Credit Karma
by aquariuscsm - 10/22/19 01:20 PM
Does Fuel Dilution Leave Oil After Cause Resolved?
by LoneRanger - 10/22/19 01:11 PM
How do you select tires?
by ZZman - 10/22/19 12:12 PM
Shell TF-0870
by rooflessVW - 10/22/19 12:07 PM
Reverse tire look up?
by tiredguy - 10/22/19 11:35 AM
Oil consuming 2004 Mercury Marauder
by 2013ecof150 - 10/22/19 11:09 AM
2015 Triumph Trophy SE - Castrol 10W40
by Rick505 - 10/22/19 11:08 AM
need a mini van/suv for my son 10k
by BeerCan - 10/22/19 10:52 AM
Propene, polymer with ethene use in motor oil
by DrDanger - 10/22/19 10:29 AM
Wax recommendations
by dawgn86 - 10/22/19 09:46 AM
Oil and Filter Advice
by dawgn86 - 10/22/19 09:44 AM
Lift Master Remote RE-Programming
by Gebo - 10/22/19 09:10 AM
My '88 Daytona
by IronMaidenRules - 10/22/19 09:08 AM
QSUD and cleaning?
by irv - 10/22/19 08:56 AM
New 2019 Toyota Highlander first oil change
by thooks - 10/22/19 07:50 AM
2019 Golf R
by wings&wheels - 10/22/19 06:47 AM
My latest battery load test
by Char Baby - 10/22/19 05:18 AM
MB Loctite 5970
by The Critic - 10/22/19 01:18 AM
Amazon Special on Lubegard LXE
by Marco620 - 10/21/19 11:42 PM
TV_Viewer2, Finner, blimo, Haiducek, NoRegrets
69642 Registered Users
106 registered members (2013ecof150, 28oz, 14Accent, 53' Stude, 2010Civic, 6 invisible), 2,222 guests, and 28 spiders.
Topics296,329
Posts5,095,725
Members69,642
Most Online3,532
Jul 30th, 2019
2010 Camry trans slipping after 2 drains; what now? #5130256 06/10/19 01:01 PM
J
Jasper8146 Offline OP
J
I posted on here when I first got my 2010 Toyota Camry V6 automatic about transmission fluid changes and more or less followed the advice not to flush and instead do drain and refills. Car now has 126k and after neither drain and refill did it really run any better. Actually, has been about 20k since last one and trans is slipping slightly on very steep grades and just generally seems not to be at its best. Am concerned place that did it may not have gotten fluid level correct since they said it only took 2 quarts based on what they drained out, and a couple of websites say it should be around 2.5 quarts. That means tranny may be a quart low now (or not). Am thinking of taking to dealer to correctly check fluid level depending on expense and then having them do a fluid exchange albeit without doing the cleaning solution which so many seem to think is harmful. Of course, they may not be willing to do it that way or not take any responsibility for what happens in the future. So, feel like I should do something about fluid and doing a flush would be better than waiting for it to get worse when there would be real problems new fluid would never solve. What do people think? Car has 126k and has had 2 drain and refills for sure and probably nothing else. Won't take it back to place that did drains because they contaminated the oil last time and am still concerned they may have done that to the trans also, which would be another reason to get all the old fluid out. All thoughts much appreciated.
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130267 06/10/19 01:06 PM
W
walterjay Offline
W
Consider a trusted reputable transmission shop if one exists in your area
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130283 06/10/19 01:17 PM
slacktide_bitog Offline
Add a quart and see if the problem remains or goes away smile
When draining the transmission, measure how much came out, and put that much back in.
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130288 06/10/19 01:23 PM
M
maxdustington Offline
M
Dump it yourself and put in 2.5 qts. What do you have to lose?
At this point I would be concerned about paying shops to service a trans that might have to be replaced. Do some D&Fs and see if anything improves. They might have put the wrong fluid in, put an incorrect amount in or contaminated it like you said.
97 GMC RCLB K2500LD L30/4L60
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130291 06/10/19 01:30 PM
The Critic Online Crying
Online Crying
The fluid level should be adjusted at approx 104F. You need a scan tool which is capable of reading the fluid temp sensor.
As a "ballpark" check, I guess you can allow the trans to sit overnight, then start it up and allow the vehicle to warm up for 2-3 min (no more). Pull the trans check plug on the overflow tube, and check if fluid is coming out. Presumably, at this point, you should be well under the 104f threshold so lots of fluid should be draining.
2011 Toyota Prius 1.8L - 198K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 139K - Valvoline Premium Blue Restore 10W-30
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130292 06/10/19 01:30 PM
M
mclasser Offline
M
Did the shop use OEM ATF or some generic crap?
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130314 06/10/19 01:48 PM
B
BMWTurboDzl Offline
B
"Life time" units are difficult to do correctly because the fill procedure requires that the ATF be measured within a specified temp range. It's why dealerships tend to shy away from the work. I would find a reputable shop to perform another drain an fill, but be forewarned that with regards to units built within the past 15 yrs of so, ATF changes, as a rule, do not guarantee long service life of the transmission.
