Viscosity Modifiers
MolaKule
Staff member
Iowegia - USA
There are two main categories of Viscosity Modifiers (VMs).
Names those two categories.
This question is not open to Tribologists or Chemists.
Quote
Like Olefin Copolymers and Hydrogenated Styrene Diene?
Not a question of the types of chemistry but rather the two main categories of Viscosity Modifiers.
You have named some types of Viscosity Index Improvers (VII's), in which VII's are one category, so please name the other category.
Thanks for your responses and interest in Viscosity Modifiers.
We can think of Viscosity Modifiers as falling into two categories:
1) Thickeners,
2) Viscosity Index Improvers (VII's).
Thickeners increase the viscosity of a lubricant without necessarily increasing the Viscosity Index (VI). One of those thickeners is a high viscosity Bright stock, a thick Group I oil, used as thickeners in engine oils and gear lubes, but is less used today because of less Group I production, and because better and more stable thickeners are available.
Another thickener is Polyisobutene (PIB's). At low treat rates, high viscosity PIB's are often used as viscosity "adjusters" to low-viscosity base stocks. PIB popularity has decreased due to poor oxidative and mechanical stability. However, they are still used in two-stroke engine oils, gear oils, and hydraulic fluids.
Viscosity Index Improvers (VII's) will have a larger effect on solution (bulk) viscosity at higher temperatures than at lower temperatures, thereby increasing the Viscosity Index (VI), which is the most commercially used measure of the rate of change of viscosity with temperature.
Some of the polymer VII's include Olefin Copolymers (OCP's), Polyalkyl Methacylates (PAMA's), Hydrogented Styrene-Dienes (HSD's), and PAMA-OCP polymer Blends.
