Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
39 registered members (53' Stude, bernau, Best F100, AndyB, 10 invisible), 687 guests, and 22 spiders.
Topics290,259
Posts4,987,232
Members68,413
Most Online2,967
Mar 10th, 2019
Mercruiser water separating gas filter cut open #5131928
06/12/19 01:32 AM
06/12/19 01:32 AM
Maryland USA
rubberchicken Offline OP
Maryland USA
Comparison between a virgin Quicksilver water separating gas filter , and a used Sierra equivalent, in service for 2 years. The Mercruiser / Quicksilver is part 35-866340K01 and the Sierra is a popular line of marine replacement parts. The Sierra was in service for about 100 hours, or about 1200-1500 gallons of gas.
The reason I post this here is because they are almost identical to oil filters.
Some observations
- Sierra does not seem to have any coating on the inside, while the Merc has a claimed epoxy coating. Very important considering that water builds up in the filter.
- Merc internal coating had air bubbles under the paint, and the end-plate was not coated on the inside. So good idea, poor execution on the internal coating.
- Sierra external coating was not as good as Merc, and had noticeable rust spots.
- Sierra not apparently coated on the inside, but I did not detect any internal rust. There was a tiny bit of water present when I drained the filter into a jar.
- Sierra has more filter area, Merc has more water holding capacity.
- Sierra had an assembly defect- the black nitrile gasket was offset and probably did not seal 100%, which might let dirty fuel bypass the filter.
- Sierra made in Taiwan, Merc in US.
- Merc / QS always on left, Sierra on right if 2 pics are side by side.
Honestly I was disappointed by both of them, but I would give the Merc a 6 out of 10, and the Sierra a 4 out of 10. I might consider a Racor for such an important part.
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5131930
06/12/19 01:37 AM
06/12/19 01:37 AM
Maryland USA
Maryland USA
[Linked Image]
[Linked Image]
[Linked Image]
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5131932
06/12/19 01:46 AM
06/12/19 01:46 AM
Maryland USA
Maryland USA
[Linked Image]
[Linked Image]
[Linked Image]
The brown smudge is sealer from the filter smeared around. The paint bubbles, which were all on the bottom, numerous and massive- the size of a US 5 cent piece , do not show up well.
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5131933
06/12/19 01:47 AM
06/12/19 01:47 AM
Maryland USA
Maryland USA
[Linked Image]
[Linked Image]
[Linked Image]
Merc / QS on left, Sierra on right
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5131976
06/12/19 04:26 AM
06/12/19 04:26 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
Once you go Racor, you don't go back.
The spin on cans are adequate for a gasoline fuel engine, but if you want industrial level filtering and separation, you can't beat a Racor or equivalent.
If you get one with a solid metal bowl for USCG compliance, get the water-in-fuel sensor. If you decide to do a low-micron element (2-micron) get a vacuum gauge for the exit port. Both are cheap and easy to set up. You can change your filter and drain water by performance rather than blind assumption.
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5132208
06/12/19 10:37 AM
06/12/19 10:37 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Most people change them once a year regardless. Both should do the job. Many Mercruiser carb engines have an additional filter at the carb.
2015 Ford F250 w/Powerstroke
Re: Mercruiser water separating gas filter cut open [Re: DoubleWasp] #5132601
06/12/19 07:43 PM
06/12/19 07:43 PM
Maryland USA
Maryland USA
Racor makes a direct replacement for this filter, with a metal bowl. I had one on my previous boat and was very happy, so I may look into one for my current boat. Good tip on the sensor- I did not realize they had that option.
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5134491
06/14/19 10:22 PM
06/14/19 10:22 PM
Fort Lauderdale, FL
Fort Lauderdale, FL
It's a good way to know when to drain. Very good tool to have. Like most WIF sensors, it's just two contacts that bridge when immersed in water.
Just hook it to the ground of a light on the dash, and you're good to go.
Honestly, far from a requirement on a small tank that is used frequently enough and kept filled, but it shuts out any pondering of water contamination or when to drain the filter.