435i
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130333 06/10/19 02:01 PM
supton Online Content
Online Content
I'd do a fluid exchange myself, but, I have the cheapo Techstream off ebay and can query the trans for its temperature. And thus get the fluid level correct. And I tend to be fussy like that.
If this isn't something you can do, I'd probably go to the dealer and have them do it. I doubt they'd turn you away. I mean, they deny stuff under warranty, right? so if it failed 1k after they flush it then I don't seem them feeling any pressure that it was their fault. [I kid! well mostly.]
I suspect the fluid level is just off. Wrong fluid isn't good but Aisin transmissions seem pretty robust. It could be something else entirely, perhaps a solenoid has quit or is acting up. The problem could be completely unrelated to the fluid change.
2011 Toyota Camry, base, 2.5L/6MT, 193k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 214k, his
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130370 06/10/19 02:37 PM
G
Gebo Offline
G
In order to accurately check the level, Toyota will have a range of temps you need to be between when checking the fluid level.
For example from Lexus Service Bulletin:
2008 LS460 between 95F and 108F (13 degree window)
2006 LS430 between 115F and 133F (31 degree window)
2007 EX350 between 104F and 113F (9 degree window)
Unless you have the proper scan tool, this will be very difficult to do. I paid about $100 for the Scan Tool I use.
Since ATF expands as it heats up, more will come out of the "overflow" tube the hotter the fluid gets. In my cars, I try to check it at the lowest acceptable temp to try and leave me with the highest amount of ATF in my transmissions.
Some will disagree, but I would make sure I only used Toyota WS fluid in your car. I am assuming that is what the owners' manual says. Do you know which ATF they used when they did the drain and fill?
If you don't have the ability to do this yourself and since there already seems to be a problem, I'd go to a Toyota dealer and do that plain flush. At least they would (?) use the correct fluid and should know the correct temp range.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Supertech Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130393 06/10/19 02:52 PM
Donald Offline
I would bring it to a trusted indy transmission shop. An exchange of the ATF may prolong the life of the transmission but may not fix anything. If a part is worn then the part if worn, and 10 flushes will not fix it.
2015 Ford F250 w/Powerstroke
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130406 06/10/19 03:00 PM
W
windeye Offline
W
assuming the ATX was taken care of before you bought it (meaning the ATF is properly refreshed every 30K miles, toyota's 10K miles recommendation often indicates it's too late to change), there are two things to check: 1) type of fluid the shop used, if it's generic stuff, it will mesh up the friction characteristics. I did some research on this topic on my mazdas, and came away not believing the after-market fluid claiming they are all compatible with the seemingly in-compatible fluids by the OE); and 2) the ATF level was not set properly, as others have pointed out, you need a proper scan tool to check the level and it's in a very small temp window.
That being said, you face what you have on hand now, if it was me, I'd find a reputable shop/dealership, and do a complete exchange of ATF via cooler lines, and set the level properly.
2000 Mazda MPV LX, 202,500 miles
2007 Mazda 3 Touring, 112,800 miles
2013 Toyota Camry XLE, 100,800 miles
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130418 06/10/19 03:05 PM
Cujet Offline
Are you sure it's slipping? Could be the converter unlocking under load, allowing RPM to increase.
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130442 06/10/19 03:28 PM
M
meep Offline
M
I've had a few aisin trans and have never seen them slip unless the solenoid screens were loaded with debris. fluid changes don't fix that.
in a daimler trans, slipping was remedied by small amounts of lucas transfix (it's like molasses) added in to taste. you'll need to be comfortable dealing with fluid levels in your trans to try this.
if all of your fluids are healthy, you have a non-fluid problem.
2018 F150
2015 crv (wifey!)
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5130467 06/10/19 03:54 PM
diyjake Online Content
Online Content
These transmission don't have an actual dipstick so it is very critical to use a scan tool when changing the ATF to get the correct fluid level at the right temp. Improper fluid level cold cause your transmission to behave like this.
I do have one good question, if you take the car to the dealer or a indy shop to do a flush, how do these flushes work? Do they put in the same exactly amount of fluid as what they pull out? Or will they fill the proper amount no matter how much fluid was pulled out?
Re: 2010 Camry trans slipping after 2 drains; what now? [Re: Jasper8146] #5131163 06/11/19 08:52 AM
G
grjr Offline
G
I don't think the shop that changed your fluid made a mistake when they said that they only got 2 quarts of fluid out. I have a 2011 Sienna with a U660E trans which I believe is the same as yours. I've drained and filled the ATF twice now and the first time I only got about 2 quarts out. The second time I let the vehicle sit for a couple days to allow the fluid to drain down to the pan and I got about 2.4 quarts out. Both times I raised the front of the vehicle with my jack to get the most fluid out. I used a 1000 mL graduated cylinder to measure the amounts of fluid I drained so I'd say my numbers are more accurate than most.
