RATS
by MrQuackers - 12/07/19 07:46 PM
60 registered members (AndyB, Astro14, AZjeff, adams355, 2015_PSD, AurionX2, 7 invisible),
1,230
guests, and 54
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,433
Posts5,135,318
Members70,066
Most Online3,589 Nov 2nd, 2019
Re: Hole in engine :(
[Re: GumbyJarvis]
#5122769
06/02/19 04:47 AM
Lubener
Posts: 3,441 |
Maxlife. It has seal swellers. Won't patch a hole. You could try cleaning the area and doing a JB Weld application(s). You got nothing to lose.
The "thinking" man's friend.
[Re: Matagonka]
#5122812
06/02/19 06:29 AM
Triple_Se7en
Posts: 11,412 |
Super Glue it and seal with Duct Tape.  Seriously now, is there a chance you could find another just like it.... that way you make-use of all the parts just purchased?
19' Hyundai Santa Fe 2.4 GDI - Valv Syn 5w30 / Napa Proselect filter / 6oz Liqui-Moly 20' Kia Soul X-Line 2.0 Multi-port / Factory-fill oil / filter 04' Colorado 3.5 / Castrol Edge 0W40 / K&N filter
[Re: Matagonka]
#5122989
06/02/19 10:41 AM
Cujet
Posts: 9,053 |
Surplus center often has good deals on replacement engines.
[Re: Matagonka]
#5123115
06/02/19 01:52 PM
andyd
Posts: 8,559 |
Linctex Joined: Dec 2016 Posts: 8,570 Waco, TX I have fixed busted mower engine blocks, FAR worse than that. Make a metal patch and epoxy it on. Heh Heh. yep My brother, stole a piston + rod from dead Vertical shaft and patched crack with aluminum flashing to get 3.5 KW generator going during blizzard of '78. His 7th grade science project was assembling and disassembling an old 3hp B+S.
'16 Camry LE STP synth 0w20 and STP filter. the Fridge 1994 Ranger ,the Rat, 5w30 dino, STP filter '16 Camry SE, Valvoline HM 0w20 and OEM filter Thick oil is better
[Re: andyd]
#5123223
06/02/19 04:12 PM
Triple_Se7en
Posts: 11,412 |
Is that correct? 8570 posts in three years here....wow.
I hadn't even touched a screwdriver, wrench or pliers yet in the 7th Grade. Didn't used multiple tools in any home project, not until I married at the age of 20. Basic, necessary tooling is me.
No dad growing up and vested in our home with five sisters. No male mentors, tutors or helpers around. In front of those five sisters were two brothers. Each more than 20 years older than me. Both were married and gone as I reached 3-4 years old. Both fixed our home when it needed work. Both never took the time to teach me.
Life goes on and really no regrets.
[Re: Matagonka]
#5123478
06/02/19 08:42 PM
spasm3
Posts: 10,669 |
I wonder if you could close that hole with on of those brazing rods made for aluminum. I think they were a zinc alloy.
13 elantra 81k 5w30 synpwr 03 chevy avalanche 83k synpwr 5w30 17 mazda cx-5 17000 miles synpwr 5w30
[Re: Matagonka]
#5123822
06/03/19 08:03 AM
meep
Posts: 4,119 |
the metal is bent back and not entirely detached?
Tap it back into place with a hammer, clean it REALLY WELL, getting ALL of the oil off, then slather with JB weld....
(and replace the rod...)?
what we can't see is gouged crank bearings, and other internal damage...
2018 F150 2015 crv (wifey!)
[Re: meep]
#5127666
06/07/19 07:21 AM
Matagonka
OP
OP
Posts: 588 |
I'm getting there. Had to park it for a couple of days. Started working on it last night. Need to remove deck and unscrew the bottom bolt to take off engine now. Gettnig close. The rod is definitely gone. If crankshaft is good, I'm rebuilding it. I found another tractor for 150 on CL for parts. He hasn't answered yet.
2018 Mazda 3 Touring HB 2.5
[Re: Matagonka]
#5127734
06/07/19 08:57 AM
MrMoody
Posts: 485 |
PM me if interested in coming to get the LT1000 I have, it would run and mow if it would crank, pretty sure the compression release on the cam is broken. A family member gave me a Troy Bilt so it's more trouble to fix than it's worth to me.
2018 Hyundai Kona 1.6T DCT 2006 Pontiac (Holden) GTO AT 2001 Pontiac Grand Prix GT 3.8 NA (beater) 2005 Toyota Matrix FWD (ultra beater) "Fob" and "Noack" are not acronyms.
[Re: Matagonka]
#5128322
06/08/19 05:52 AM
Cujet
Posts: 9,053 |
A TIG welder can fix that block without difficulty. If you were near me, I'd do it for you. (Jupiter, FL)
[Re: Matagonka]
#5128707
06/08/19 04:07 PM
Bjornviken
Posts: 821 |
Only downhill in neutral. 🤣🤣👍
