Originally Posted by slacktide_bitog
How much time does it take for you to pull the intake on a VQ like the 4th gen Maxima? That's one of the better transverse V6 designs, and that one has cutouts int he intake to access the rear plugs and coils. It still takes time to pull the intake, but not as bad as the 1MZ.
I thought pulling the intake on a 4th gen VQ30DE was pretty awful. The two bolt/studs (can't remember which) for the hangers in the rear are almost impossible to get to. Fortunately the cutouts allow access to the plugs on the rear bank without intake removal, but keep in mind this required Nissan to design TWO DIFFERENT coils, one set for the rear bank, one set for the front that are not interchangeable. That adds cost, and I'm pretty sure the bean counters have made the practice of two different coils ancient history.
I've done a few vehicles which required intake removal for rear bank plug access and they weren't bad. My Pacifica takes about 15 minutes to pull the plastic intake and get to the plugs. I've done a Ford Duratec 3.0L V6, that wasn't bad either, less than 30 minute job. I'm sure there's vehicles where pulling the intake to get to plugs is a real challenge, but I haven't encountered any yet.. Other than my Maxima, but the intake doesn't need to be pulled to get to plugs, I had to change a knock sensor deep in the "v".
Worst vehicle I've ever done plugs on, by far, was a 2001 Nissan Frontier with the VG33ER supercharged engine. This is a longitudinal engine which goes to show that the transverse V6 plugs being hard to access is NOT a blanket statement. Plug accessibility has everything to do with the vehicle/engine bay layout, it's not inherent in an engine size or orientation.
