Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
39 registered members (Best F100, 53' Stude, bernau, buck91, 11 invisible), 726 guests, and 22 spiders.
Topics290,259
Posts4,987,232
Members68,413
Most Online2,967
Mar 10th, 2019
Electric (cordless) kettle repair #5129560
06/09/19 06:25 PM
06/09/19 06:25 PM
Winnipeg MB CA
Number_35 Offline OP
Winnipeg MB CA
Our Oster kettle quit working yesterday. By cordless, I mean that the base plugs in, but the actual kettle can be removed. It's probably our most-used kitchen appliance, as we boil up water for several big pots of tea daily. This was a minor disaster.
I watched a couple of YouTube videos, both indicating that it's typically the thermostat that fails. (One was quite amusing - the presenter was Indian, and referred to the kettle as a "geyser", which is likely a Brit term. And he pronounced it the Brit way, "geezer". So I figured if I attempted a repair, it would be an old geezer trying to fix an old geyser.) LOL
Anyway, I took the bottom cover off the kettle (two Phillips screws and one tamper-proof screw I had to persuade a bit) and measured the resistance of the heating element - around 10 Ohms as expected.
I'd always assumed these used an inductive coupling, but in fact there are contacts on the kettle and the base. The ones on the base are shielded by a spring-loaded cover when the kettle is not on the base. Poked around with the Ohmmeter and got high resistances or opens for all of the tests. (N pin of the plug to either of the contacts under the base's protective contact cover, ditto for the Hot pin of the plug, and same for the ground. On the kettle, found high resistance between the Hot and Neutral contacts.
Couldn't find any electrical contact cleaner, but used some brake cleaner. Ohmed everything out again, and had continuity on all three circuits (H, N, and G) on the base, but the heater circuit (H to N) on the kettle was open. Then I realized the switch was off. duh Turned it on, and continuity was good.
Put some water in it, and it worked great. Comparable replacements run c. $50 (plus our 13% sales tax) so that was a few minutes well spent. Takeaway: Check the contacts before scrapping your electric kettle.
Re: Electric (cordless) kettle repair [Re: Number_35] #5129597
06/09/19 07:02 PM
06/09/19 07:02 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
great when something can be repaired and spared from the trash heap!
Re: Electric (cordless) kettle repair [Re: Number_35] #5129984
06/10/19 07:47 AM
06/10/19 07:47 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Congratulation on the repair ! :-)
Wyr
God bless
Re: Electric (cordless) kettle repair [Re: Number_35] #5130011
06/10/19 08:19 AM
06/10/19 08:19 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Good job. I had one of these in my old office. It was an indispensable dispenser for hot water for tea in the AM.
I recall the element had the highest wattage that you could run on a 15amp breaker without popping it.
It boiled a pint in about 40 to 50 seconds.
Thats fast.
They pulled this model due to "safety issues".
I read people were getting scalded by hot water.
Duh!
[Linked Image]
2019 VW Jetta S,6M OCI#0 3107mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Electric (cordless) kettle repair [Re: ARCOgraphite] #5130044
06/10/19 09:13 AM
06/10/19 09:13 AM
Winnipeg MB CA
Winnipeg MB CA
Thats fast.
Duh!
[Linked Image]
I guess we're an impatient society, but our 1435 W kettle does seem to take a long time to bring 1.7 l of water to a boil. I like that Sunbeam unit you've shown. #1 son had a different solution - in his house he wired in a 240 V receptacle, bought a Brit kettle (240 V), and retrofitted a North American-style 240 V plug. The 240 V kettle is very fast compared to ours. If we ever get to our kitchen reno I'd like to do the same.
Re: Electric (cordless) kettle repair [Re: Number_35] #5130068
06/10/19 09:29 AM
06/10/19 09:29 AM
America
Alfred_B Offline
Alfred_B  Offline
America
One of the few great thing in the tool box -- brake cleaner.
Re: Electric (cordless) kettle repair [Re: Number_35] #5130077
06/10/19 09:42 AM
06/10/19 09:42 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Total watts is more important than voltage, some of the 220v/240v kettles don't consume any more power than the 120v ones do and wouldn't be any faster.
Having said that though, this one is rated at 3000W. Hmm, might be an interesting idea:
https://www.amazon.com/Electric-Stainless-Temperature-Different-Dynastar/dp/B07JNRSFGX
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 413K
2000 Toyota ECHO, 281K
Re: Electric (cordless) kettle repair [Re: kschachn] #5130447
06/10/19 03:38 PM
06/10/19 03:38 PM
Winnipeg MB CA
Winnipeg MB CA
Agreed, it's Watts (power) which determines the heating speed. We'd wondered about lopping the plug off a conventional kettle and putting on a 240 V plug ...
R = 10 Ohms
E = 240 V
I = E/R = 24 A
Oops, way too much for the 20 A receptacle!
Let's assume (because I don't know what the Brit kettle is rated at) that its heating element's resistance was 20 Ohms:
R = 20 Ohms
E = 240 V
I = E/R = 12 A. OK, that, as a steady-state load, is at the limit for a 15 A circuit w/ #14 AWG wire. I think he used a 20 A breaker and #12 AWG wire.
Resulting wattage: P = E*I = 240 V * 12 A = 2880 W.
So, to double the power consumption of a resistive load, you can double the input voltage and double the resistance.
That should halve the time to boil the water.
Re: Electric (cordless) kettle repair [Re: Number_35] #5131171
06/11/19 09:02 AM
06/11/19 09:02 AM
N.H, U.S.A.
N.H, U.S.A.
At home we have a kettle on the gas stovetop. That take about 4 minutes to boil 1litre on a med low flame.
You can also make a alcohol burner. if you don't want to "wast" electricity converting it to heat.
