Bosch fuel pump quality
by drtyler - 11/19/19 11:28 AM
Standard Motor Products
by Whimsey - 11/19/19 11:25 AM
Delo SynBlend 15w40 - $11.45
by Greg L - 11/19/19 11:17 AM
VIRGIN STP 8316 CUT OPEN
by 53' Stude - 11/19/19 11:00 AM
FPPF: Polar Power & Total Power
by BigJohn - 11/19/19 10:40 AM
Quality filter for 2017 Subaru 2.5 Ltr
by Ishmael - 11/19/19 10:39 AM
Kendall GT-1 Max vs PP
by c5z06 - 11/19/19 10:25 AM
Toyota Sienna FWD in Snow / Ice
by tiredguy - 11/19/19 09:32 AM
7.62 x 39 Top Three?
by CCI - 11/19/19 09:30 AM
MOTUL Specific VW 508.00 Unboxing
by ARCOgraphite - 11/19/19 09:14 AM
A few Ford part number filters cut open
by mpgo4th - 11/19/19 09:08 AM
Battery warranty Issue at Pep Boys
by InhalingBullets - 11/19/19 08:35 AM
How Often To Use CRC IVC ?
by ChrisD46 - 11/19/19 03:28 AM
SEARS: 4 Stroke/Lawnmower Maintenance Deals
by GumbyJarvis - 11/19/19 02:17 AM
Pepboys Coupon
by Xeno - 11/19/19 02:12 AM
Pennzoil “Designed for Your Drive”
by LubeFiner - 11/19/19 02:09 AM
Ebay $15 of $75 purchase
by GMguy84 - 11/19/19 12:06 AM
How thorough are coolant flushes at auto shops?
by Whammo - 11/18/19 10:58 PM
Fixed Orifice PCV design and issues.
by Talent_Keyhole - 11/18/19 10:44 PM
Redline Si-1 turning the light out
by lukejo - 11/18/19 10:16 PM
Hansvoytek, DeltaP71, 300Kncounting, Bill67, vjt51965
69916 Registered Users
86 registered members (2010Civic, 53' Stude, aquariuscsm, 4WD, 28oz, 13 invisible), 2,037 guests, and 24 spiders.
Topics297,631
Posts5,119,658
Members69,916
Most Online3,589
Nov 2nd, 2019
New U Joints Won't Take Grease #5130822 06/10/19 08:08 PM
T
TheLawnRanger Offline OP
T
I replaced the u joints on my truck. They went on pretty easy. I though the project was almost over until I went to grease the u joints before reinstalling the driveshaft. I can't get any of the 3 u joints to take grease. I am also using a new grease gun that has grease coming out but doesn't seem to lock to the zerk. Is there something I need to do to the gun or zerks before pumping the grease?
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: New U Joints Won't Take Grease [Re: TheLawnRanger] #5130893 06/10/19 09:11 PM
P
Pelican Offline
P
Get yourself a "Lock and Lube" to fit on your grease gun and no more problems.
Re: New U Joints Won't Take Grease [Re: TheLawnRanger] #5130921 06/10/19 09:50 PM
clinebarger Offline
Assuming that your using Neapco or Spicer joints.....It's probably your grease gun!
Is your gun fully bled & primed? I've never needed a locking tip for greasing U-Joints. Could be an issue with you not getting square on the zerk or you have a junk gun/tip?
2001 Chevy Camaro L92/4L80E
Re: New U Joints Won't Take Grease [Re: clinebarger] #5130933 06/10/19 10:10 PM
T
T
Spicer u joints, Performance Tool grease gun
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Re: New U Joints Won't Take Grease [Re: TheLawnRanger] #5131012 06/11/19 03:52 AM
L
Lubener Offline
L
If you can't squarely attach the gun to the zerk,it will never snap on the zerk and you will never get grease in and will squirt all over. Could be a cheap, Chinese made grease gun that will never snap properly on the zerk.
The "thinking" man's friend.
Re: New U Joints Won't Take Grease [Re: TheLawnRanger] #5131102 06/11/19 06:38 AM
Driz Online Content
Online Content
Try a flex hose on it. If you can’t get straight on the zerk it won’t snap down. Sometimes
The straight pipe on most guns won’t sometimes let you get the angle you need. They’re only a few bucks at any place carrying auto parts.
Re: New U Joints Won't Take Grease [Re: TheLawnRanger] #5131114 06/11/19 06:54 AM
Hootbro Offline
Ditto on what others are saying to find a better fitting and/or grease gun to lock on the zerk. Also, I would recommend for first time installed zerks is to get a small pick tool and make sure the little nipple ball can be depressed. I have had new zerks not take grease because the nipple ball was stuck.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
2013 Volkswagen Jetta 2.5L (Dealer Bulk 5W-40)
Re: New U Joints Won't Take Grease [Re: TheLawnRanger] #5131835 06/11/19 09:41 PM
T
T
I had a bad coupler on my new grease gun. My neighbor brought his over and it worked fine. The coupler on the neighbor's grease gun went right in the zerks making a popping sound as it went on letting me know it was on good enough. After that, no problem except the u joint with 2 c clips. Grease was not coming out of those rollers until I loosened the vice grips holding them on until I reinstalled the driveshaft.
Thanks to everyone who gave me advice for this project on this and a few other threads. I had a successful test drive earlier this evening.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Re: New U Joints Won't Take Grease [Re: TheLawnRanger] #5132432 06/12/19 02:25 PM
L
littleant Offline
L
They also make a needle point adaptor that works well when greasing joints when the driveshaft (still in vehicle) does not allow getting square on the zerk fitting. My 02 Jeep is like that on driveshaft and axle shafts.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
