Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
18 registered members (Bailes1992, Gubkin, emod, avi1777, 4WD, 80Boxcar), 621 guests, and 20 spiders.
Topics293,636
Posts5,043,862
Members69,027
Most Online3,532
Jul 30th, 2019
Replacing Center Bearing on Driveshaft #5132721 06/12/19 10:01 PM
G
Gebo Offline OP
G
I am looking at replacing the center driveshaft bearing on my 2005 Lexus LS430. Do I need to make sure the mechanic marks the bolts and such to make sure he reinstalls the driveshaft the same way it came off? I have heard the driveshaft is balanced and it has to go back on the same way. My mechanic told me it didn't matter on this car. What is the truth?
'98 LEX LS400 295K
'02 4Runner 235K
'05 Lex LS430 85K
'07 Lex GX470 65K
SuperTech Oil
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
(Subject to Change as the Wind Blows)
Re: Replacing Center Bearing on Driveshaft [Re: Gebo] #5132726 06/12/19 10:04 PM
seanf Offline
Best practice is to mark it and put it back exactly however the really critical part is that the two halves go back together exactly the same after the center bearing is changed as they are balanced as one assembly
Re: Replacing Center Bearing on Driveshaft [Re: Gebo] #5132739 06/12/19 10:26 PM
T
Trav Offline
T
The shafts must absolutely be match marked upon removal when dealing with a 2 piece shaft, as the other poster mentioned it is balanced as an assembled unit regardless of make or model.
On higher end cars the 2 shafts may well be balanced individually and then as a whole, that is why he has gotten away with it before but I wouldn't count on it.
An out of balance shaft can be a real PITA. and will usually need to be corrected by a drive shaft outfit.
Re: Replacing Center Bearing on Driveshaft [Re: Gebo] #5132742 06/12/19 10:26 PM
clinebarger Offline
Always mark them.....Though it's most likely "Keyed" & you can't get to 2 shafts out of phase. We all know what ASSume means!
2001 Chevy Camaro L92/4L80E
Re: Replacing Center Bearing on Driveshaft [Re: Gebo] #5132753 06/12/19 10:42 PM
T
TheLawnRanger Offline
T
I would.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Replacing Center Bearing on Driveshaft [Re: Gebo] #5132775 06/12/19 11:06 PM
A
andyd Offline
A
Always match mark 2 piece shafts. Keep U-joints in phase. E 28 shafts were individually balanced. The CSB and the front varied with the transmission. From an assembly standpoint, individually balanced is simplest. Regardless of dire warnings, mismatched shafts didn't vibrate if kept in phase. As a general rule whenever I'm taking anything apart for the first time, I match mark. Always leave a trail of breadcrumbs. grin2
Thick oil is better grin2
Re: Replacing Center Bearing on Driveshaft [Re: clinebarger] #5132824 06/13/19 01:07 AM
Silk Online Content
Online Content
And don't assume that they have to line up like you think they should. Early Skylines (and Holdens using that drive line) had UJ's 15 deg out of phase. At first we thought someone had put them together wrong, and lined them back up. But it was factory.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Replacing Center Bearing on Driveshaft [Re: clinebarger] #5132862 06/13/19 05:27 AM
T
Trav Offline
T
+1 over the years I have come across a few that were were not and would go back together any which way (older Opel was known for this) or more commonly 180 off and in phase. The balance weights on the shafts do not necessarily align either.
I learned my lesson many years ago on an old GMC Long Horn in trade school, with its 8'6" bed they did a factory custom shaft in them. It would have taken a second to put a paint mark and avoid the whole fiasco, lesson learned.
Re: Replacing Center Bearing on Driveshaft [Re: Gebo] #5133131 06/13/19 11:57 AM
G
Gebo Offline OP
G
Update, he replaced the center bearing and said he marked the driveshaft. Now I have a him coming from the back of the car. Twice today, I got a vibrating rumble when I put slight pressure in the accelerator going from 35 and up. This noise and vibration does happen until I pressed the accelerator. That rumble vibration has quit but the humming noise is still there.
I may be making this up as my senses are
on high alertt
Thoughts?
My mechanic has been informed.
'98 LEX LS400 295K
'02 4Runner 235K
'05 Lex LS430 85K
'07 Lex GX470 65K
SuperTech Oil
Re: Replacing Center Bearing on Driveshaft [Re: Gebo] #5133158 06/13/19 12:24 PM
G
Gebo Offline OP
G
Further info. The sound is like snow tires .
'98 LEX LS400 295K
'02 4Runner 235K
'05 Lex LS430 85K
'07 Lex GX470 65K
SuperTech Oil
Re: Replacing Center Bearing on Driveshaft [Re: Gebo] #5133319 06/13/19 03:49 PM
G
Gebo Offline OP
G
Further info. Just changing the gear oil to Amsoil 75W-110 and lookey what I found stuck in my right rear brand new Michelin Premiere AS's.
Well, that explains the snow tire sound. LOL
[Linked Image]
[Linked Image]
'98 LEX LS400 295K
'02 4Runner 235K
'05 Lex LS430 85K
'07 Lex GX470 65K
SuperTech Oil
