Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
Mobil 1 FS 0w40 vs Castrol 0w40
by Ndx - 11/12/19 04:14 PM
How often to drive a second car.
by SouthDakotaDad - 11/12/19 03:48 PM
Manufacturers, Bypasses & Large Sumps
by ad244 - 11/12/19 03:23 PM
Samsung DeX for PC
by dogememe - 11/12/19 03:19 PM
2008 Acura TL Timing Belt/Component Kit
by BAJA_05 - 11/12/19 02:06 PM
Installing decals and emblems in cold weather
by atikovi - 11/12/19 01:39 PM
Skyactiv 20,000 mile OCI with Oil Analysis
by thegameq - 11/12/19 01:23 PM
Stihl KM110R Carburetor Adjustment
by henni - 11/12/19 01:10 PM
Mix and match wheel cylinder brands?
by RocketUSA - 11/12/19 12:45 PM
Hombre909, DeLong, Scuder, Jasonrmcc, Capacc
69840 Registered Users
119 registered members (1978elcamino, 2010Civic, 928, 69Torino, 2002 Maxima SE, 15 invisible), 2,115 guests, and 24 spiders.
Topics297,332
Posts5,113,222
Members69,840
Most Online3,589
Nov 2nd, 2019
98 Expedition - Spark Plug Torque to prevent spitting plugs #5130226 06/10/19 11:27 AM
F
Fitz98 Offline OP
F
I am changing the plugs on my 98 Expedition 5.4 4x4.
Torkspec website says 10 lbs torque on plugs to head, but I have also read to increase torque to prevent spitting plugs.
Anyone know the magic number to torque these into the triton aluminum heads?
I have spit a plug before and would like to prevent it again if I can.
Was there ever a TSB?
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130264 06/10/19 12:05 PM
bdcardinal Offline
From the FSM 16-20Nm or 12-14ft-lb
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130301 06/10/19 12:35 PM
Chris142 Offline
I would use my arm and go strictly by feel.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: bdcardinal] #5130362 06/10/19 01:30 PM
F
Fitz98 Offline OP
F
So there was no TSB to prevent spitting plugs out of head?
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130364 06/10/19 01:31 PM
L
Linctex Offline
L
There's only 3 THREADS of aluminum holding each plug in. It's not hard to strip them out.
12-14ft-lb and no more than that.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130385 06/10/19 01:50 PM
M
Miller88 Offline
M
For some reason I recall mine being tightened to 20. 1997 F150 5.4
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130400 06/10/19 01:56 PM
T
Trav Offline
T
In that range you are getting into lb-in if you need any sort of real accuracy and you do which eliminates most 3/8 tools.
If you use never seize the number will be even lower, hand slightly firmer than snug and call it good. In my experience (not that I am a big Ford guy, far from it) they seem to let go more when tightened to the spec after changing them.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130450 06/10/19 02:43 PM
bdcardinal Offline
Just about repairing the head after they blow out. Which according to Ford, they wanted you to put a new head on.
Here is a video from Ford Tech Makuloco https://www.youtube.com/watch?v=kc4-z-sT1ms
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130466 06/10/19 02:53 PM
Colt45ws Offline
There is a site out there that advises using some rediculous high torque on the plugs but I think thats a bad ida. Ive done a little research and Ive found 20-25ft lbs is doable on 4 thread heads. On the newer 8 thread heads I just go straight to 25ft lbs and dont even think about it. They dont loosen after that.
I popped 2 plugs on my 2002 and both times it was because the plugs had loosened until they blew out. Ive done some other mod motor vehicles and often find at least one spark plug loose and coated in the brown-orange soot from the gasses escaping up the threads.
imo 10ft lbs is too little torque to prevent loosening and backing out over time. If you want to be really safe torque to factory 10ftlbs and then go back and retorque every 10-20k
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130480 06/10/19 03:12 PM
F
Fitz98 Offline OP
F
I was also thinking about the anti-seize. It does just what it says, prevents the different metals from seizing, but can't help but wonder if that contributes to plugs loosening and blowing out.
Perhaps it is more due to dissimilar metals without anti-seize causing galvanic corrosion on the aluminum heads, weakening the aluminum threads.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5131071 06/11/19 05:54 AM
T
Trav Offline
T
The problem with these is not anti seize or anything else its the 3 threads that is the root issue that even when new were weak, it is just bad engineering. Now you get to repair their mistakes, course engineers know best right. LOL
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5131174 06/11/19 08:06 AM
W
WyrTwister Offline
W
You would think some one would have filled a class action against Ford ?
Wyr
God bless
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Trav] #5131234 06/11/19 09:18 AM
bdcardinal Offline
I would say that now is the perfect time to repair every cylinder if the OP plans on keeping the vehicle long term.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5131259 06/11/19 09:47 AM
Schmoe Offline
Ford days it's a spark plug problem, not a head problem.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Schmoe] #5131343 06/11/19 11:02 AM
bdcardinal Offline
Well I believe that when my poo turns purple and smells like rainbow sherbet.
