Originally Posted by ZeeOSix
Originally Posted by bullwinkle
"Best", in my opinion, is the one that can hold up, without tearing, and do it's job for at least the factory OCI, or longer, preferably with a silicone ADBV (that doesn't get chewed up by bad machining/no deburring), for a non-ridiculous price.
#1 Fram Ultra (cheapest in the eBay 6 pack, can could be stronger)
#2 Royal Purple (cost higher, full syn & stronger can)
#3 Fleetguard Stratapore & Venturi (superior filtration, but $$$)
#4 Bosch Distance Plus (strongest can, blend media, hard to find, sometimes eats ADBVs)
#5 Mobil 1 (blend media, still somewhat expensive)
#6 Fram TG (blend media, silicone ADBV)
#7 Fram XG (new ones have silicone ADBV, sometimes pleat spacing shaky)
#8 Champ Ecore (decent media, don't push them too far)
#9 Premium Guard & other similar Chinese (lots of media, efficiency not great)
#DEAD LAST Purolator & other tearing Mann & Hummel offerings, which also have nitrile ADBVs that harden fast
#4 is not high efficiency like the OP also asked about.
Thought he said "best construction", which also means can strength to me, when a truck sees a lot of gravel roads & kicks up debris. I had to change my last XG3600 early due to a good sized dent that was starting to rust under the Sure-Grip. Unfortunately the Bosch DP is only 99% @ 40 microns-still better than a Wix XP/NAPA Platinum.
