If 0W-oil gives you peace of mind for cold starts, or you think your son will get slightly better fuel economy, then use it. Even in snow climates, plenty of cars are running 5W-whatever. However, either would be fine. Any modern car using 5W-20 can run 0W-20. Both are 20 weight when vehicle is at operating temperature. Difference is negligible. You can use any brand formulation you want. At 94,000 miles, some people may consider a high mileage oil.
