Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
20 registered members (CATERHAM, 2015Corolla, 4WD, bonjo, Duke, ChrisD46, 2 invisible), 616 guests, and 24 spiders.
Topics293,636
Posts5,043,858
Members69,027
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: bdcardinal] #5131377 06/11/19 12:57 PM
O
OVERKILL Offline
O
Originally Posted by bdcardinal
Originally Posted by Schmoe
Ford days it's a spark plug problem, not a head problem.
Well I believe that when my poo turns purple and smells like rainbow sherbet.
Indeed.
From a purely engineering standpoint, my understanding of how this was developed, and why it failed is as follows:
- Ford previously had full-thread holes in the heads. This was a PITA to get the plugs to centre when being installed on the assembly line so it was looked at how they could improve the self-seating ability of the plugs in the holes for fast turn-down on the line.
- Research was performed and the results indicated that sufficient engagement was provided by ~3 threads, this meant that the remainder of the hole could be bored smooth so that the plug could be dropped down the hole and tightened down extremely quickly, since the smooth section set the plug straight.
- Research was NOT done to explore the behaviour of this setup once damage to the threads had taken place due to removal/installation; there was no testing as to how this would fare with in-the-field service.
- So from a design standpoint, the 3-threads were technically "sufficient", however, as we all know, the risk of damage to those threads on a subsequent long-interval removal and install is extremely high. It doesn't take much galling to compromise the integrity of this setup and result in a loose plug, which may in turn become a blow-out.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5131397 06/11/19 01:21 PM
blupupher Offline
Yup, and that is why in late '02/early '03 they redesigned the heads to have 7-8 threads (and those heads have no issues).
Most forums people have had good luck with Motorcraft plugs installed dry and torqued to ~24 ft lbs.
My '02 has a used '03 motor in it, so it has the newer heads with more thread.
2018 Santa Fe: PP 10W-30/OEM/5k
2018 Soul: Mobil Super 5W-20/OEM/5k
2012 xB: M1 EP 0W-20/CQ Blue/5k
2002 F150: Magnatec 5W-20/Bosch D+/1yr
1994 VT1100: Peak 15W-40/Bosch D+/1yr
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Trav] #5131401 06/11/19 01:24 PM
T
talest Offline
T
Originally Posted by Trav
The problem with these is not anti seize or anything else its the 3 threads that is the root issue that even when new were weak, it is just bad engineering. Now you get to repair their mistakes, course engineers know best right. LOL
Good to know it was not just the Northstar with stupid thread designs. Stupid.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: blupupher] #5131618 06/11/19 06:11 PM
bdcardinal Offline
Even the heads with 7-8 threads shoot plugs. However the frequency is a LOT less.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5132351 06/12/19 02:01 PM
B
Black_Thunder Offline
B
I torqued mine to 28 ft lbs.
I feel an added issue is they weren't installed tight enough from factory and when they loosen up the compression cycles would beat the plug around against the threads causing them to wear or dislodge and eventually fail
I'd buy Callahan autoparts if I could.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5132415 06/12/19 03:09 PM
R
red7404 Offline
R
i helped a guy with a fuel dragster once. 392, blower ect. stop when the gasket compress.
Re: 98 Expedition - Spark Plug Torque to prevent spitting plugs [Re: Fitz98] #5132448 06/12/19 04:06 PM
M
mk378 Offline
M
Gasket?
They're taper seat plugs.
Page 2 of 2 1 2
