A car's steering wheel is in about 350 degree position when driving straight down the road. That means if you drive with the steering wheel in the 360 or 0 degree position the car will drift over to the right (USA).
I know I can adjust the tie rod's equally on both sides to center the steering wheel, but not change the total toe alignment. That is what I want to do. However, I can't seem to get it clear in my mind which way I should turn the tie rod's to make this adjustment - to turn the steering wheel a few degrees clockwise. In this vehicle, the tie rod ends are behind the center line of the axle.
I need to lengthen one side and shorten the other side by the same amount. I made a small adjustment that shortened the drivers side and lengthened the passenger side. Talking in terms of turning clockwise and counter clockwise of the tie rods can be confusing depending on your point of reference so I found that I just think in terms of turning my wrench the same way on both sides. In other words, I moved the wrench in the upward motion on both sides.
Since I couldn't really tell much difference I thought I'd check and see if you can help with which side I need to lengthen and shorten to get the steering wheel to move clockwise toward vertical position of 0 degrees.
I'm now so confused I've about determined maybe I was going in the wrong direction ?
