Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
17 registered members (4WD, bonjo, dieselguy67, CATERHAM, 2015Corolla, eljefino), 639 guests, and 23 spiders.
Topics293,636
Posts5,043,861
Members69,027
Most Online3,532
Jul 30th, 2019
BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage #5129536 06/09/19 05:57 PM
SlavaB Offline OP
Anyone can help with directions on how to use BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage?
Got one on sale (as described here https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5129533)
17 Kia Sportage EX 2.4 GDI / Mobil1 5w20, OE 26300-35505
15 MB GLA250 4Matic 2.0T / Mobil1 0w40, Hengst E818H
Re: BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage [Re: SlavaB] #5129650 06/09/19 07:55 PM
demarpaint Offline
This might help. BG 206 Directions. It appears a special tool is needed.
God Bless Our Troops
Re: BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage [Re: SlavaB] #5129654 06/09/19 07:58 PM
L
Linctex Offline
L
It did not come with instructions?
I think you have to pour the contents into some type of pressure vessel with a valve on it
Re: BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage [Re: SlavaB] #5129691 06/09/19 08:33 PM
SlavaB Offline OP
Thx! Seems like I won’t be able to do it myself really
Re: BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage [Re: SlavaB] #5129857 06/10/19 12:36 AM
J
Jetsfan421 Offline
J
Looks similar to seafoam spray. You could probably get a similar effect by using a spray bottle set to mist and spraying it with a buddy controlling rpms.
Re: BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage [Re: Jetsfan421] #5129915 06/10/19 05:08 AM
L
Linctex Offline
L
My first thought was a "pump-up garden sprayer"...
but then, there are these refillable air spray cans, too (I just added one to my cart):
https://www.amazon.com/FIRSTINFO-Al...ure/dp/B00YF7Q1TI/ref=asc_df_B00YF7Q1TI/
https://www.amazon.com/gp/product/B00YF7Q1TI/ref=ox_sc_mini_detail
Re: BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage [Re: SlavaB] #5130923 06/10/19 10:53 PM
M
Mad_Hatter Offline
M
Take off the hose from the airbox to the throttle body.
Buy a plastic spray bottle from Walmart for .99 cents, set it to mist.
Have your friend rev the engine to about 2k rpms to open up the throttle plate and mist away. Let off the gas, wash rinse and repeat. If you can spray fast enough you can hot soak the valves and piston tops. Give them a few minutes before starting up again to allow the cleaner to do it's job. When you're done just toss the cheap spray bottle in the trash. I wouldn't store any unused product in the plastic bottle.
On older cars with a throttle cable you could do it by yourself but not yours.
An alternative to using a cheap plastic spray bottle would be to go onto Amazon and look for refillable oil spray bottles that you would use in the kitchen for misting something like an olive oil. They have a hand pump to prime them and you can pick up an aluminum bottle version for about $10. You might have to refill it a couple of times but that's not hard. On the upside you have a spray container you can reuse over and over, just be sure to flush it out with water after usage because the cleaners solvents might eat it up.
Re: BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage [Re: SlavaB] #5131407 06/11/19 01:27 PM
N
nicholas Offline
N
Let the engine sit for 30-60 mins after giving your intake a good blasting for a proper heat soak - - - then open er up on the highway, safely of course.
2019 2.0T Santa Fe
2010 3.5 Santa Fe
Re: BG 206 Air Intake Valve Cleaner in my 17 Kia Sportage [Re: SlavaB] #5131487 06/11/19 02:57 PM
SlavaB Offline OP
Thx everyone!
