Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
29 registered members (4WD, 80Boxcar, bmod305, Bailes1992, CB900F2, dbias, 2 invisible), 651 guests, and 21 spiders.
Topics293,636
Posts5,043,871
Members69,027
Most Online3,532
Jul 30th, 2019
Carquest Blue (Wix made) 84145 C&P, 5,058 miles #5132680 06/12/19 09:03 PM
blupupher Offline OP
This is a CarQuest Blue 84145 (Wix made) off my daughters 2012 Scion xB.
49,858 miles on car, 5058 miles on filter. Oil was Quaker State 5w-20.
Look very similar to the last two CQ I have done (HERE and HERE) as well as the earlier WIX
Filter (not rust on the seam, just dirt and oil, I double checked):
[Linked Image]
Silicone ADV:
[Linked Image]
Baseplate:
[Linked Image]
Metal center tube with holes:
[Linked Image]
Media:
[Linked Image]
[Linked Image]
Magnets caught a lot of stuff her in the top (similar to previous filters with magnets):
[Linked Image]
New fill is Mobil 1 EP and another CarQuest Blue 84145
[Linked Image]
Media is wrapped in paper towels drying out and will tear that apart and post in the next day or so.
I also have another youtube video posted of it as well.
Odd thing was this filter was leaking a bit. I tightened it when I installed it like I normally do, but there was some obvious leaking going on this time.
I was down almost a qt this time (previous changes at same interval have been 1/2 to 3/4 qt low), but at 4000 miles, it was only maybe 1/4 qt low, so 3/4 qt in 1000 miles.
Need to keep an eye on it for sure, this is the infamous 2AZ-FE that has consumption issues starting as early as 40,000 miles.
Weird thing is, seems to be loosing more oil in the last 1000 miles of the interval?
On a side note, my daughter did the entire oil change herself with me just supervising. only thing I did was get the floor jack out, jacked it up and put it on a stand, everything else she did.
Makes a dad proud.
2018 Santa Fe: PP 10W-30/OEM/5k
2018 Soul: Mobil Super 5W-20/OEM/5k
2012 xB: M1 EP 0W-20/CQ Blue/5k
2002 F150: Magnatec 5W-20/Bosch D+/1yr
1994 VT1100: Peak 15W-40/Bosch D+/1yr
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5132688 06/12/19 09:16 PM
53' Stude Offline
Filter looks good and good on you teaching her maintenance smile
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5132693 06/12/19 09:18 PM
O
oldhp Offline
O
Good for her and good for you teaching her!!! Whats the stuff in the bottom of the can? Slime or grit?
2018 RAM 1500 3.6/8 speed.
2019 Dodge Charger SXT 3.6/8 speed.
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: oldhp] #5132705 06/12/19 09:30 PM
Just stuff that is magnetic. Last 2 filters had similar:
[Linked Image]
[Linked Image]
This time I had 2 magnets in the middle, so it just caught more there.
The Wix from before I did not put a magnet on, so no idea if it was doing it then, and if I did not have magnets these times (and I put them on again this time) I would not even know about it. No idea how fine they really are, so may or may not have been caught by the media.
It feels like a very fine powder, and as said, is magnetic. Is it the engine slowly dying, no idea. I probably should do a UOA to find out for sure, but not really worried about it truthfully.
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5132719 06/12/19 09:59 PM
B
bbhero Offline
B
Not unusual for a Camry motor such has this one... My lady's Camry 98 2.2 does the exact same thing.. burns more in the last 1k miles...
Very good c and p. As usual too for you smile
Nissan Altima 3.5 Coupe
Cam2 Dexos1 Gen 2 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5132723 06/12/19 10:04 PM
Z
ZeeOSix Offline
Z
Most of that is ferrous metal wear. I see the same "black paste" on magnetic drain plugs. Most of it is probably too fine to be caught by most spin-on filters. Good C&P, thanks.
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: bbhero] #5132731 06/12/19 10:16 PM
53' Stude Offline
Amen colonel. I need to get off my lazy hind end and cut and post my tough guard filter.
OP: thanks for c&p smile
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5132771 06/12/19 11:02 PM
slacktide_bitog Offline
Thank you for the cut and post thumbsup
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: bbhero] #5132774 06/12/19 11:06 PM
But why? Just seems weird to have a non-linear oil usage.
I know the 2AZ-FE has the oil loss issue due to the ring issue, but none I have read say it is a sudden increase in loss at a specific mileage within the oil change interval.
My truck uses a qt ever 1500 miles (give or take a few hundred depending on how I drive), but is always there from the time the oil is put in.
I could understand a particular oil causing a new symptom of oil loss (which happened here, last 2 changes were low with an increase between 4000 and 5000 miles, both times I used QSUD (0w-20 and 5w-20). I will be checking oil every 1000 miles to watch carefully for loss, maybe 500 miles if it is noticeable).
Who knows, I may throw some 5w-30 in it next time (I was planning on using up all my 0w-20 (another 23 qts) on this vehicle though).
Quote
Thanks.
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5132802 06/13/19 12:22 AM
B
bbhero Offline
B
Well...
I don't have much an explanation either LOL
Just observations... Over the last 5 years with the lady's 98 Camry...
It does seem strange to me too... And what is more weird is that for whatever earthly reason the car burns a fair amount less Motorcraft 5w30 than any other oil I have run in it... Sometimes as little as a half a quart... Versus say Warren Distribution made oil for Federated Auto... The car burned about 1 and 1/3 a quart of that in 3,200 miles...
I don't know why that is the case. But it has been that way the whole time we've had the car. Got it with 66k miles.. Now at 153k miles.
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5132814 06/13/19 12:46 AM
CR94 Offline
...Media is wrapped in paper towels drying out and will tear that apart and post in the next day or so....
The paper towels are such a good idea I've done it myself---only later to read of other people doing the same thing.
Dipsticks are non-linear, because the upper surface area of oil in the sump typically shrinks as the oil level drops.
2011 Toyota Prius now at 102K
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5133247 06/13/19 02:11 PM
Got the media cut open today.
A little carbon and a few little metal flakes in there.
[Linked Image]
[Linked Image]
Daughter will be getting her license in a week so car will be getting driven more often.
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5133328 06/13/19 03:58 PM
53' Stude Offline
Looks good and thank you again for your hard work smile
Re: Carquest Blue (Wix made) 84145 C&P, 5,058 miles [Re: blupupher] #5135898 06/16/19 04:44 PM
W
wemay Offline
W
Thanks blupupher. You're c&p is excellent
2018 KIA Sportage LX 2.4 AWD:
EDGE 5W30, PH9688
2013 Hyundai Santa Fe Sport 2.0T:
M1HM 10W30, XG9688
