Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
Whoop, coondog, steelbeams, Pete44, Connie7
70521 Registered Users
94 registered members (1foxracing, Aero540T, 53' Stude, 2009Edge, 2002 Maxima SE, atikovi, 6 invisible), 2,156 guests, and 17 spiders.
Topics300,521
Posts5,177,674
Members70,520
Mercruiser water separating gas filter cut open #5131928 06/12/19 12:32 AM
R
rubberchicken Offline OP
R
Comparison between a virgin Quicksilver water separating gas filter , and a used Sierra equivalent, in service for 2 years. The Mercruiser / Quicksilver is part 35-866340K01 and the Sierra is a popular line of marine replacement parts. The Sierra was in service for about 100 hours, or about 1200-1500 gallons of gas.
The reason I post this here is because they are almost identical to oil filters.
Some observations
- Sierra does not seem to have any coating on the inside, while the Merc has a claimed epoxy coating. Very important considering that water builds up in the filter.
- Merc internal coating had air bubbles under the paint, and the end-plate was not coated on the inside. So good idea, poor execution on the internal coating.
- Sierra external coating was not as good as Merc, and had noticeable rust spots.
- Sierra not apparently coated on the inside, but I did not detect any internal rust. There was a tiny bit of water present when I drained the filter into a jar.
- Sierra has more filter area, Merc has more water holding capacity.
- Sierra had an assembly defect- the black nitrile gasket was offset and probably did not seal 100%, which might let dirty fuel bypass the filter.
- Sierra made in Taiwan, Merc in US.
- Merc / QS always on left, Sierra on right if 2 pics are side by side.
Honestly I was disappointed by both of them, but I would give the Merc a 6 out of 10, and the Sierra a 4 out of 10. I might consider a Racor for such an important part.
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5131930 06/12/19 12:37 AM
R
R
[Linked Image]
[Linked Image]
[Linked Image]
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5131932 06/12/19 12:46 AM
R
R
[Linked Image]
[Linked Image]
[Linked Image]
The brown smudge is sealer from the filter smeared around. The paint bubbles, which were all on the bottom, numerous and massive- the size of a US 5 cent piece , do not show up well.
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5131933 06/12/19 12:47 AM
R
R
[Linked Image]
[Linked Image]
[Linked Image]
Merc / QS on left, Sierra on right
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5131976 06/12/19 03:26 AM
DoubleWasp Offline
Once you go Racor, you don't go back.
The spin on cans are adequate for a gasoline fuel engine, but if you want industrial level filtering and separation, you can't beat a Racor or equivalent.
If you get one with a solid metal bowl for USCG compliance, get the water-in-fuel sensor. If you decide to do a low-micron element (2-micron) get a vacuum gauge for the exit port. Both are cheap and easy to set up. You can change your filter and drain water by performance rather than blind assumption.
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5132208 06/12/19 09:37 AM
Donald Offline
Most people change them once a year regardless. Both should do the job. Many Mercruiser carb engines have an additional filter at the carb.
2015 Ford F-250 w/Powerstroke
Re: Mercruiser water separating gas filter cut open [Re: DoubleWasp] #5132601 06/12/19 06:43 PM
R
R
Racor makes a direct replacement for this filter, with a metal bowl. I had one on my previous boat and was very happy, so I may look into one for my current boat. Good tip on the sensor- I did not realize they had that option.
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5134491 06/14/19 09:22 PM
DoubleWasp Offline
It's a good way to know when to drain. Very good tool to have. Like most WIF sensors, it's just two contacts that bridge when immersed in water.
Just hook it to the ground of a light on the dash, and you're good to go.
Honestly, far from a requirement on a small tank that is used frequently enough and kept filled, but it shuts out any pondering of water contamination or when to drain the filter.
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5145847 06/27/19 05:38 PM
gotnogunk Offline
I don't have a pro filter cutter but I drain my fuel water separator into a clear vessel. I never see any sign of water ???
2018 Cadillac XTS 3.6
2014 Ford F150 3.7 supercrew
Re: Mercruiser water separating gas filter cut open [Re: rubberchicken] #5320889 01/12/20 04:02 PM
L
littlehulkster Offline
L
That could be Mercury Marine's motto, honestly.
2015 Mazda3 I 2.0
