Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
39 registered members (buck91, BlueOvalFitter, AndyB, CB900F2, Bighorn2500, 7 invisible), 632 guests, and 19 spiders.
Topics290,259
Posts4,987,225
Members68,412
Most Online2,967
Mar 10th, 2019
My 09 Suburban Needs A Body Control Module #5132748
06/12/19 10:36 PM
06/12/19 10:36 PM
NY, NY
NYEngineer Offline OP
NY, NY
Great... Huge single point of failure. My brother knows a guy that comes to you and programs them but he doesn't sell them. Any suggestions? Dealer?
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5132764
06/12/19 10:52 PM
06/12/19 10:52 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Dealer.....i would have it flashed/configured by the same dealer as well. GM will not warrant one configured by a 3rd party.
In general.....Most BCM failures are from Cold/Cracked solder joints.
2001 Chevy Camaro L92/4L80E
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5132891
06/13/19 06:31 AM
06/13/19 06:31 AM
illinois, usa
LazyDog Offline
LazyDog  Offline
illinois, usa
You can just pull it out and sent to have the solder joints fixed. No need to reprogram since it is the original. banana
Re: My 09 Suburban Needs A Body Control Module [Re: LazyDog] #5132898
06/13/19 06:40 AM
06/13/19 06:40 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
Yep.
I’ve done this with many Volvo modules. Worked great. I used these guys: https://xemodex.com/us/
They fix the module (solder joints, bulbs, power supply, transistors, whatever) and ship it back. They have express shipping. They are an example of a module repair company. Don’t know if they’ve got the service for your exact module, but...
I’m willing to bet that there is a whole trade industry fixing GM modules. Google. Surf the Chevy forums.
Barring that, get the dealer to do it. A new (or used) module that isn’t original to your car will need to be reprogrammed. For that, you’ll want full - up dealer software and a warranty.
32 Packard 15W40
01 Volvo V70 T5 0W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5132932
06/13/19 07:27 AM
06/13/19 07:27 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
I've pulled them and resoldered the joints. It's not hard if you have enough skill to get it out.
Re: My 09 Suburban Needs A Body Control Module [Re: DoubleWasp] #5132935
06/13/19 07:36 AM
06/13/19 07:36 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
I’ve got the skill to get it out, but I’m no good at soldering...
And if the problem is more complex than soldering (e.g. transistor or power supply failure) then I’m way over my head.
This is something that I would farm out, personally...
32 Packard 15W40
05 MB S600 0W40 M1
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133029
06/13/19 09:29 AM
06/13/19 09:29 AM
Cincinnati
Chris Meutsch Offline
Cincinnati
2005 Honda CR-V EX, 271k
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133030
06/13/19 09:30 AM
06/13/19 09:30 AM
Fort Lauderdale, FL
Fort Lauderdale, FL
You need none at all. You're not even soldering. You're just reflowing. Touch the tip to the old solder until it turns fluid. Lift tip off. Repeat for other solder points. Done.
I did my last one sitting on a box in my garage while falling asleep.
When my friend had the same problem with his other truck, his 10 year old son duplicated my work. If you can use a razor and write your name with a pen, you're good to go.
Don't worry about what might be wrong. It's a 45 minute job. If it doesn't work, then toss that thing off. But that's just my perspective. I haven't encountered one that was anything more than the solder yet.
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133046
06/13/19 09:48 AM
06/13/19 09:48 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
The power transistor on the 535i ECU would break solder joints. I watched Peter Florrance revive 2 out of 3 with a soldering iron. The 3rd smelled fried. At the time a new ECU was 1500$. I described the operation to a noob on the board and he fixed his.. You can see a broken solder joint. There is a black ring just below the top of the blob.It is carbon from arcing. grin2
Thick oil is better grin2
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133115
06/13/19 11:33 AM
06/13/19 11:33 AM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I have the benefit of a stereomicroscope available to me. Instead of reflowing dozens of good solder joints, I'll inspect the unit and find the broken and iffy solder joints.
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133347
06/13/19 04:15 PM
06/13/19 04:15 PM
Fort Lauderdale, FL
Fort Lauderdale, FL
The GM BCM doesn't have many. Might have been ten.
I always reflow all of them. If I have the unit open and my iron in front of me, do I really want to put it back together with the rest of the time bombs still ticking?
If one poorly done joint did the unit in, what reasonable assumption can one make about the rest of the joints?
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133635
06/13/19 09:30 PM
06/13/19 09:30 PM
NY, NY
NY, NY
Awesome. I'll pop it out tomorrow and have a look at it. This place is the best.
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5133954
06/14/19 10:01 AM
06/14/19 10:01 AM
Southeast
meep Offline
meep  Offline
Southeast
@ NYE - if you don't have an iron, pick up a 30 watt iron and some solder. Get the iron hot and moisten the tip with solder. if it doesn't adhere, scuff it lightly and try again. Keep a moist sponge or rag nearby to clean the tip.
As D'Wasp said, just reflow - but having your own spool will help if the tip gets dry, tacky, or you find a joint that is too dry.
@ Astro14 - I've read your posts. You can do this. Pick up an iron and some solder and practice on scrap 14 to 24 gauge wire and you'll get the feel for it.
2018 F150
2015 crv (wifey!)
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5134023
06/14/19 12:29 PM
06/14/19 12:29 PM
NY, NY
NY, NY
Meep... Thanks. I've got plenty of experience making emergency field repairs to printed circuit boards. I'm all set. I've got the perfect iron for this job. I'm excited to do it. I may try and do it as soon as I get home from work today.
I'll post back and let everyone know how it goes.
Re: My 09 Suburban Needs A Body Control Module [Re: NYEngineer] #5134287
06/14/19 06:04 PM
06/14/19 06:04 PM
NY, NY
NY, NY
Ok... I am a peepee. I got the BCM out of my truck pretty easily and got it open slightly less easily. I inspected it and realized I needed a magnifying glass so I went and got one at Ace. Still found NOTHING. I reassembled it and put it back in. Everything works the same.
I'm going to order a new one on Monday.
I just fixed the board in a VFD last week at work. After watching a few youtube videos I figured I had this in the bag.
