Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
85 registered members (Aichiguy, 2010Civic, bbhero, AZjeff, 55hambone, 4WD, 7 invisible), 1,480 guests, and 17 spiders.
Topics301,809
Posts5,203,132
Members70,784
2016 f450, deleted, 6,000miles #5131752 06/11/19 07:55 PM
CrazyMike Offline OP
Running a lpf9750 Luberfiner, wix full flow, Coop Dmo CJ4 15w40 mineral. 6-7,000miles. Air filter has been a large open style, oiled membrane, with pre filter sock. Truck has been deleted since January. Very dusty conditions. Looks ok IMO, air filtration a bit lacking. No TBN numbers avail at the time. Will add that to future UOA. Thoughts?
[Linked Image]
Ford F450 6.7, Mercedes cars, lots of toys using oil.
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5131777 06/11/19 08:20 PM
Danno Offline
The Si numbers get my attention. Dusting an engine was a problem in our 7.3s and 6.0s in the west.
I'd be looking at going to stock filtration if it was my truck.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5131805 06/11/19 08:55 PM
DoubleWasp Offline
Need a VOA. Si may be part of the formula. There are HDEOs that have Si equal to or greater than that as an additive.
Re: 2016 f450, deleted, 6,000miles [Re: Danno] #5131806 06/11/19 08:55 PM
Stock assembly won't flow enough, has a giant aftermarket turbo on it running 45psi. There are some paper elements to try though, disposable but still large surface area. Might even have one on the shelf.
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5131810 06/11/19 09:02 PM
SavagePatch Offline
Without knowing what brand you're running now I would recommend looking in to AFE and seeing if they have a Dry (or Oiled) filter that will work with your intake.
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5131822 06/11/19 09:26 PM
DoubleWasp Offline
Meant to add, single digit wear numbers are a good sign. Gotta have that VOA though.
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5131875 06/11/19 10:16 PM
Been running S&B paper filters with a wrap before delete, switched to oiled with wrap after delete since I could collapse the filter gauge, needed more flow. I found with better flowing oiled and a wrap I could still collapse the gauge, ran 2 weeks with no wrap during a trip through BC, could of very well collected a majority of this silica during this trip. Regardless I agree some filtration needs to change, and further UOA. Thx for the feedback!
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5131886 06/11/19 10:36 PM
DoubleWasp Offline
Try AEM Dryflow. On my Cummins Rams, I could collapse the gauge on a brand new factory filter.
My DryFlow is showing nothing on the gauge after more than 50,000 miles in service. I operate in sand and dust clouds all of the time and typically put up single digit Si numbers over a 25,000 mile oil change interval. I have not cleaned it even once.
Get the biggest one you can fit. You will not regret it.
But again, you need to know whether or not Si is part of the formula.
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5131891 06/11/19 10:53 PM
M
motor_oil_madman Online Content
Online Content
M
So you went 10,000 miles on this report? I'm confused, you say 6-7000 miles in your post, but then the oil report says 90,000 miles on the engine and 10,000 on the fluid.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: 2016 f450, deleted, 6,000miles [Re: motor_oil_madman] #5132034 06/12/19 06:03 AM
SubieRubyRoo Offline
10,000 kilometers. He's north of the border.
De omnibus dubitandum.
Re: 2016 f450, deleted, 6,000miles [Re: SubieRubyRoo] #5132156 06/12/19 08:32 AM
53' Stude Offline
LOL! Yeah, Chris ya can't fix stupid wink
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5132163 06/12/19 08:39 AM
B
BMWTurboDzl Offline
B
Sounds like you're on the right tract looking for larger filters. Larger filters = reduced pressure loss through the filter media.
435i
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5132267 06/12/19 10:58 AM
A
addyguy Offline
A
For a deleted truck, in harsh conditions, I'd say the results are great.
2010 Kia Soul 2U - 2.0L I-4, auto; 152k miles.
Castrol Edge (black bottle) 5W-30; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5132283 06/12/19 11:24 AM
dnewton3 Offline
Global Moderator
Global Moderator
those are decent wear numbers for the exposure and presumed dust inhalation.
I would look into going back to a stock air filter, but seeing if you can mod up a "double" intake somehow to get the volume you need using stock elements. I realize it's cramped inside a 6.7L PSD hood.
You play, you gotta pay! grin
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2016 f450, deleted, 6,000miles [Re: CrazyMike] #5132481 06/12/19 03:42 PM
B
BrianF Offline
B
Nice to see people running DMO. Popular out here.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
