Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
21 registered members (4WD, bonjo, dieselguy67, CATERHAM, 2015Corolla, eljefino), 647 guests, and 24 spiders.
Topics293,636
Posts5,043,861
Members69,027
Most Online3,532
Jul 30th, 2019
E10/E15 Gas #5132690 06/12/19 09:17 PM
M
Mad_Hatter Offline OP
M
Where I live most of the fuel is a E10/E15 blend. I can get ethanol free gas but it's at least $1 more than the premium E10/15 blended gas, so I usually get the ethanol fuel. In the summer months I go through the gas in my tank relatively fast but in the winter months it's not unusual for gas to sit in my tank for a month or more.
How real is this "phase separation" thing and is it something I should worry about in the winter months?
I've heard of several products that supposedly guard against this. What are your thoughts on these products?? [Linked Image]
[Linked Image]
Re: E10/E15 Gas [Re: Mad_Hatter] #5132702 06/12/19 09:27 PM
O
oldhp Online Content
Online Content
O
"Phase separation" thing is real. How long does it take? IDK. With a sealed F.I. system, a long time I would think. When not run E0 in the winter months?
2018 RAM 1500 3.6/8 speed.
2019 Dodge Charger SXT 3.6/8 speed.
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: E10/E15 Gas [Re: oldhp] #5132706 06/12/19 09:31 PM
M
M
I have considered that but I haven't mainly due to the cost i suppose. In the winter months the ethanol free gas can easily be $4/$4.50 a gallon or more. Right now for example it's $4.17gl (don't ask me why it's that high in summer)...I was just wondering if I could save the money by adding one these products.
Re: E10/E15 Gas [Re: Mad_Hatter] #5132724 06/12/19 10:04 PM
Dinoburner Offline
The 77 in my sig gets Stabil marine when put up for winter and no problems. Also it`s added to the gas cans with 89 octane fuel, again no problems.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: E10/E15 Gas [Re: Dinoburner] #5132750 06/12/19 10:37 PM
M
M
Is there a reason you use the Marine v. the 360?
Re: E10/E15 Gas [Re: Mad_Hatter] #5132769 06/12/19 11:00 PM
O
Online Content
O
I think both of those products would help. If you know your not gunna be driving for that month or so put 10 gals E0 in it and let'er sit.
Re: E10/E15 Gas [Re: Mad_Hatter] #5132776 06/12/19 11:09 PM
Marco620 Offline
Im a huge no ethanol guy. Buy either toptier or gas from a heavily visited station and use Gumout w Regane once per oci. Buy a second bottle and micro treat at 1 ounce per 1000 miles. Should be fine. Keep tank no less than 1/4 full. Low gas causes most issues.
15' Civic 1.8 i-vtec 262,000 mi Redline 5w20, BP Cvt fluid, Archoil9100
Tornado Chaser/Doberman Whisperer
Son of a Navy Corpsman.
Re: E10/E15 Gas [Re: Mad_Hatter] #5132791 06/12/19 11:43 PM
A
andyd Offline
A
Just curious. My Camry book told me that E-10 was OK, but E-15 isn't. E-0 has more BTUs per gallon than E-10-15. I've had lawn mower E-10 phase shift. Never in a car. I would use E-0 if it were available. grin2
Thick oil is better grin2
Re: E10/E15 Gas [Re: Mad_Hatter] #5132797 06/13/19 12:01 AM
Y
y_p_w Offline
Y
I've seen phase separation in my dad's lawnmower. He was asking me to help when he couldn't get it to start. It was stored for over a year using normal gas bought at gas station, which meant it probably contained ethanol. The fuel part was milky and the fuel and water separated like oil and water.
Other than that, I've never heard of it being an issue in a modern car with a properly working sealed fuel system. Any new car will have a system where the tank is pressurized with fuel vapor rather than atmospheric air. I've heard of people having oxygenated fuel (typically E10 or similar) tested after a couple of years where the fuel was fine and tested at the expected octane rating.
Re: E10/E15 Gas [Re: y_p_w] #5132816 06/13/19 12:48 AM
M
M
Did you have to flush/dump it all out or did you use something with isopropanol?? I've heard that works/helps. I just started using Heet in the red bottle a couple times in the winter up here in the NW. Can't say I've really ever had a issue with water but I figured it couldn't hurt, no? (I'm not particularly fond of the idea of isopropanol in my fuel a couple of tanks in the winter but can it be any worse than the ethanol?)
Also, I think running E0 in the winter would be the safest bet. I suppose I could, as suggested, just keep in 5~10gl just to have something in the tank and fill up with the "regular" E10/15 if I'm out for a long run... but would there be a problem putting in ethanol blend on top of what E0 might already be in the tank???
And how much of a concern would rust be in the tank if I'm keeping the fuel level that low. When I was younger I was always told to keep the tank topped off to prevent rust. Are today's tanks better equipped to deal with rust???
Re: E10/E15 Gas [Re: andyd] #5132821 06/13/19 12:59 AM
M
M
Most stations here around me do use E10 but I've been on the road in Oregon, Idaho and up around Seattle and stopped and had to use E15 because that's all there was. I would love to use regular E10 but man, at $4+ or more per gallon that's practically a $100 to fill up!
Re: E10/E15 Gas [Re: Mad_Hatter] #5132887 06/13/19 06:25 AM
B
barryh Offline
B
Only vented tanks like lawn mowers and my old motorcycle need worry about phase separation as they will continue to absorb moisture from the atmosphere in storage. In modern sealed tanks air only gets in as the fuel is used up. Not wanting to pay for water, what would worry me is how much water the fuel contains when you buy it. Hopefully none. I wonder if there is a spec that filling stations must comply with.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (MB oil 229.5 5W40)
Re: E10/E15 Gas [Re: Mad_Hatter] #5132888 06/13/19 06:25 AM
B
BMWTurboDzl Offline
B
Per the DOE (Dept of Energy) it takes approx 3 months for phase separation to occur in a high humidity environment.
Gasoline itself goes stale well before then.
435i
Re: E10/E15 Gas [Re: Mad_Hatter] #5132961 06/13/19 08:02 AM
Y
y_p_w Offline
Y
Not sure what he did with it.
I mean, there’s specific small engine gasoline, but it’s extremely expensive. I don’t know if I’d even think of using any unless equipment is going in storage. Just use up the fuel in the tank and partially fill. And even then if water gets into the fuel then E10 would help to blend it.
https://www.homedepot.com/p/TruFuel-4-Cycle-Ethanol-Free-Fuel-6527238/203571144
I don’t believe that people like gardeners with leaf blowers really worry about their equipment that they use every week. As long as the fuel is used it should never get to the point where there’s phase separation.
Re: E10/E15 Gas [Re: barryh] #5132967 06/13/19 08:08 AM
Y
y_p_w Offline
Y
Most have moisture filters before the flow detection that measures the amount of fuel dispensed. When some pumps were extremely slow, I was told it was because the filters needed replacement. It should still pump, but where there’s more restriction.
