Ultrasonic Cleaner
by ET16. 06/16/19 06:27 AM
Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
53 registered members (bbhero, 53' Stude, AlienBug, bernau, Best F100, 8 invisible), 786 guests, and 21 spiders.
Topics290,259
Posts4,987,243
Members68,413
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5132877
06/13/19 05:57 AM
06/13/19 05:57 AM
Florida
Amkeer Offline
Amkeer  Offline
Florida
These transmission are very durable so I wouldn't be to worried. It may be under filled or over filled. You can also use a infrared gauge to check the temperature of the pan in order to get between 105-115 degrees. Drain and refill is what I do.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 94000
2008 Toyota Tundra D Cab 5.7 M1 5-20 95000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 206000 miles
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5133179
06/13/19 12:47 PM
06/13/19 12:47 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
1) I'd just do it myself to make sure it was done correctly. If you don't have that capability, then a really good shop.
2) I would insist on Maxlife or a high quality WS-compatible fluid, but I would NOT use WS. It wears out quickly, creating slip and this is well known.
3) The temperature is just not as critical as indicated. The thermal expansion rate of ATF is not that large. What TheCritic said is adequate; idle a few minutes in shirtsleeve weather, or go drive around the block once or twice.
4) Are they checking the fill while running, (else it will end up low). I am guessing they are, but helps to check.
You said the car has 126k and you've done drain/fills. You did not say when you got the car and how many that has been. If you have done less than four drain/fills at average ~2qts each, I'd say this sounds perfectly normal for WS fluid with that many miles on it. You just haven't changed out enough of it to get back to a healthy % of good fluid. So:
How many drain/fills have actually been done on it since new, with what fluid?
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Oro_O] #5133910
06/14/19 08:49 AM
06/14/19 08:49 AM
Upstate NY
windeye Offline
windeye  Offline
Upstate NY
Professor Kelly on Weber Auto youtube channel did his research on the ATF, and he is very skeptical on the Maxlife ATF. Go see that video on "60-years of toyota ATF". It's a fact that Maxlife ATF does NOT have a single licence for this ATF, and it claims that it's compatible to Dexron 6, totoya T-IV, WS, etc. And we know through TSBs from Ford and Totoya, that these fluids are NOT compatible. How did Maxlife manage to create a fluid that's compatible to those fluids is everyone's guess. I would use only WS for your ATX.
2000 Mazda MPV LX, 202,500 miles
2007 Mazda 3 Touring, 112,800 miles
2013 Toyota Camry XLE, 100,800 miles
Page 2 of 2 1 2
