400 XLE 15w40 in the case. We're gonna let it ride for a month or two and pull a sample. Planning on switching over to Mystik JT-8 at that point as we can get it locally for a decent price (and meets the F1 standard)
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Mr4btTahoe] #5133264
06/13/19 02:46 PM
06/13/19 02:46 PM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Huh,,,, maybe Ford was on to something when they first announced wear issues with new CK-4 oils.... everyone was so quick to jump on the BS bandwagon and not realize there might have been some actual facts backing their initial stance! I'll side with the team of multi-million dollar engineers from ford over guys on BITOG any day, no offense fellas wink
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: racin4ds] #5133434
06/13/19 05:43 PM
06/13/19 05:43 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
Or there is a coolant leak that is slowly destroying the bearings, crankshaft, and other moving parts.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & MB (Purflux) filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum Euro 0W-40 & Mann filter]
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: racin4ds] #5134602
06/15/19 04:34 AM
06/15/19 04:34 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
The oils were designed by engineers, not ordinary BITOGers. Also, Ford has a panic over diesel specs ever few years. It's just something they seem to like to do. They did it recently. They did it around 1998. They did it around 1984. So, about every 15 years or so, Ford essentially goes on a big marketing campaign to sell Motorcraft oil.
To the OP, Dave Newton made good suggestions. The 15w-40 should be fine, too.
Plain, simple Garak.
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Garak] #5134650
06/15/19 06:55 AM
06/15/19 06:55 AM
SC
BillyE Offline
BillyE  Offline
SC
How do you think this is a marketing campaign to sell motorcraft oil? They have a list of hundreds of competitors that meet spec. About the only thing that doesn’t meet spec is Delo.
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: BillyE] #5134654
06/15/19 07:01 AM
06/15/19 07:01 AM
MD
claluja Offline
claluja  Offline
MD
And Motorcraft 5w40 wasn't even on the approved list for the first year or so. Ford certainly didn't do it to sell Motorcraft oil.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Mr4btTahoe] #5134673
06/15/19 07:34 AM
06/15/19 07:34 AM
Central Iowa
TiredTrucker Offline
Central Iowa
I now have 984,000+ miles on the factory reman of my Detroit 60 pre-emission. All original. It has gotten CK rated oil from the time that Schaeffer first offered it. Wear numbers are virtually unchanged from when the engine had only 40K miles on the reman and still uses oil at the same rate as it has its entire time with me... about 1 qt per 11,000 miles. Last oil change, at 978,415 miles, 21156 hrs, with 22,693 miles / 491 hrs on the oil, the Iron was 16, Lead 6, Chrome 1, Copper 1, Tin 0, Aluminum 3.
The oil change intervals are 50% longer than the OEM recommended drain interval of 15,000 miles / 300 hours.
Oh.... and it has gotten 10w30 in winter and 15w40 in summer. CJ-4 initially then CK-4 when it showed up. Schaeffer syn blend. Both of which are on the Ford approved list if that matters to anyone. Even during all the controversy about CK-4 and Ford, the Schaeffer CK-4 made the approved list with Ford.
Probably should add... the add pack showed Boron 26, Moly 72, Calcium 2010, Phosphorous 1238, and Zinc 1016 on the UOA.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: Mr4btTahoe] #5135257
06/15/19 08:50 PM
06/15/19 08:50 PM
Southeast
BlakeB Offline
BlakeB  Offline
Southeast
Traveller 15w40 has the Ford approval and is regularly $25 for a 2.5 gallon jug. They run it on sale sometimes for $20. That’s what I’m using on my dads LML Duramax right now. The last oil change on it cost $28, you can’t beat that.
His LML doesn’t tick on the Traveller or Delo CK-4 but ticks really loud on Delvac 1300.
The Traveller is CK-4 only and the Delo is CK-4/SN.
Re: Best oil for pre-emissions mechanical diesels? CK4 showing high wear. [Re: BlakeB] #5135282
06/15/19 09:08 PM
06/15/19 09:08 PM
RI
mattd Offline
mattd  Offline
RI
Run it until it stops running IMO. The cylinders on the IDI are very soft and the blocks cannot be bored. They are too thin. It’s likey that’s the source of your iron. I’ve had a couple apart and they had a massive lip between where the piston traveled and the ridge on the cylinders. Easily 0.030” bore wear. You’re better off with a 6.9 block and boring it to a 7.3. Good luck and I hope you find a lube that can make it live longer.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Page 2 of 2 1 2
