2015 Accord V6 Idemitsu 0w20
Crown Point, IN
Very boring UOA. I guess that's a good thing
I read that Idemitsu ATF is the same fluid as Honda DW atf. I wonder if this oil is the same thing as Honda branded dealership oil?
Originally Posted by UncleDave
Is the mm telling you to dump?
UD
Yes, I drive "severe driving" mostly city driving and the MM tells me to dump it between 5K and 6K miles.
Originally Posted by Patrick0525
@dan_erickson Which Idemitsu 0w20 ? There are three types. Looks like the basic type.
Not sure off the top of my head. It's the in the silver bottle that Advance clearance out a couple years ago
Not quite.
Idemitsu is the supplier to Honda, but the formulations are slightly different.
UD
UD
Thanks.
Interesting my Ridgeline lets me go 8-9K towing 5K for 3-4K miles.
Without seeing TBN it's hard to tell how much life left - but based on everything else in the UOA's it appears the OLM is having you dump quite early.
been collecting 3.5 earth dreams UOAS to see how well the MM/OLM actually does - so far it hasn't let anyone go to far yet, but of course, not everyone uses that tool.
UD
Can you give more details beyond "city driving" ? Telling you to change the oil at 5-6k miles is pretty low on such a new Honda. I mean, are you a delivery driver or similar ?
Not quite.
UD
Is either formula better than the other? Would an Idemitsu 3 quart drain/fill "play nice" with the existing Honda DW?
Not quite.
UD
I can't say which might be better.
I know which one is "better" for a vehicle under warranty.
I run idemitsu trans fluid in my Titan with confidence - Idemitsu is one of the few ATF refiners that have matching vs "universal" trans friction formulas.
Out of warranty Id still probably stick with Honda - or at least do a full fluid exchange over to idemitsu - -
curious why change formulations at all ? Whats your reason to want to do it? - no judgment just curiosity.
Bernardi auto parts is a good source for genuine honda fluids.
Not quite.
UD
Just curious I guess :p I'd run into an AZ to browse and saw it. I'd never seen it before so I did a quick Google search on it,and people rave about it,saying it gave better shift feel over Honda OEM.
That's a very, very good point UD... Idemitsu actually has a specific CVT fluid that is only for NS-2... Type N they call it... That is the one I will use to do a few drain and refills on my Nissan Altima 3.5 coupe. And it is $9.99 a quart.
