I seem to be having a bit of a problem with my trailer light converter in my 2004 Audi A4, I've had 2 burn out on me. They are Curt 56146 powered tail light converter. I realize my car has PWM brake/running light so to get around that and use the above converter I tapped into the 3rd brake light for brake input and the separate running light in the tail light for the running lights. Testing it all out with a test light everything works, plug in the trailer, hit the key fob unlock and watch the trailer lights flash and I'm good. When I get to the boat launch I see I have no trailer lights at all.
Warranty the converter since I figure I must have gotten a bad one, next one did the same thing. I hooked my trailer to my Q5 with factory tow package and all the lights work as they should as well as my other car with a non powered tail light converter. I've since pulled the trailer lights all apart and I found that one of the bullet connectors for the ground for the right tail light was unhooked. Could this unhooked ground cause the signals/brakes/running lights to backfeed and ground thru the converter and fry it? Trailer in question is a 2013 Karavan PWC trailer which was brand new when I bought it in 2017. Has anyone ever opened up one of those and try and repair the sacrifical circuits that fry when its shorted? I can't send this one back for warranty as it was my screw up.
