Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
118 registered members (928, 2012AccentSE, apollo18, Anduril, ABomb369, 750IX, 9 invisible), 2,253 guests, and 22 spiders.
Topics301,698
Posts5,200,833
Members70,759
Page 2 of 2 1 2
Re: Best filter to run [Re: chubbie] #5128959 06/08/19 11:10 PM
Marco620 Offline
Ford MC on a Ford. Maybe a drain plug magnet or filtermag to help. Fram Ultra or TG on Honda as Fram is Honda OEM
15' Civic 1.8 i-vtec 310,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Best filter to run [Re: chubbie] #5128966 06/08/19 11:26 PM
DoubleNickels Offline
Note that about a decade or so ago, Ford Motorcraft FL-400S used to have a longer canister. Some other cross reference filters still produce the filter with the taller canister. Just a little bit more filter media & capacity, if that is important to you. AD Delco PFL400ACS uses the taller canister. I also ran across the Bosch Work Shop which has a taller canister. Depending on fitment, some people have even used the Ford Motorcraft FL-1A, which is a larger filter with the same 3/4-16 thread.
[Linked Image]
Re: Best filter to run [Re: chubbie] #5128973 06/08/19 11:46 PM
Z
zorobabel Offline
Z
I have seen a bad FL400S cut open on this board.
1997 Maxima 210k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 211k, Valvoline SynPower 5W-30, K&N HP-1003
Re: Best filter to run [Re: zorobabel] #5128989 06/09/19 02:20 AM
chubbie Offline OP
Wow.ok. So if I have room the motorcraft fl-1a is a direct cross reference to my fl400s. And the cross reference to the fl-1a to the fram tough guard would be the tg8a. I could in theory use that big beast.or better yet the fram xg8a?
07 Dodge Ram 151K shell rotella gas truck 5w-30
18 Mazda cx5 61K pennz syn 0w-20
Re: Best filter to run [Re: chubbie] #5128992 06/09/19 03:11 AM
Only if you have room, and it fits. Same thread pitch doesn't mean that the filter will fit up to the oil pump. The canister is taller, and has a larger diameter.
Re: Best filter to run [Re: chubbie] #5129037 06/09/19 06:06 AM
J
jongies3 Offline
J
Fram Ultra is probably the best for the money, but I run the orange Frams personally. Never use a filter long enough to justify an Ultra! But they are excellent filters and priced very competitively for a synthetic media/wire backed filter.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
2003 Buick Park Avenue Ultra S/C 3.8 V6: PYB 5W-30, FRAM PH3387 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: Best filter to run [Re: chubbie] #5129117 06/09/19 07:53 AM
Mr Nice Offline
I use Fram Ultra for 3 OCI’s.
Re: Best filter to run [Re: Mr Nice] #5129200 06/09/19 09:50 AM
chubbie Offline OP
Ok also the fl-1a has a larger diamater so if the backing plate that it's screwing on to has to be wide enough for it. I see.
Re: Best filter to run [Re: PimTac] #5129221 06/09/19 10:08 AM
E
E150GT Offline
E
Originally Posted by PimTac
I don’t believe a adv is necessary for the SkyActiv.
Another option are the Thailand made Roki filters.
I'm pretty sure the Thai made filters from the dealer are made by denso. They look nearly identical to the Thailand made denso Toyota filters and have similar marking on the box.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: Best filter to run [Re: chubbie] #5129236 06/09/19 10:19 AM
B
bullwinkle Offline
B
The threads are the same, it just has to fit. For instance, on the Cherokee in my sig, the factory filter is a short Fram PH16 size, but the PH3600/FL400S fits, as does the FL1A/PH8A size. Just make sure there's enough room around them. On your Valvoline Ecore ADBV, that's a common flaw with black nitrile ADBVs, especially on Purolator made filters-engine heat stiffens them & they quit sealing-I've had Quaker State filter ADBVs quit inside of 2000 miles before!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Best filter to run [Re: chubbie] #5129447 06/09/19 02:51 PM
A
Al Offline
A
Another ultra user here.
Page 2 of 2 1 2
