Originally Posted by ARCOgraphite
Originally Posted by vavavroom
Originally Posted by slacktide_bitog
NGK makes a good set of wires. They are numbered and come in a nice blue color
I have cut NGK/NTK silicone spark plug wires. The jacket consists of an outer blue layer of silicone and the inner jacket out of white silicone. The core is a multistrand silver-colored wire, although it says on the wire jacket "copper." By the way, why do we call them spark plug cables? They are wires.
BC there is NO wire in high tension ignition cables - unless its aftermarket "MAG Wire"
The Copper notation was for the terminals ONLY - not the wire. '
The center insulator is typically EPDM rubber.
You don't want or \need low impedance "wire" for super high voltage pulse ignition. It doesn't help. And the FFC will chase you.
There is definitely a wire core in this OE replacement wire. I'll have to look for the wire. Maybe I can find it.
