This rattle has been getting on my nerves for quite some time now. It would become auditable at freeway speeds and it sounded like a screw was loose in the quarter panel, or a pebble.
Since the car had front end damage repaired last year, that's where I started checking, but aside from one headlight screw being loose, everything else was fine, and the rattle persisted. I pulled the wheel well liners and found nothing out of ordinary.
Then about two weeks ago I was washing the car and when I washed around the front wheel splash guard, I heard it rattle.
Turns out the plastic grommet somewow lost its tension and was loose inside the rocker panel hole.
I wrapped it with some electrical tape to make it fit snug again and the rattle is now gone.
Both sides had the same thing and we're never damaged. If I didn't accidentally stumble on this, I would have never thought to check it.
