Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
38 registered members (AndyB, BlueOvalFitter, Bighorn2500, chemman, 8 invisible), 638 guests, and 19 spiders.
Topics290,259
Posts4,987,225
Members68,412
Most Online2,967
Mar 10th, 2019
98 Expedition - Spark Plug Torque to prevent spitting plugs #5130226
06/10/19 12:27 PM
06/10/19 12:27 PM
Florida
Fitz98 Offline OP
Fitz98  Offline OP
Florida
I am changing the plugs on my 98 Expedition 5.4 4x4.
Torkspec website says 10 lbs torque on plugs to head, but I have also read to increase torque to prevent spitting plugs.
Anyone know the magic number to torque these into the triton aluminum heads?
I have spit a plug before and would like to prevent it again if I can.
Was there ever a TSB?
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130264
06/10/19 01:05 PM
06/10/19 01:05 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
From the FSM 16-20Nm or 12-14ft-lb
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130301
06/10/19 01:35 PM
06/10/19 01:35 PM
Apple Valley, California
Chris142 Offline
Chris142  Offline
I would use my arm and go strictly by feel.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: bdcardinal] #5130362
06/10/19 02:30 PM
06/10/19 02:30 PM
Florida
Fitz98 Offline OP
Fitz98  Offline OP
Florida
So there was no TSB to prevent spitting plugs out of head?
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130364
06/10/19 02:31 PM
06/10/19 02:31 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
There's only 3 THREADS of aluminum holding each plug in. It's not hard to strip them out.
12-14ft-lb and no more than that.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130385
06/10/19 02:50 PM
06/10/19 02:50 PM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
For some reason I recall mine being tightened to 20. 1997 F150 5.4
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130400
06/10/19 02:56 PM
06/10/19 02:56 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
In that range you are getting into lb-in if you need any sort of real accuracy and you do which eliminates most 3/8 tools.
If you use never seize the number will be even lower, hand slightly firmer than snug and call it good. In my experience (not that I am a big Ford guy, far from it) they seem to let go more when tightened to the spec after changing them.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130450
06/10/19 03:43 PM
06/10/19 03:43 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Just about repairing the head after they blow out. Which according to Ford, they wanted you to put a new head on.
Here is a video from Ford Tech Makuloco https://www.youtube.com/watch?v=kc4-z-sT1ms
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130466
06/10/19 03:53 PM
06/10/19 03:53 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
There is a site out there that advises using some rediculous high torque on the plugs but I think thats a bad ida. Ive done a little research and Ive found 20-25ft lbs is doable on 4 thread heads. On the newer 8 thread heads I just go straight to 25ft lbs and dont even think about it. They dont loosen after that.
I popped 2 plugs on my 2002 and both times it was because the plugs had loosened until they blew out. Ive done some other mod motor vehicles and often find at least one spark plug loose and coated in the brown-orange soot from the gasses escaping up the threads.
imo 10ft lbs is too little torque to prevent loosening and backing out over time. If you want to be really safe torque to factory 10ftlbs and then go back and retorque every 10-20k
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5130480
06/10/19 04:12 PM
06/10/19 04:12 PM
Florida
Fitz98 Offline OP
Fitz98  Offline OP
Florida
I was also thinking about the anti-seize. It does just what it says, prevents the different metals from seizing, but can't help but wonder if that contributes to plugs loosening and blowing out.
Perhaps it is more due to dissimilar metals without anti-seize causing galvanic corrosion on the aluminum heads, weakening the aluminum threads.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5131071
06/11/19 06:54 AM
06/11/19 06:54 AM
Trav Offline
Trav  Offline
The problem with these is not anti seize or anything else its the 3 threads that is the root issue that even when new were weak, it is just bad engineering. Now you get to repair their mistakes, course engineers know best right. LOL
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5131174
06/11/19 09:06 AM
06/11/19 09:06 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
You would think some one would have filled a class action against Ford ?
Wyr
God bless
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Trav] #5131234
06/11/19 10:18 AM
06/11/19 10:18 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
I would say that now is the perfect time to repair every cylinder if the OP plans on keeping the vehicle long term.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5131259
06/11/19 10:47 AM
06/11/19 10:47 AM
Oklahoma
Schmoe Offline
Schmoe  Offline
Oklahoma
Ford days it's a spark plug problem, not a head problem.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L (RIP) 2018 CRV EX-L
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Schmoe] #5131343
06/11/19 12:02 PM
06/11/19 12:02 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Well I believe that when my poo turns purple and smells like rainbow sherbet.
