Alignment questions: is camber/caster not usually touched?
by FordBroncoVWJeta - 01/26/20 10:47 PM
Pricing used tires
by PumpPusher - 01/26/20 10:21 PM
STP Motor Oil at HF
by kstanf150 - 01/26/20 10:07 PM
9 years for the 4 cylinder Eco-boost
by Snagglefoot - 01/26/20 09:39 PM
So I picked this up..
by Mad_Hatter - 01/26/20 08:49 PM
New here and question about oil.
by Sunstealth - 01/26/20 08:42 PM
Looking for a car for $4k or less
by SVTCobra - 01/26/20 08:09 PM
I'm looking for a 2017 Camry LE in Pgh. PA area
by JimPghPA - 01/26/20 07:59 PM
just bought a lift!
by agarb - 01/26/20 07:54 PM
09 Mercury Grand Marqyus fix or dump?
by John_K - 01/26/20 07:14 PM
Any Castrol Edge EP Users ?
by ChrisD46 - 01/26/20 07:06 PM
Good inexpensive smart charger?
by dvancleve - 01/26/20 06:12 PM
top fuel flames.
by red7404 - 01/26/20 05:24 PM
What say you?
by Mad_Hatter - 01/26/20 05:18 PM
2006 Cadillac CTS: worth looking into or run away?
by 53' Stude - 01/26/20 04:07 PM
2012 Elantra battery running at 11.7 volts
by schuylkill - 01/26/20 03:31 PM
Chevron Supreme no longer at Costco
by OilUzer - 01/26/20 03:18 PM
tampasaint, rdmjone, BigGeo, apham8, Sunstealth
70535 Registered Users
53 registered members (bbhero, AC1DD, 1WildPig, adams355, ArrestMeRedZ, 4 invisible), 2,187 guests, and 17 spiders.
Topics300,617
Posts5,179,379
Members70,535
Page 1 of 4 1 2 3 4
Ever bought/changed a coil pack? #5127769 06/07/19 09:40 AM
Z
ZZman Offline OP
Z
Of all the vehicles I have owned I have never had to buy or change one. Am I lucky or are some vehicles just prone to having them fail?
2007 Hyundai Santa Fe AWD.
2005 Toyota Avalon XLS
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127777 06/07/19 09:48 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
You're lucky... or you haven't put enough miles on your cars. I've had to change them on nearly every car I've had. Some needed replacing yet again.
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127790 06/07/19 10:03 AM
E
Ed_Flecko Offline
E
As spark plugs wear and the "gap" increases and the load on the coil pack increases accordingly, ultimately accelerating their failure. The coil pack increases power to the spark plug to always keep it firing, and that gets harder as the gap increases.
Replace your plugs at regular intervals, don't try to squeeze every mile you can out of them and you'll likely increase the lifespan of your coils. I set of spark plugs is a lot cheaper than coil packs.
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127791 06/07/19 10:04 AM
N
newbe46 Offline
N
I had 3 of them gone bad in my M3. I could have changed it myself but it was in the middle of winter so I couldn't bother. They changed all 6 of them.
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127799 06/07/19 10:18 AM
W
WyrTwister Offline
W
Dad and I changed the single coil on his 69 Galaxy 500 , 302 cid engine , maybe in the 1970's ?
I may have changed one on one of my cars . Can not remember clearly enough to say for sure .
Truth is , cars , now a days , are running more miles than in my youth . Maybe that has something to do with it ?
Wyr
God bless
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127801 06/07/19 10:20 AM
daves87rs Offline
Nope, never changed one.....
2020 Chevrolet Trax LS
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
2004 Chevrolet Cavalier
Too much GM.. ;-)
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127803 06/07/19 10:24 AM
G
GMBoy Offline
G
In the old days of carbs it was common for the coils to last maybe 50-60k miles before needing to replace it. Those were just cheap cylinder oil filled styles...we would always upgrade a chrome unit lol. Nowadays, I have only noticed that GM 4.2 inlines and 3.6L motors go thru coils often.
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127808 06/07/19 10:26 AM
B
beanoil Offline
B
Dodge Caliber, had one fail, RockAuto'ed one. Easy to swap out.
RamPromaster company ride, CEL came on, bad miss, failed coil pack. Car was in the shop for a week, excuse was the Fiat coil pack came from Italy.
Chrysler T&C, failed coil on the rear bank gave a CEL. Had all plugs and pack replaced, repair shop said all other coils tested fine. I don't know how coils are tested, took their word on it. And I wasn't going to be the one digging into the rear bank. A man needs to know his limits.
As I'm thinking, all were FCA products that had coils go boink.
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127813 06/07/19 10:29 AM
L
Linctex Offline
L
My uncle's 2001 F150 4.6 liter would kill the furthest forward one (on the passenger side) with regularity....
We never could figure out why.
My 2008 F150 4.6 has never had one fail with 192,000 miles on it.
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127825 06/07/19 10:47 AM
caprice_2nv Offline
When I worked at the Ford dealer mid 2000s we replaced them constantly on the trucks. One employee in our body shop had to replace all of his over a period of a year on a 2003 f150.
I've never seen one fail on a gm truck from the 2000s, or any of the hei coils in my old 1980s cars (knocks on wood).
Some vehicles seem prone to them failing more than others. Change spark plugs more often to prevent failure, is good advice.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127829 06/07/19 10:54 AM
ls1mike Offline
I have replaced some on a Subaru H6 Tribeca and one on the S/C 3800 Regal I had (which is really two)
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127841 06/07/19 11:10 AM
B
brages Offline
B
"coil pack" is a misnomer when used to refer to a coil-on-plug module.
I had bad coils on a Mazda MPV (Duratec 3.0) and had to replace several.
Re: Ever bought/changed a coil pack? [Re: ZZman] #5127845 06/07/19 11:18 AM
B
Blkstanger Online Content
Online Content
B
I have done them all on my Jeep. When I bought it it still had the original coils. The little springs that make contact with the plugs were rusted out. When I went to change the plugs they fell apart.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5 Castrol Edge EP 5w30 Fram Ultra.
Re: Ever bought/changed a coil pack? [Re: Linctex] #5127846 06/07/19 11:19 AM
supton Offline
Least cooling, ran the hottest? Vibration? shrug
Myself, I don't think I've ever replaced one. Never owned a gasser long enough I guess.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 221k, his
Re: Ever bought/changed a coil pack? [Re: supton] #5127850 06/07/19 11:21 AM
bdcardinal Offline
The cowl drains on top of them so whenever it rains they get soaked.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Page 1 of 4 1 2 3 4
