Originally Posted by 69GTX
The problem was never with DexCool. But rather with poor maintenance habits by the owners who did "happen" to own those engine gaskets that could fail if you completely ignored coolant system.
You, sir, do not know of what you speak. One example does not make a case study.
Dexcool in an LS series engine is not a problem. Dexcool, immaculately maintained in my '97 C2500 5.7 managed to eat the intake manifold gaskets. Those gaskets might have failed anyway with conventional antifreeze, but not at the 7 year 60k mile point where they did. And this was not an isolated case, it happened to just about every vehicle with that engine (and many others) when factory equipped with Dexcool regardless of how well they were maintained.
Now, if you are talking about the reported Dexcool sludge that happened in unsealed systems that were not properly maintained, I am in agreement with you. But for many late 90s and early 2000s GMs, Dexcool combined with bad intake manifold gaskets compounded the problem with both, and existed regardless of how well the system was maintained.
Not knowing if the newer OEM gaskets I used in the 5.7 small block were of the improved design (I didn't know about the Dexcool/IMG problems in 2003/4 when I replaced them) I use G05 in that truck, and have had no problems since. All my other GMs that don't have the common IMG problem get Zerex Dexcool and are clean as a whistle.
